Sharp Electronic Calculating / Printing Machine Compet Qs-2760a Calculator Logo
michelle roach Posted on Jan 16, 2013
Sharp calculator not printing dark enough - Sharp Electronic Calculating / Printing Machine Compet Qs-2760a Calculator
Sharp EL-1197PIII printing nonsense after a jam.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it .
Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism .
you are looking for resources to properly align the gears. I found a few resources that might be helpful:
Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link: SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib.
Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link: Sharp EL-1197PIII User Manual online (mans.io).
Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link: User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
4answers
Out of box brand new Sharp EL-1801v and the 5 button doesn’t work. Defective or Is it me?
Defective, return it for replacement.
EL-1801V 12 Digit Compact Printing Calculator - Sharp ...
sharpcalculators.com > products > EL-1801V-12-Digit-...
EL-1801V 12 Digit Compact Printing Calculator. EL-1801V. EL-1801V 12 Digit Compact Printing Calculator EL-1801V. Printing Calculators. Price : 70.99 ... US$70.99 · ‎In stock
Sharp EL-1750V will not print
The manual says contact Sharp -
1-844-578-1637
5helpful
My texas instruments ti-86 is dark all the time, help me please
After changing the batteries the calculator is restored to factory defaults, but the screen contrast may change. The screen may be too light to see anything or., as in your case too dark.
To lighten screen
Press [2nd] key and release it.
Press and hold [DownArrow] until screen is light enough.
To darken screen
Press and hold [UpArrow] until screen is dark enough.
Hope it helps.
Thank You for using FixYa and for rating the solution.
2helpful
How do I print a date format with sharp el 1801PIII?
To print the current date press once the Clock/Calendar key and then press once the Non Add/ Subtotal key (# key)
To print out any other date (or codes and other numbers that are not part of a calculation) just type it and then press the Non Add/ Subtotal key (# key). The date/number will be printed preceded by the # sign.
You may also want to download the SHARP EPL-1801PIII Operation Manual
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
