Question about Intel DG43NB Motherboard
No soun out put is coming
Sound is not coming out from the back panel
  • Intel Master
  • 3,606 Answers
Hello try to reinstall the sound driver from here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG43NB
And make sure the volumen, is not turned down low or muted.
The green outlet, is for the sound.
Good luck
Posted on Jan 20, 2013
No sound on some channels (which previously had sound); some channels still have sound
It seems that the "Lang" button on the remote may be pressed by mistake. Try setting the language to English and see if all the channels now broadcast sound.
Mar 10, 2014 | Sharp Televison & Video
No sound on my Sony Bravia KDL-40S3000
Check whether you can hear the sound through headphone, if the TV has a headphone socket. If it has, there are some internal defects.
Aug 12, 2012 | Televison & Video
P4m890-m7 no soun after radeon 2600 pro installation
If you have another slot put it there. It sound like you computer is assigning the same address to both and giving your radeon priority. It could be other things but try that first.
Oct 31, 2009 | ATI RADEON HD 2600 PRO Graphic Card
One of the back electric windows has slipped down into the door - i think it has come off some kind of runner? it is held up at the mo. How do you resolve this?
Runner or guide yes! Your going to have to take the inside of your door panel off to put it back on. There are screws located all around your door find them and remove. There also may be a hidden bolt on the inter handle which is used to shut the door, remove that bolt too! If you have automatic door locks and windows your going to unplug them once you get all of the screws removed. You can normally remove them by hand sometimes i use a flat head screw driver if they have clips. Once thats off you can will be able to see where the window is suppose to be and put back on. You may want to look around and see what caused it to come off while your in there so you don't have to take it apart again..Its not that hard in short remove screws and bolt un-plug wires put window on check and put back together...very simple good luck!
Sep 22, 2009 | 2000 Ford Focus
I have 1999 galand and have a tack tack soun i think is the lister
i had this same problem, its a loud tapping sound coming from the engine and sounds louder when you rev. i had the car for over 1 year working like this until i found a solution that cuts the noise significantly (over 50%) and also giving the car more power. it also helps wjth the over-idling when you start the car when it is cold. firstly disconnect the battery then you have to remove the air intake hose. this will expose the throttle body. there is a sensor attached to it, i believe that is the throttle body sensor.this sensor need to be removed and cleaned using a little wd-40 and then put back in place. make sure that your air filter is clean and mount back the intake.
May 06, 2009 | 1999 Mitsubishi Galant
No sound coming from speakers
check the sound setting, if u have sound in the computer but when u put cds it doesnot work! go to sound settings from control panel and adjust it, if there is no sound at all in the computer? reinstall the sound driver, if u have it , update it.
Regards
May 03, 2009 | Computers & Internet
HOW DO I DOWNLOAD SOUND DRIVERS FOR DELL PC
Go to Dell's support page. Put in your computer's service tag. Choose download drivers and look over the list. Choose the audio device that is installed on your system. After you download it, navigate to the folder you saved it in and double click the installer.
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Soun Drive+Task Manager related problem
This seems like an internal Mute,
go to the sound settings and select a new sound theme in controll panel and see if this helps.
if not then you may want to consider backing all your files up on a external hard drive and doing a full system restore back to factory settings
Please rate
Feb 21, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
No souned
check that you haven't muted the sound by accident. Look for a speaker icon in the task tray at the bottom of the screen on the right hand side. If it has a red circle with a line going through it, then it is muted. Click on it then click on the little blue speaker to turn off the mute.
If you have not got a speaker icon in the tray then go to control panel, sound and click double click on speakers then click on the blue speaker icon to turn the mute off. (For Vista)
Also make sure that the speaker wires are plugged in correctly on the back of the computer.
Jan 13, 2009 | Packard Bell iMedia SL 9553 (P660401806)...
Logitech X-530 Speaker Problem
SELECT CONTROLPANEL-SELECCT SOUN OPTION-SELECT SOUND SETTINGS-THEN SELECT 5.1 SELECT SPEKER. -THEN OK...
Sep 24, 2008 | Logitech X-530 Computer Speakers
Intel DG43NB  Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
