Question about Dryers
Changing light bulbs in model 28775
Need size type of bulb. How do you remove shade to change bulb?
    Genius:
  • Dryers Master
  • 1,669 Answers
What is it? Is it a car, truck, toothbrush or what? How about a manufacturer name!
Posted on Jan 16, 2013
  • 205 Answers
SOURCE: New bulbs in chandelier don't work
A light bulb is not a terribly complicated thing. I think you're saying that the bulbs are OK, but they do not seem to function in some of the chandelier sockets. Is that correct?
Assuming the bulbs are not burned out, the only reason this would occur is if they are not making good electrical contact with the socket. The bulb makes contact in two places, on is the threaded base and the other is the metal contact on the base of the bulb. My guess would be they are not threading in quite right and then you're not able to screw them all the way in so the base makes electrical contact.
Before you rate this solution I hope you'll take into account that I'm not paid to do this, I'm just trying to help. I have no idea what you're reaction will be, but I'm really getting tired of getting poor ratings for trying to help...especially when I seem to be the only one who responds on a question.
Posted on Dec 29, 2007
Crossedwires
  • 44 Answers
SOURCE: How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Posted on Feb 09, 2008
SOURCE: light bulb socket uses intermediate base bulbs, not standard bulbs
I found the solution on the web. The only place it looks like that has this adapter is voss lighting. Here is a link to the adapter. http://www.vosslighting.com/storefrontB2BWEB/itemdetail.do?action=prepare_detail&itm_id=18159&itm_index=7
Posted on Nov 11, 2008
SOURCE: light bulb burned out in ceiling fan
THE FAN IS ACTUALLY A WINWARD II BY HAMPTON BAY. ACCORDING TO INSTRUCTION MANUAL YOU TURN THE GLASS BOWL COVERING THE LIGHT ASSEMBLY UNTIL IT MAKES CONTACT WITH A COUPLE OF GROOVES IN THE RIM AND THE GLASS ASSEMBLY SHOULD RELEASE. I DID NOT RECEIVE ANY HELP FROM "FIXYA" BUT MAYBE THIS INFO WILL HELP SOMEONE ELSE WITH THE SAME PROBLEM. THE MODEL # OF THE HAMPTON BAY FAN WAS 523 342. (I FOUND MY INSTRUCTION MANUAL AND THIS IS WHERE I GOT MY INFO)
Posted on Mar 28, 2009
  • 7 Answers
SOURCE: changing light bulbs in Hampton Bay model AC 527 Ceiling fan
press up while turing it counter!
Posted on Mar 29, 2009
How do you change light bulb on hunter ceiling fan model 25734 Type H
Hunter 25734 doesn't come with light, light was just added, you need a picture of a light or a model number of the light for people to answer your question.
Sep 04, 2015 | Hunter Dryers
Need to change a bulb
If we had your full model number, we could help you more precisely.
The first step is to unplug the oven before changing bulbs!
See a diagram which helps you find & replace many GE cooktop and cavity light bulbs http://031d26d.namesecurehost.com/mwd/ge_lamp_replacement.jpg
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding: http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (or 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Nov 26, 2013 | Microwave Ovens
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
Light bulb
You didn't mention your brand and full model number, so we'll have to give you a very general answer.
A diagram which helps you find & replace many GE cooktop and cavity light bulbs is here http://031d26d.namesecurehost.com/mwd/ge_lamp_replacement.jpg
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Dec 27, 2012 | Microwave Ovens
Replaceing bulb on ceiling fan
Turn off the fan before you climbing the ladder to remove the dead bulbs
  • Note whether a screw secures the shade or if the lightbulb holds the shade in place.Unscrew the lightbulb counterclockwise. If the bulb is securing the shade, grasp the shade with one hand while removing the bulb.Install the new lightbulb by turning clockwise into the socket. If the bulb holds the shade in place, keep the shade in position with one had while screwing in the bulb with the other.
  • ceiling light
  • May 15, 2012 | Hampton Bay 24002 Ceiling Fan
    Changing third brake light bulb
    just pull back on the deck cover on both sides and it just slips off. Then turn the bulb socket counterclockwise 1/4 turn and out comes the bulb - GE 921- is the bulb size. good-day!
    Mar 30, 2012 | 1997 Mercury Cougar XR7
    How to change bulb in fridge
    To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement center. Insert the new light bulb and replace the cover. If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair center that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
    Jul 04, 2011 | Whirlpool Refrigerators
    How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
    That's covered on pages 35 & 36 of your owner's manual.
    If for some reason you don't have yours, you can download it here.
    Cooktop Light/Night Light
    On models JVM1850, JNM1851, DVM1850 and
    EMO4000, replace the burned-out bulb with a 120 volt,
    40-watt incandescent bulb (WB36X10003), available
    from your GE supplier.
    On models JVM1870, JVM1871, JVM2050 and
    JVM3670, replace the burned-out bulb with a 120 volt,
    20-watt halogen bulb (WB36X10213), available from
    your GE supplier.
    To replace the bulb(s), first disconnect the
    power at the main fuse or circuit breaker panel
    or pull the plug.
    Remove the screw at the left edge of the light
    cover and push on the right edge of the cover
    to open.
    Be sure the bulb(s) to be replaced are cool
    before removing. After breaking the adhesive
    seal, remove the bulb by either gently turning
    (for models JVM1850, JNM1851, DVM1850 and
    EMO4000) or pulling straight out (for models
    JVM1870, JVM1871, JVM2050 and JVM3670).
    Replace with the same size and type bulb.
    Raise the light shield and replace the screw.
    Connect electrical power to the oven.
    Oven Light
    Replace the burned-out bulb with a 120 volt, 20-watt
    halogen bulb (WB36X10213), available from your GE supplier.
    To replace the oven light, first disconnect the
    or pull the plug.
    Remove the top grille by taking out the screws
    on top of the grille that hold it in place and
    sliding the grille to the left (opening the door
    makes grille removal easier).
    Next, remove the light cover.
    On some models, the light cover is located
    in the center of the top opening. Remove the
    screw that secures the light cover and lift the
    cover off.
    On some models, the light cover is located at the
    left of the top opening. Lift the cover off.
    Pinch the clips that hold the light socket in
    place and lift the socket out.
    Remove the bulb from the light socket by
    pulling straight out. Replace with the same size
    and type bulb, then replace the light socket and
    cover.
    Replace the grille and screws. Connect electrical
    power to the oven.
    Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    How do i change the bulbs on a jvm1870sk03 microwave
    That's covered on pages 35 & 36 of the owner's manual here.
    your GE supplier.
    or pull the plug. *
    to open.
    Oven Light
    GE supplier.
    or pull the plug.
    cover off.
    cover.
    power to the oven.
    * If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
    Apr 25, 2010 | GE JVM1870 Microwave Oven
    Changing light bulb in microwave oven
    If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
    Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
    Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
    Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
    Dryers Logo
    131 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
