Question about HP Photosmart D7460 Printer
Hp d7460 not printing cyan and light cyan
The printer has been in storage for a year as we moved countries. I am trying to use it again, but it is not printing cyan or light cyan despite having put new cartridges in. I have tried "cleaing the print heads" and "Alignment", but the only colours that appear on the "Self Test Report" are black, yellow, light magenta ( very grainy) and magenta ( very grainy). Any help would be appreciated, thanks!
JayBlair
  • 328 Answers
SOURCE: Print Heads
Make sure the printheads are not expired. Check the dates. Order new from HP direct
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 02, 2007
  • 238 Answers
SOURCE: HP Deskjet 5150 won't print black
ya hi, the nozzels must have got dried up and choked, put a few drops of hydrogen peraoxide on the nozzel for some time and then clean it, this will free the pores in the nozzel, be careful with the chemical, or take some proffessional assistance.. let me know
Posted on Dec 16, 2007
websnail
  • 419 Answers
SOURCE: printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
Posted on May 28, 2009
SOURCE: my hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
Posted on Jan 04, 2010
seeker5211
  • 1089 Answers
SOURCE: My HPLJ3500 Color Printer wont print black even
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Posted on Jan 11, 2011
On my Photosmart D7460 HP printer, the error code 0005FBB6 keeps coming on the screen saying that I have not powered down properly... not allowing me to print and setting off all sorts of flashing...
1) connect printer directly to wall
2) try different walloutlets
3) unplug the power from the back of the printer and then press and hold down the power button for 30 sec release the button. plug in the power chord..
4) if it does not work service the product
Mar 26, 2011 | HP Photosmart D7460 Printer
I have a HP photosmart D7460 printer,when I bought it it had all the ink cartridges with it.After first install it told me that Cyan & light Cyan were missing & Black was incompatible as it worked...
you are lucky to have use the cartridges of your printer for 19 months. In my office experience, I am actually replacing the cartridges of my printers within a year. Just a regular life span of an ink refilled cartridge.
May 17, 2010 | HP Photosmart D7460 Printer
Can not get printer to print keeps saying that it is idle in the que
Hi Pull the power cable. And leave out for 1 minute it should reset to default factory settings.
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and yourprinter has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe MagicInkjet Flush kit to soak the print head and you should beprinting again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Also this may help...
HP 145 Sequence HP D145 all-in-one printer
http://magicinkjetflush.com/images/PDF/HP_135_Sequence.pdf
or smaller file
http://magicinkjetflush.com/images/HP_135_Sequence.jpg
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | HP Photosmart D7460 Printer
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
I have a d7460 hp printer and the magenta ink cartridge is empty, but I need to print something very important by tomorrow morning and it won't print. It says that it's "unhealthy" to print in...
From your printer properties, go to the "Printing preferences" button on the "General" tab. On the "Color" tab, select "Print in grayscale". That should take care of it for ya.
Apr 21, 2009 | HP Photosmart D7460 Printer
How to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Mar 22, 2009 | HP Officejet 5610 All-In-One InkJet...
HP D7460 printing blank pages, no error message
Just needed to be unplugged (both at wall and at printer) for two minutes. Restarted and it worked fine.
Nov 22, 2008 | HP Photosmart D7460 Printer
HP Photosmart D7460 won't print
Did they suggest uninstalling it from device manager, completely and downloading the new vista driver fo your printer off the HP website??? and then installing this.
Feb 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP Photosmart D7460 Printer Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
