Question about Refrigerators
An automobile maker has an order for 7,500 new cars to be delivered in one week. Each car must be fitted with a new hood ornament that requires 1 hour and 15 minutes to install. Assuming the factory operates on a standard workweek shift (8 hours per day for 5 days), how many workers must be assigned this job to meet the deadline?
3 Suggested Answers
SOURCE: engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Posted on Oct 24, 2008
  • 234 Answers
SOURCE: Electric Water Heater Using Too Much Electric.
Maybe you want to think about getting a tankless heater.The gad unit works real good.But the electric water heater i want to think you should check the thermostate.Maybe it is struck and not cutting off every time.
Posted on Mar 14, 2009
Technika T888VGX/1 will not power up
Indoor fittings
Pedal can change nacarat, become grass blue, alternation in white with red; Hand in head placed on metal, change leather packaging, change crystal bright; Supply the car door plank give a decoration bar, wheel to include a set of... The automobile can ornament accessories also really many, the master can in accordance with a common style, color, pattern, choose a few to interchange accessories, for that "hideaway" while using the ornament of warmth.
Aug 21, 2012 | Televison & Video
An automobile maker has an order for 7500 new cars to be delivered in one week. Each car must be fitted with a new hood ornament that requires 1 hour and 15 minutes to install. Assuming the factory...
Jun 14, 2012 | Refrigerators
How many miles before my car to change oil
Every 6 months, or every 7,500 miles if you use your automobile for normal transpiration. If you do a lot of hauling, racing, or anything or drive a lot of miles on it. Then its suggested that you do it ever 3 months or 3,000 miles. what ever comes first.
Mar 09, 2011 | 2008 Dodge Caliber
How to install a hood ornament without the mounting holes in the ornament
use double sided tape. recommend 3m tape.."gorilla glue" makes a really good double sided tape. make sure you clean both car and ornament with alcahol where ever the tape is going to be. or you could use hi-temp high strength hot glue.
Apr 07, 2010 | Lincoln Continental Cars & Trucks
How do you replace the hood badge? 98 BMW Z3
Allow some warm water mixed with dish soap to penetrate around the edges of the old ornament. Gently slide a pry tool into the top or bottom center. The hold downs (plastic clips that SHOULD pop) are going to be on the left/right middle. While continuing to pour some warm water and dish soap around the pry point, work the pry tool around the circle. If you don't have a pry tool, use a non-ridged butterknife wrapped in electrical tape. It will take some force to remove, but it will come out.
Please note, you CANNOT re-use the clips. Your new hood ornament should have some with it.
Remove ALL old adhesive from the paint surface so that the new ornament will go on smoothly. Best of luck!
Mar 08, 2010 | 1998 BMW Z3 Roadster
How do I get the "standing star" hood ornament off? Need to replace it.
After you buy the new ornament, to take the old one out, get a small phillips head screwdriver and a big, soft rag. Basically, you just use the rag to keep from scratching the paint on the hood as you work the screwdriver (may be easier with two) underneath the ornament, and slowly work it up enough that it just pops right out.
The ornament has two posts at the 3 and 9 o'clock position. Work evenly at these two points.
check it then rate it
Jan 09, 2010 | Mercedes-Benz E350 Cars & Trucks
Need a manual .
moz-screenshot.jpgProcter Silex will send you a new one for $3.50. From http://www.proctorsilex.com/contact-us.php:
If a use and care booklet for your Proctor Silex appliance is required,send a $3.50 check or money order (reprinting charge) and a brief noteincluding your name, address and model number to:
Hamilton Beach Brands, Inc.
360 Page Road
Washington, NC 27889
Your booklet should be delivered within two weeks.
Jan 25, 2009 | Toastmaster TBR20H Bread Maker
Hood emblem installation
Just put the replacement hood ornament in the hole and use a pair of pliers to pull down and turn the lock 1/4 turn clockwise. It is spring loaded and if you look real close at the ornament you will see what piece to pull down and turn. Right now it is locked in its shipping spot.
Jul 30, 2008 | 1989 Mercedes-Benz 300-Class
How to replace hood star?
it is very easy, open hood, locate hood ornament,with a pair of pliers twist of to the left like if you were unscrewing a screw,and vise versa when installing new one.
ABOVE IS A FUKIN LYE. IF YOU DO THIS YOU R DAMNAG YOU CAR FOR GOOD AND NEVER FIX IT. THE ONLY WAY DOING THIS IS BUY MY CD ON ELECTRONIC BAY (EBAY) AND YO U SEING HOW MY PROFESSION DO IT YOU EBAY FOR BENZ ORNAMENT AND YO U BY MY CD OR ELSE YOU NEVER DO IT GOOD
I believe the original answer is correct. That being said, who the hell would take advice from the ignorant, obscene, can't spell or write English person who replied who is trying to sell something on eBay. Absurd!
Actually, the ignorant nut case with the obscene language who cannot spell or write English is partly correct; you must compress the outer shell with the pliers (preferably channel-locks) and turn it 1/4 turn counter-clockwise (to the left) so that the outer shell lines up with the release cuts in the hole in the grill. Once the shell is lined up properly, the ornament will slide straight out the top. Be careful that you guard against sending the old ornament mount out the top and over and down your nice Mercedes hood; that could cost you some cash to buff out the scratches! As for buying the nut case's CD, I'll leave that up to you.
Jun 30, 2008 | 1992 Mercedes-Benz 190
Refrigerators Logo
216 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
