Question about Sorelle Baby Gear
Need Replacement Allen Head Bolts For A Toddler Bed
I have a Sorelle Riga Toddler Bed. I also have the instructions, but they do not have the bolt sizes on them. I am looking for help finding the size of the (b) bolts on the instruction sheet.
5 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: Changing crib to toddler bed
Is that the exact model/maker of your crib.. If not, may i know the exact details please..
thank you
Posted on May 31, 2008
SOURCE: Vicki 4 in 1 Convertible Crib......
Nevermind........... I think I found the soloution
they included the wrong instructions with my crib. They included the instructions for an old model
i need to get the toddler attachment because it supposedly has legs
will order it and hope it does what they say it will
** fingers crossed
Posted on Mar 24, 2009
wwjdcgh
  • 114 Answers
SOURCE: bolts needed
either home depot, lowes , or true value hard ware
Posted on Mar 28, 2009
SOURCE: Need assembly instructions and bolt sizes for a twin over futon bunk bed
Can you find out the make of the beds?
If you can look it up on the internet and order the correct sized bolts.
IKEA is easy.
kolbrun
Posted on Feb 14, 2012
thank you
May 31, 2008 | Sorelle Vicki
How to convert sorelle tuscany crib to toddler bed
the above solution is useless as there is not toddler kit instruction at the site, is there anyone that has done this?
Nov 09, 2012 | Sorelle Tuscany 1050 Crib
I need to convert our sorelle tuscany convertible crib to a toddler bed and lost the instructions. how can i get a set of instructions?
http://www.sorellefurniture.com/instructions.php
Not sure what model yours is, but that's their site for instructions.
Mar 14, 2011 | Sorelle Tuscany 1050 Crib
I lost my manual, I need to know how to transform the crib into a toddler bed
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
mkd123_2.jpgGraco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
Jan 23, 2011 | Simplicity for Children 4-in-1 Convertible...
How do I convert from a crib to a toddler bed? Do
It is very simple to convert a crib to a toddlers bed. You just need to remove the side railings by folding them under the bed. It would be automatically converted to a bed that a toddler can use
Mar 03, 2010 | Sorelle Regal 310 Crib
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Vicki 4 in 1 Convertible Crib...... IS NOT ABLE TO CHANGE INTO DAY BED OR TODDLER BED! I was shocked to learn this weekend when I went to convert my sons crib into a daybed that it can't be done. My crib...
** fingers crossed
Mar 23, 2009 | Sorelle Vicki
Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
Sep 23, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Baby Gear Logo
320 people viewed this question
Top Sorelle Baby Gear Experts
Jeffrey Turcotte
Jeffrey Turcotte
Brett Duxbury
Brett Duxbury
Tom Chichester
Are you a Sorelle Baby Gear Expert? Answer questions, earn points and help others
