Question about Panasonic Heating & Cooling
R410 what is the maximum psi in inverter split air conditioner?
How to charge inverter spilt air conditioner?
SOURCE: spilt air conditionerl
Hi deabreu5. I have a spare remote for the fujita split system model: KFR I also have the instruction booklet but no manual.
Mine lasted for 3 years and no cold air comes out anymore. I'm going to have a crack at fixing it myself somehow. But a spare remote came in the box so I'll sell it to you if you like.
email me.
Posted on Mar 23, 2008
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
SOURCE: Blueway split system wall air conditioning doesn't work properly.
Hi,I have had problems with my Blueway A/C it was very cheap but NASTY,anyway I might be able to help, I made a website with my manual that includes the error codes that I could not find on the net anywhere ,I have also sourced a company in sydney who has spares and have the contact details listed and started a forum that we can help each other out with
Posted on Apr 05, 2009
  • 832 Answers
SOURCE: need remote for a v-lec split type air conditioner
Why not try the dealer selling V - lec aircon? They are
in the best position to know where to get the replacements or clone remote controller for your unit.
Better still try surfing the internet, V-lec Aircon may have
a web site to service their clients. May this info, help you.
Posted on Jan 06, 2010
I have a trane air conditioner operating at 70psi low side pressure but with little to no temperature on liquid line by condenser but is cold to the touch entering the air handler
What type of refrigerant? R22- 70psi is good/ r410- 70 psi not good. What is the head pressure, is the filter clean, is the coil frozen, is the fan operating properly, all the supply air grills open...lots of things cause funky pressures. Need more info
Apr 05, 2017 | Heating & Cooling
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
Is it better to by air conditioners with R - 410 GAS OR R - 22 GAS
R410 units are cheaper now but not as effecient as R22, also R22 is much more expensive and most likely you would have to use R22 a to recharge unit if it as allowed where you live .
Oct 02, 2014 | Cfm Daikin R410a Split System Air...
How much psi to charge on a split unit which has a distance of 40 meters between the indoor and outdoor unit
the psi of an air conditioner is not 'changed' by the distance of the line set to the indoor coil. the psi will remain constant depending on type of refrigerant used, i.e. R-22 or some of the newer refrigerants.
For example - when using R-22 - the low side will typically run at around 70 psi give or take a few pounds depending on conditions while the high side pressure will be determined (as always) by adding 35 degrees to the ambient temperature and finding the corresponding psi on the gauge.
Aug 06, 2011 | Heating & Cooling
We have LG air con system (hot and cold) coming up with error code CH33. What does this mean?
CH 33 -Excessive rise of standard compressor discharge temperature. If over 105°C check refrigerant charge. Over charged, release little gas still to normal PSI. If condenser full of debris, clean it.
Dec 18, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Our Sanyo split air system does not take out the humidity. What is wrong?
Is it blowing cold air.? Depending on your temp. settings will really control the humidity also . try setting it for 64 and see if that helps
Aug 10, 2010 | Sanyo Split System Air Conditioner
What should the high pressure line read to be fully charged on my RUUD UAKA-042 a/c unit? The specs on the unit has a design pressure of 300 PSI on the high pressure line and 150 PSI on the low pressure...
that is a desing pressure not an operation pressure. opperating pressuers will vary with load so pressure alone will not tell you if you have the proper charge. the proper method is with superheat or subcooling, depending on the type of metering device you have
Jun 26, 2010 | Ruud UAKA042 Air Conditioner
Brand new equipment compressor work 5 minutes,
sounds like your slugin oil back to compressor and its over working itself especially cause you have low amprage,you need to pull a vacum on the systemm and bring it down to -25 psi and hold that vac.charge for a good 2 or 3 hrs and then recharge with new freon not the freon that was pull out of system,dont flip jug or try to put any liquid in even know the system will act like it wants liquid just add the gas slowly and it will eventually recoop it charge and amprage should rise to 8.9 to 9.2 depending on the outside temp.note: if this unit is under warranty by manufacture they should replace it due to the fact of a brand new unit that has never ran properly since installed call manufacture for complete waranty details heres the basic warranty this unit comes with and phone # - WARRANTY
Labor Warranty Limited 1-year entire appliance
Limited 5-year sealed refrigerating system Parts Warranty Limited 1-year entire appliance
Limited 5-year sealed refrigerating system Have more questions? Please contact 1-800-626-2005.
hope this helps
Sep 28, 2009 | GE Quiet-Aire Ductless Mini Split System...
Heating & Cooling Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
