Question about Chevrolet 1972 Blue & White Chevy Pickup Truck Diecast Model Truck
Fuel guage problem
1980 chevey pickup truck fuel guage dos'nt work I think its wiring
  • 508 Answers
CHECK THE SENDING UNIT FROM THE FUEL TANK. GET A "D" CELL BATTERY AND CONNECT THE WIRES FROM THE SENDING UNIT DOWN BY THE FUEL TANK. ONE WIRE TO THE POSITIVE END AND THE OTHER TO THE NEGATIVE END OF THE BATTERY. HAVE SOMEONE IN THE CAB VERIFY THAT THE FUEL GAGE MOVES. IF IT DOES THEN YOUR SENDING UNIT IN THE FUEL TANK NEEDS TO BE REPLACED. THIS IS A VERY COMMON PROBLEM AND AN EASY FIX.
Posted on Jan 24, 2009
My 1997 s10 truck fuel guage does not work
If it was working before , drop the tank again low enough to check your connections, if ok, remove the assembly out of the tank and inspect, with the unit out, hook the wiring back up, turn the key on and manually swing the float and have someone watch the gauge.
Jan 05, 2014 | 1997 Chevrolet S-10 Pickup
My 2006 ford explorer displays low fuel level n the fuel gauge does nt move or work even when there is full tank of fuel
make sure the sender is grounded or your guage wont work at all..there should be a ground wire .. if not add one someplace..
Dec 26, 2013 | Ford Cars & Trucks
2008 gmc fuel pump works, sometimes it dos'nt
Check any fuel pump relay and replace.
Retry.
If no luck, then you may have a faulty fuel pump.
Nov 12, 2012 | Cars & Trucks
Fuel light stays on after filling and fuel guage does'nt move
sounds like the sender in the fuel tank as it works both.
May 30, 2011 | 2001 Volkswagen Beetle
Fuel guage stopped working?
it's either the gauge or the sending unit in the tank. I would wager that the sending unit is bad in the tank, or the wires leading to it.
It's possible the fuel gauge itself is bad, but try the fuel tank first.
You'll have to drop the fuel tank to access the sending unit.
Jul 10, 2010 | 1983 Volkswagen Rabbit Pickup
I have a 93 toyota pickup . alternator wiring ??
the thicker red wire connects to the (BAT) and the other is the ground
Mar 13, 2010 | 1993 Toyota Pickup
Fuel gauge does not work checked fuses none bad
first start with the cheapest parts like the guage itself.may need replacing.if thats not it could possibly be a wiring problem.also check the float in the fuel tank.
Dec 01, 2008 | 1994 Mazda 2WD B Series Pickup
Need to fix the gas guage on a 1980 jeep cj5.
You have one of two possible things that are not working. The sending unit in the tank may be bad, or the gage in the dash is not working. Use a "C" cell battery and hook the wires to the gage in the dash to the battery ends. If the gage moves the guage is good. If that is the result then you will need to replace the sending unit in the fuel tank. That will require removing (dropping) the fuel tank to gain access to the sending unit.
Aug 03, 2008 | Jeep CJ5 Cars & Trucks
My car it dos`nt start the fuel is not runing....i think is the fuel pump that is not pumping the gas
check all battery cabels rust or molded, if uit is you need to clean up , make sure yuo doing deep clean and start check again.
Jul 25, 2008 | 1998 Dodge Caravan
Chevrolet 1972 Blue & White Chevy Pickup Truck Diecast Model Truck Logo
576 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
Maxumized
jogp98
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
