O want to install a new key . What are the steps ,please
  • Computers & ... Master
  • 27,725 Answers
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
b>
Posted on Jan 16, 2013
I have a proscan tablet and my granddaughter entered a password and forgot what it was...how do i unlock tablet now?
In your situation ,you can use a third-party software.I recommend one to you -Windows Password Key.Here are steps that you can follow:
Step 1: Download and install Windows Password Key in another accessible PC.
Step 2: Run the downloaded file and install it.
Step 3: Burn a reset disk with Windows Password Key.
Step 4: Remove the password with the burned disk.
Any question please refer to Windows Password Key
Mar 03, 2014 | Samsung Televison & Video
I reecently installed at&t fast access dsl on my desk top computer and installed the Westell router that came with it. I have a new dell laptop I want to add to this wireless router. Dont know much...
HI,
Can you please tell me which wireless router you have so that i can give you the manual for that model and your problem will be solved.Everything will be explained step by step in the manual with the diagrams.
Goodluck,
Please don't forget to rate the solution.
Apr 07, 2008 | Computers & Internet
How to format windows XP from CD
Here is The Step By Step Guide to Format or install win xp from a bootable CD
(Warning: Do it at your own risk, Back up all you data before formating the drive.)
Step1-Insert the windows XP cd in your cdrom and than go to the BIOS by hitting "DEL" or "F12? when your system in powering on. Go to Boot order and make sure cdrom is on the first place.
Save settings and restart your computer.
Once you have successfully booted from the CD, you will see the Windows XP "Welcome to Setup" screen. Press ENTER to begin the setup process.
Step 2- License Agreement
When it shows about License Agreement just press F8(function key) to accept the agreement.
Step 3: Previous Versions of Windows XP In this step setup will search for existing Windows installations. after search complete will see two option "R for repair or Esc to install fresh copy"
Note:screen will appear only if a Windows installation is already exists on your pc. If you're installing on a brand-new hard drive,you have to skip this option and see step 5.
krbshg_1.gif Step 4:To Continue installing fresh copy
Press ESC. You will be given a list of partitions available on your hard drive.
Step 5: Partitions If there are multiple partitions on your hard drive, or you have multiple hard drives in the computer, use the UP or DOWN arrow keys to choose your install partition. Please note that your system partition needs to be a primary partition (usually the first partition that shows up in the list), not a logical partition.
The partition should be at least 10 GB in size. Make sure that all the data you need from this partition is copied elsewhere, because it will be deleted.
Once you have selected the right partition selected, press ENTER. You will see the next "you already have a system installed" screen only if you already have Windows installed on this partition. If you are installing on a brand-new hard drive, skip to Step 7.
Step 6: Continue Installing On The Selected Drive Press C to continue. You will be given a list of install options
krbshg_5.gif Step 7: Format The Selected Partition Select the option to "Format the partition using the NTFS file system (quick) and press ENTER.You will receive a warning about formatting the drive unless the drive is brand-new.
krbshg_6.gif Step 8: Continue With The Format Press F to continue formatting selected partition. If you still haven't backed up, this is the last change to backup your important data, after this step you will not to able to go back and restore your data.
krbshg_7.gif Step 9: Copying Files After the format setup will automatically copy files and restart your computer. Go to BIOS and remove cdrom from first boot device. Start your computer.
krbshg_8.gif Step 10: Automatic Installation After RestartSetup will continue to install after the restart. it will ask you for the product key and user name etc. Fill the forms yourself.
Jul 10, 2011 | Computers & Internet
I had got my comp formated once befor with windows
I will be happy to assist you with your problem
To format your computer back please follow the steps given
  • Backup. Just to be on the safe side in case you find that you have made a mistake of forgot to save something, you should always backup your data before formatting or wiping your disk clean. You can either copy your data files on to a CD or a flash drive or another hard drive.
  • Step 2 Restart. Shut down your computer and hit the appropriate key to go into your BIOS. A message will appear as the computer starts up telling you which key to hit to enter the BIOS (sometimes called Setup). Once in the BIOS, you need to go through the different sections until you find one that says something like "boot device order". Once in this menu use the appropriate labeled keys to select CD-ROM as the first boot device. Exit the BIOS and be sure to select save by pressing key f10. If your computer does not restart, please restart it again with your Windows XP CD in the CD drive.
  • Step 3 Start the setup. After Windows starts up it will display a message that says "press any key to boot from CD", press any key. Windows will start to load files and then will take you to a screen that asks you to install Windows or repair; press the "Enter" key. Press the "F8" key to accept the licensing agreement. If a Windows installation is detected it will prompt you to repair, just press the "Esc" key. Select the existing partition and press "D" to delete the partition. You may have to press "Enter" and then "L" to confirm that you want to delete the partition. The screen will then list the open partitions to create a new partition. Hit the "C" key to create a new partition where the previous one existed. The setup will ask you to pick a size for the new partition, it will automatically list the largest possible size. Hit "Enter" to accept this size. On the next screen, Windows will ask which partition you want to install Windows on. Pick the partition you just created. The next screen will offer several options to Format the partition. Select one of the options and hit "Enter".
  • Step 4 Install or restart. After the partition is formatted, you can install Windows again or you can turn off the computer and remove the CD. Your computer is now formatted. Go back to your BIOS and change the boot up order to hard drive first.
Thanks
If you need any further assistance please feel free to contact me again.
May 15, 2010 | Computers & Internet
How do I turn web cam on?
Go to quickplay an then choose the second icon and it'll open a window. At you left you'll a list of application wher you'll find "webcam" and that's it.
Another thing is the problem with this cameras an the windows vista: using messenger or skype sometimes appears a sign that says "it's on use"... so then try this:
Step 1: We need to enable the Windows Image Acquisition Serivce. Here are the steps to enable the Windows Image Acquisition service.
1. Tap Window key (flag key on the keyboard) and R key on the keyboard, at once.
2. You would see the Run window on the screen.
3. Type SERVICES.MSC and hit enter.
4. You would see the services window on the screen.
5. Double click the "Windows Image Acquisition (WIA)" service, and under the startup type select Automatic.
6. Click on "Start" button if it is stopped under Service status
7. Click on Apply and Ok.
Step 2: We need to uninstall the webcam drivers. Here are the Steps Uninstall the Webcam drivers from the device manager.
1. Click on start and click on Control panel.
2. Click on "the Classic View" on the top left side of the control panel.
3. Double click on the "Device Manager" icon in the list.
4. Click on + next to the Imaging devices. Now you would see one HP Pavilion webcam or more then one web cam listings under the Imaging devices.
5. Right click on each HP Pavilion web cam and click on uninstall. And confirm un installation if it prompts. (Click on Yes.)
Please do not restart the notebook if it asks to restart the notebook. As we need to download the Latest driver for the webcam. However, please do not install the webcam drivers right away. As we need to install the webcam after restarting the notebook.\
Step 3: download the Latest drivers for the Webcam (it's on website). Please Save the files on the Desktop. Do not install this file right away. We need to install it after restating the notebook.Once you download the file, you need to restart the Notebook. Double click on the downloaded file(ex: sp34746.exe) and follow the on screen instructions to install it. After you complete the installation, please restart the notebook once again.
Step 4: We need to reset the Bios after reinstalling the webcam drivers. Here are the steps to Reset the Bios.
1. Restart the notebook.
2. Tap the F10 key as soon as the HP logo appears.
3. Using the arrow keys, navigate to Exit Menu, select "Load Setup Defaults" and select "Exit Saving Changes"
Step 5: If the issue still persists, you need to reinstall the Bios. You have it also on the website. And then flash the Bios.
Dec 02, 2009 | Computers & Internet
I was trying to install my new Di 524 and forget the keys
From the DLink website:
Reset to default settings print.gif The following reset procedure will completely restore the default settings on the router including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the router powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
The default username is admin and leave the password blank.
http://support.dlink.com/supportfaq/
Mar 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Network key
Hello Karlallen:
Unfortunatly if you did not write down the key when you did the initial installation...there is no way to retrieve it. What you must do is reset your router and then re-assign a new key.
Be sure and write it down in a safe place in case you want to add additional computers.
Good luck to you my friend.
Seek PC Repair
P.S. Please let me know if you need step-by-step instructions on re-configuring your router.
Feb 12, 2008 | Linksys Wireless-N WRT150N Router
Black screen
If one of these solutions doesnt work you will most likely need to purchase a new calculator.
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 12, 2008 | Texas Instruments TI-83 Plus Calculator
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
