Question about Hisense Televison & Video
No signal the word component comes up
Can't turn on tv says no signal then word component comes up
    Top Expert:
  • Hisense Master
  • 74,106 Answers
Check its tuner. It is faulty.
Posted on Jan 16, 2013
When I turn my TV on, it comes on and says 'no signal' then after about 5 seconds, automatically switches its self off... any idea why?
Most sets will shut down very fast if no signal at all.
If you can before it shuts off try to change input to one of the rear audio video inputs that has something connected to it and turned on.
Failing there and if using a box of some type for signal--unplug it and the set both for a while---plug back both and let each try to boot up.
A total loss of signal or a glitch with the set or a box can confuse the TV set's Microprocessor.
May 30, 2012 | AOC L32H961 32 in. TV
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
My xbox 360's wires are all plugged in the correct places and other people can see my xbox profile when i turn my xbox on but on my component source on my tv it says no signal so i can not get a...
If you have the AV cable that has the switch on the Xbox end, make sure that it's in the correct setting. Your cable could have shorted out if this does not work.
Aug 17, 2011 | Microsoft Xbox 360 Console
I have an Acer one aspire but cannot link this to my HD tv, I have bought a VGA to component cable but it will not display image even though I press the FN key and F5. it works on a smaller TV via VGA to...
A VGA to Component cable is used only in special monitors - it won't work on tv's because the signal is completely different between them and the tv can't decode it: in the VGA you have an RGB signal with separate synchro while in the Component you have a Luminance signal with integrated synchro and 2 colour difference ones. So a converter is mandatory , one like
http://www.electronicsshowplace.com/hdmi-converter-p-251440.html
Aug 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
WE ARE TRYING TO GET TELEVISON RECEPTIOB BUT WE GET "NO SIGNAL INPUT COMPONENT 5 AND THEN IT POWERS OFF". WE HAVE A PIONEER PDP 425 MX. I HAVE TRIED TO USE ONLY INPUT 4 BUT TV WILL NOT STAY ON...
The reason your tv is powering down is that it is not receiving an input signal on the channel (input). basically you don't have anything plugged in and turned so the tv doesn't see a signal on component 5 so it shuts the tv off. turn on your TV and hit the input button until you get to the input that you are have a device installed on. just make sure the device you are trying to see on the tv is turned on prior to turning on your tv.
If you do not have an and device plugged in (cable or other input device), plug something in to an input and turn the device on so a signal is being sent to the tv and then turn on your tv and change the channel to that input.
if you are locked on input 5, install and turn on a device to that input so the TV registers it as an active input.
Jul 02, 2011 | Televison & Video
I cant keep my tv turned on after i pushed the rgb button by mistake it keeps on displaying no signal and then it goes off
Turn on the TV again. You need to change the input from RGB back to cable or HDMI or Component or whatever input you have a source for. If you don't know which one, look at the back of the TV and the wires you've got plugged into it.
If it's 1 round coaxial cable, change the input to Cable.
If it's three wires (red, white, and yellow) change the input to A/V.
If it's 5 multicolored wires, change the input to Component.
If it's an HDMI cable, change input to HDMI.
If you cannot change the input before the TV turns itself off, try unplugging the TV from the wall socket for about 10 seconds, and then plugging it back in. If its still on RGB, you're going to have to either find a way to get faster at switching inputs, or find an RGB cable and something to connect it to your TV. This is a last resort however.
Jun 09, 2011 | Televison & Video
Tx-sr606. Signal lost to TV on HDMI Out. Coming in from Component Video or DVD or Game Components. Audio is playing but I get no signal to TV. HDMI Cable is fine. usually have to turn it off or unplug...
Check the most popular solutions.Also check that if you give the receiver some time (in my situation at this moment about 10 minutes) after you turned it on an selection of source.
I just received the new capacitors from a German store and will install them 2 weeks from now.
Rgrds,
Phil
Jan 25, 2011 | Onkyo TX-SR606 Receiver
Just bought a 42" panasonic
On your remote, click menu, then setup, then external devices, then input labels. Here is a link for manual:
http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX80U
Dec 09, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Televison & Video Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
