Question about Hoisting
What are the advantages of a wire hoist over a chain hoist?
  • 75 Answers
Chain hoists are heavier, and are more susceptible to rust, although wire hoists can also rust
Posted on Jan 16, 2013
Looking for a parts list for a Dayton 3Z372b electric hoist.
Dayton Hoist Parts - Ace Industries, Inc.
https://www.aceindustries.com/m-53-dayton-hoist-parts.aspx
Dayton Hoist Parts Online. Certified OEM DaytonParts in Stock Helpful Diagrams to Find Parts Fast. ...Dayton Electric Chain Hoist Parts. Basic Hoist(Figure 12) ...
[PDF]Dayton® Electric Chain Hoists - Ace Industries, Inc.
www.aceindustries.com/pdfs/Dayton/DaytonElectricChain-JLCManual.pdf
Dayton electric chain hoists are rugged, portablehoists that provide quick, precise ... Other features that ensure the safe operation of Dayton electricchain hoists.
Dayton Hoists Online - Ace Industries, Inc.
www.aceindustries.com/m-52-dayton.aspx
Coffing hoists and the Grainger Dayton electric hoists are the same identical units. The only
Apr 19, 2016 | Dayton Heating & Cooling
How to take an motor out of an 1976 Minnie
You need to take off the bumper and the door that covers engine access. You'll need a low boy engine hoist. Take out the radiator and push aside the AC condenser and oil cooler. Take off the fan blades from the watre pump pulley. Find a good place to hook up the chain on the hoist. Now go under the engine and remove the access cover on the bell housing. Take out the bolts that hold the torque converter to the flywheel. Now go after the bolts that hold the transmission to the engine. Put a floor jack under the transmission so it wont drop when you jack up the engine with the hoist. After you remove all the electrical wiring from the components on the engine remove the bolts on the motor mounts and raise the engine with the hoist . Pull the engine out while looking for anything that you didn't disconnect. Be sure the transmission doesn't drop when the engine separates from it.
Sep 30, 2014 | Cars & Trucks
Hpw do I remove 216 motor from my 1950 fleetline
first thing to do is remove the hood,next disconnect one of the battery cables,( I assume you have a chain hoist or a portable hoist)
if you don't have you can rent one for so much a day. make sure you put pulling chains on the motor, you will probably have to take off the valve cover when you get that done remove two head bolts, one at hook the chains through the head bolts, now make the chains are taught front of the motor and one at the back. now on each side of the motor (lower part of motor) you will fine the motor mounts, make sure you don't have the chains to tight just snug, when you have the motor mounts bolt loose, not taken clear out. You will to disconnect the drive shaft from the truck, I think it will a 7/16 or a 1/2 inch bolts you have to remove, another thing , have a pan ready because the transmission oil will leak out the tail of it. ok here we go,find the tranny mounts and remove the bolts(be darn careful under there. something I did not mention before, make sure you remove the radiator and of course all the wires and fuel lines oil lines,etc.I hoped I helped have a happy thanksgiving.
Apr 20, 2014 | Chevrolet Impala Cars & Trucks
Are wire hoists as strong as chain hoists?
Wire hoists are as strong and in some cases can be stronger even than chain hoists being able to lift between 1/2 up to 80 tons.
Nov 21, 2013 | Hoisting
Are there automatic chain hoists or are they all manual?
There are a lot of automatic chain hoists and you will find that they work much faster and with less effort than manual ones.
Do i need to remove the engine from the car to change the timing chains
no you dont need to remove engine. but you have to engine hoist or chain hoist support engine because you have to remove front engine mount to remove timing chain cover.
May 20, 2013 | 2001 Nissan Altima
I can't find information on my chain hoist anywhere. what are some other names for the chain hoist?
the manual chain hoist can also be called the chain block, block and tackle, hand chain hoist, or manual chain block
Jan 16, 2013 | Hoisting
Can i possibly pull a 3.4 out the top from a 2001 olds sillouette van, i pulled one from a 2003 dodge caravan, it was tough but it worked. can it also be done in the olds. i dont have a hoist or accsess to...
Its going be tough to pull out anything other than a small 4 cylinder without a hoist. You could use a comealong. Its like a small hoist, has a chain and a lever you can use to lift the engine. It has a hook on it to allow you to attach it to something.
But to be able to use it you need to put the car underneath something that is sturdy enough to support the weight of the engine, like a large limb on a tree or a metal frame of a garage or something like that.
And you will need a sturdy chain. The bigger the better. Attach the chain to your engine lift hooks.
Get some grade 8 screws,nuts and washers from home depot. Get the largest diameter screws that will fit through the links of the chain. Make a loop on each end of the chain by putting the screws through links and tightening the nuts on the screws. Put the loops you made on the engine lift hooks. Attach the come along to the tree or whatever you can find thats sturdy enough to support the weight of the engine with another chain. Then lift the engine out.
you will have to detach the ac compressor and power steering pump and tie them out of the way with pieces of wire. That way you wont have to discharge the ac system or drain the power steering fluid. Remove coolant hoses and fuel lines. And remove the half shafts for front wheel drive. Then detach the motor mounts/transmission mounts. Of course, theres a lot of other stuff you need to detach, but im sure you know that already.
You can rent engine hoists for like $35 a day from a Taylor Rental or other equipment rental
company. Rent it one day and take it back and rent it another day when you are ready to
put the engine or another engine back in.
Sep 14, 2011 | 2001 Oldsmobile Silhouette
Manual chain hoist keeps slipping load chain when under load (lifting and lowering). It will hold when you keep tension on the slack side of load chain. Any ideas?
sounds if the motor brake is not holding , this is a wear part and will require adjustment/replacement over its life time , the brake is located under the motor cover , but if your not sure what to adjust ,then im gonna suggest for safetys of you and the people around it' s sake you get a profesional to service this hoist
Aug 19, 2010 | Jet Equipment Chain Hoist 1TON 10 Ft Lift...
How to wire
use a wireless controller it will be cheaper and easer http://www.telecrane.com/
the three wires are
x1 constant power
up
down
x1 is connected to the up or down wire to activate the hoist in the desired direction
Mar 16, 2009 | Jet Equipment Chain Hoist 1TON 10 Ft Lift...
Hoisting Logo
913 people viewed this question
Top Hoisting Experts
Andrew Taylor
Andrew Taylor
Jerry Kramer
Jerry Kramer
Are you a Hoisting Expert? Answer questions, earn points and help others
