Question about Home
My upstairs lights are not all working
I have 6 ceiling lights upstairs. The other day the landing light stopped working and I found two bedroom lights also won't switch on. I have checked all the switches and light fittings and they are OK. All the 6 upstairs lights are on one fuse, so it is strange that 3 workand the other 3 lights don't. My neon screwdriver shows there is power to all six lights. I have visually inspected all the cables in the loft, though I can't get at some.. Surprisingly, without touching anything the three lights started working a day later and stopped again after 30 minutes. This has happened twice. The house was built in 1970, but the thought and cost of rewiring is not an option.
  • 3,289 Answers
You have an intermittant connection. This can be anywhere in the circuit - including white neutrals. It can be hard to find because it is intermittant. You may have luck tapping on or around switches, fixtures and outlets to narrow down the location of the intermittant.
You checked the connections - or did you tighten the connections? There's a difference! Every building is subject to vibration. Over time, this vibration can cause connections and wirenuts to loosen. If the wires in the wirenuts were not pretwisted before the wirenut was placed - there may be some intemittant connections going on inside the wirenuts.
Check and TIGHTEN all connections - wirenuts, terminal screws, etc. This includes the neutral wires! Test lamps are really not very good test tools to use - that's why electricians don't use them. Your test lamp cant tell you if it is registering 50V, 120V or 240V. There is a huge difference as you can imagine. Do not overlook the outlets. it is not uncommon for an outlet to supply power not only to the next outlet - but to a nearby switch above it, too.
Get an inexpensive multimeter. It can provide you with more information that you'll ever need as a homeowner. That is much better than the questions a neon test lamp raises.
Posted on Jan 26, 2013
  • John Darwent Jan 28, 2013
    I received a perfect solution 11 days ago. I confirmed this, but all those solutions have disappeared. Steve's solution was therefore not needed, but thanks.
How many wires should there be in a bedroom ceiling light?
hire an electrician before your house burns down. black is hot white should be neutral and green should be a ground. you got problems
Jan 17, 2018 | Miscellaneous
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
I have just purchased three First Alert carbon monoxide alarms. My home has a basement and bedrooms on the first and second floors. My questions stem from the installation. Should the installation...
When I worked Electrical in a Hardware store we were told by Nighthawk and f\First Alert and we told our customers that you want the detectors 4-6 feet off the floor never near a water heater or furnace since this can cause false alarms. The CO will rise, so one on each floor should be enough near a central stair if possible. Other wise make sure at least one is in the bedroom.
Mar 01, 2011 | First Alert CO400 Battery Powered Carbon...
My upstair room light is stop working. Changed bulb, switch and bulb holder. But still no luck. What else I should do before call the an electrician. - Mahen
Hi there,  Have you checked to see if you have power getting to your switch? You could've tripped a circuit breaker, so I would check your electrical first to rule that out. Once you've checked for power, put your switch in the OFF position. Next, take off the light from the ceiling...leaving just the two wire's hanging down and apart from each other. If you have a voltage tester/meter, then you'd want to turn the switch ON again - then check to see if you're getting power (voltage), as well as, a complete circuit. If so, great! If not, contact me again and I'll help you further. But I believe you'll have found the problem already after following the above steps. Make sure to secure each connection when putting your light back up onto the ceiling. And, DON'T turn the switch back on until your light is securely mounted. Good Luck with this, and feel free to contact me again if this doesn't work. - Jim
May 27, 2010 | Cooper Lighting Lighted Switch
Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
May 27, 2009 | Hampton Bay 52 In. White Redington...
Not sure if this is the exact ceiling fan/ light kit we have... but looks similar.
Turned out that it was the dimmer switch that had shorted out.
My hubby figured it out, and replaced it.
Jul 19, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Bought a monte carlo ceiling fan. removed old fan and found 3 white and 3 black wires, plus grounds. Cannot figure out how to connect the unit up. breaker controls all ceiling lights in master bath,2nd...
Try this:
* All 3 black together, with black and blue from fan
* All 3 white together, with white from fan
* All grounds (earths) together, with all greens from fan
Apr 28, 2008 | Hampton Bay 24002 Ceiling Fan
Home Logo
490 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
