Question about Extreme Networks XGM2-2SF 2-Port SFP for X350/X450E/X450A 16114
Ineed to know how can do the configuration of xgm2-2sf in summit 450a
Configure IP
If you are a well known person about the configuration of your modem you can reset your modem configuration yourself. But if you are not, go with any experts or technical person or user manual to do it. After resetting it check your IP address using the site Ip-Details.com .
Aug 20, 2013 | Arris Touchstone 450a (CM450) Modem
Do you have to hook your modem to your ps3 to get online
Yes you have to connect the ps3 to your modem unless you have a wireless modem and then you can configure your ps3 wirelessly.
Jul 09, 2012 | Arris Touchstone 450a (CM450) Modem
Vlan trunk on summit 24e2
Extreme uses tagged and I untagged instead of trunk/access, so it would look like this for a trunk:
conf vlan test add port gi1 tagged
(and of course you could put other VLAN's on this same port too since it's a trunk)
conf vlan user1 add port gi1 tagged
and this for handoff:
conf vlan lam test add port fa1 untagged
Feb 14, 2012 | Extreme Networks Summit 24e2 Networking...
I need the wep security code for my sons dsi to download games on it from the internet. router name arris model # cm450a
When you did the initial setup for your router, you should have configured the wireless adapter in the router:
* set a SSID -- the "name" of the network
* set an encryption-level -- hint: use 'WPA' or 'WPA2'
* set a password for your network
It's that SSID/password that you need to enter on the DSI, to make a wireless connection to your router.
Apr 21, 2011 | Arris Touchstone 450a (CM450) Modem
Where do I find the WEPkey for Arris TM502G? The question is posted all over the internet, but no real answers.
The WEP key is a encryption key that is configured in the wireless settings of the wireless router. This setting is then applied to the wireless card in the computer so it can connect to the wireless router.
To secure your wireless network from unauthorized access, please click on this link and follow my instrucrions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 19, 2010 | Arris Touchstone 450a (CM450) Modem
95 Eagle Summit 1.8L cam timing marks
get a repair manual there must be a mark or reference point of some kind
Jul 02, 2009 | 1995 Eagle Summit
One diagram shows cylinder order from front of car 1,2,3,4, all others show 4,3,2,1,...if I knew how to set the valve lash I could figuge it out by the cam lobe placements. The cylinder order for a 1992...
Number 1 cylinder is always the one closest to the timing cover, even if it is a V configuration engine. Your TDC confusion may come from being on the wrong stroke. True TDC for timing purposes, is on the combustion stroke when all the valves in that hole are closed.
Mar 08, 2009 | 1992 Eagle Summit
Extreme Networks XGM2-2SF 2-Port SFP for X350/X450E/X450A 16114 Logo
46 people viewed this question
Top Extreme Networks Computers & Internet Experts
David Payne
David Payne
Are you an Extreme Networks Computer and Internet Expert? Answer questions, earn points and help others
