Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
Modem working, Linksey set but can not get interenal on PC
External modem working, enstalled routr 2nd time with same password but, unable to get on internet per PC
  • 366 Answers
You MUST configure router with instruction supplied by your ISP: PPOE? PPOA? User ID. Password etc...
Connect to router with LAN cable and check configuration with your ISP,
Then follow a check list with this tip to activate your WLAN
Posted on Jan 26, 2009
We have 2 desktop pc's. One in one room and the other in another room on the far side of the house. Both are connected to the same telephone line. The 2wire homeportal 100 hg died and I went to Radio Shack...
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Apr 22, 2017 | 2wire HomePortal 1000HG DSL Modem and...
I have a laptop NEC versa Note serial: 116700069, part no: PC-709HB211552X I want to ask is, why the laptop is not in use to connect to the Internet. I have been using MODEM (local) type CM300 Cheers. if I...
OK when you use external modem you have to creat a new net connection. and there you make it default modem. but follow the. 1st uninstall your external modem, restart, then run external modem set up after a while your system ask for modem that time you connect your modem and follow the instruction. then restart your pc. after that create a new connection point for net connecting and make a default with these modem, restart ur system. after that you can connect your net i wish.
Jan 30, 2010 | NEC Versa Note NB 6/233 (VN230020-000000)...
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.
With an Ethernet cable, connect from the netbook to a LAN port on the 2WIRE modem.
Access the built-in web-server on the 2WIRE modem, and configure the "wireless network settings" to your choice of SSID and network password/passphrase.
Then, from your computer, "View Available Wireless Networks",
and connect to the SSID that you have chosen.
Dec 29, 2009 | Acer Aspire One PC Notebook
Connection issue
Hi! I believe your having some issue with your router and I will be more than glad to assist you in this concern..Time warner cable is your isp and if the computer is connected directly to the modem, you have a perfect internet connection but if you are going to connect the cable from your modem to the router and you connect your computer to port 1 to 4 of your router it will not give u an internet connection. This is what we are going to do.
1. connect your computer that can get an internet connecttion thru time warner cable to the router on port1.
2. pull up a browser and type in the default gateway of the router, to check the default gateway of the router, right click the network icon on the lower right of the task bar and click status and it will show the ip address, subnet and default gateway, ex the default gateway is, u are going to type in the default gateway ip address to the url of the browser.
3. It will ask u for the username and password, by default the username is admin and the password is 1234 or just leave it blank.
4. It will pop up the setup page of the router and you have to look for the setting for doing a mac clone, you need to clone the mac address of your pc that can connect to the internet thru time warner cable modem.
5. once its done, save the settings and on the internet connection settings, manualy configured it to auto-dhcp. save the settings.
6. once its done..unplg the power of the computer, router and modem.
7. cable connection should be, cable from the modem goes to the WAN port of the router and connect cable on port 1 of the router to your computer on the lan port.
8. Plug in 1st the power of the cable modem, once all lights are lit then plug in the power of the router, once all lights are solid on the router, like the power, WAN, u will notice that there is no light on the port1, computer is still off, once the computer is on port1 will lit, then power on the computer..once computer is completely boot up, pull up a browser and it should gives u an internet connection.
9. Once you have an internet connection, u can access again the setup page of the router to setup the wireless connection settings.
10. If you are going to connect another to the existing router that is conneted to the time warner cable. that is possible, but before u connect the 2nd router to the 1st router..
a. connect the 2nd router to a computer to set it have to access the setup page of the 2nd router.
b. once you access the setup page, there is a menu for the lan settings that is for the router side. u need to change the 3 octet of the ip address of the 2nd router. ex your 1st router ip address is and the 2nd router ip address is to change the 3 octet of the 2nd route, the 2nd router ip address should be then save the settings..
c. the router will reboot and need to access the setup page of the router by using the and u can set the wireless connection settings.. once its done..
d. cable connection should be---cable from the time warner cable goes to the WAN port of the 1st router, connect a cable to port 4 of the 1st router going to the WAN port of the 2nd router.. this process is called cascading two routers on a network.. this should work.. good luck
Aug 16, 2009 | ViewSonic (DHWMG120) Router
The internet red light comes on on the d link modem regularly- sometimes for hours, rebooting does nothing often- it was supplied by aol DSL 2640R- I have had it for about six months and gradually the...
hi der... usually this kinda issue most of the time lies with the service provider.. but also to play safe...if can u may try to get another modem to test the connection. well internet light turns red . possible reason :
DSL keeps disconnecting - Frequent intermittent causes ur user id and password to be erased and therefore u need to reboot or may need to configure back
2nd : u may sometimes face night dc , if tats the case its the ISP circuit problem.. ask them to come and change the circuit which gives u intrnet access.
3rd : ur modem unable to save ur configuration ... therefore ur modem mite be at fault
or u can contact the respective modem vendor to check if ur modem is at fault before calling ur isp .. this mite help u pal...
Jul 07, 2009 | D-Link Computers & Internet
Unable to connect Tata Indicom USB Modem on MacBook Pro
insert usb modem -launch system preferencies and click the icon network icon you should see qualcomn cdma...add the following settings
ppp service provider=tata
account name=internet
telephone no=#777
modem=modem au cdma 1x winw01k
vendor=au by kddi
model=wxxx[pc card]
enable error connetcion
Jan 19, 2009 | Apple MacBook Pro Laptop Computer with...
1st time installation: cannot set up the modem properly
If the internet light is red it indicates that there is an error with the username and password
Check the username and password provided by your ISP
If still unable to connect reset the modem and then reconfigure it with the username and password and choose PPPoE connection type.
If still no success contact AT&T tech support to reset the password
Jan 14, 2009 | AT&T High Speed DSL Modem
Unable to connect internet
theres a possiblity that the modem is set to bridge mode,in that way,you will not be able to connect to the internet direclty to the modem, is usually the deault gatewayy address for almost all verizon modem and username is admin and password is admin as well,if admin didnt take for the password,try using password as the password
thanks and God Bless
Dec 10, 2008 | Toshiba WRC 1000 Wireless...
Canot access ADMIN screen
Look on the modem for a reset button, usually one you will need a paper-clip to press. Many modems will have this (not familiar with yours) and will completely reset your modem (IP's, passwords etc)
Jun 06, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
61 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
