Fujitsu F-01D Arrows Tab LTE 10.1 16GB Unlocked White Logo
Posted on Jan 16, 2013
My f-01d fujitsu tab is keep on restarting did not want to open on its own help please
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 23, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
72
Points
I also have the same problem with my tab. It always restarting or shutting down when I turning it on. Please help us. Thank you in advance.
What F? Key do I press to restore my Fujitsu Siemens amilo L7320GW
Fujitsu simens back to factory settings
Downloads & Disks Regarding The Reset Factory Settings Fujitsu Amilo Li 2727
http://www.user-guides.co.uk/download/reset/resetfactory/reset-factory-settings-fujitsu-amilo-li-2727.html
Fujitsu Laptop to Factory Settings
Restoring the factory settings on your Fujitsu laptop is a great way to get rid of files associated with programs that have been removed from your computer that are taking up space and get rid of pesky viruses that you can't remove from your machine by any other means.
Restoring the factory settings on your laptop can also help resolve problems with an unstable laptop.
You should also restore the factory settings on your laptop if you plan on selling it or giving it to a family member or friend.
Restart or turn on your Fujitsu laptop. Press "F12" repeatedly when the Fujitsu logo appears on the screen to be redirected to the Boot Menu.
Highlight "Recovery and Utility" using the arrow keys on the keyboard, then press "Enter."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files.
When the files have been loaded, the System Recovery Options window will be displayed.
Select a keyboard layout, then click "Next." The Operating System dialog box appears.
Choose "Use recovery tools...," then click "Next." If prompted, type your administrator password, then press "OK." The System Recovery Options window will appear again.
Select the "Recovery" tab, then click "Restoring the Factory Image (only C:\drive)."
The restoration process will begin, and the laptop will be restored to its original factory settings.
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen.
Begin personalizing your copy of Windows.
Using Boot Disc
Highlight "CD/DVD" using the arrow keys, then press "Enter."
Place the boot disc that came with your Fujitsu laptop in the optical drive, then click "OK."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files. When the files have been loaded, the System Recovery Options window will be displayed.
Click "Next" when the Operating System dialog box appears.
If prompted, type your administrator password, then select "OK."
Click "Recovery and Utility" when the System Recovery Options window opens, then select the "Recovery" tab.
Click "Restoring the Factory Image (only C: drive)."
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen. Begin personalizing your copy of Windows.
Saving and recovering your factory and system images.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/HDD Restore Generic-Multi-lang B6FJ-3031-03EN-00.pdf
I cant open internet explore and yahoo massenger so please i want delete etype
To remove only eType's promotion link:
Enter eType's Settings window> Advanced tab and uncheck: "Help keep eType free by sharing with your friends".
To uninstall eType completely:
Enter Start menu> All programs > eType folder and you'll find the uninstall link under eType.
For more details and print screen, see Q 5.14 at www.etype.com/help/faq/configurations/
FUJITSU Twain 32 - Code DS42019 Error pops up on screen whenever I try to use my scanner. I have restarted it many times. Any advice?
Here's what I've done. Maybe it's too late to help.
1) install the latest driver
2) restart
3) go to device manager
4) right-click on unknown device and click update driver
5) Select Let Me choose and select an imaging device
6) Click have disk and browse to c:\windows\fjmini and select fi4120c.
7) let it install the unsigned driver
8) You may have to restart after installing
9) Try opening your scanning software and then select the WIA driver for your scanner
I've installed many fujitsu scanners on windows 7 systems
Works perfectly.
My comp keeps telling me to reboot but i dont no
Your computer just wants you to restart it!!Sometimes a restart is needed to complete some updates.Just go to your start button left click,look for the shut down tab,hold your mouse over it and another tab will open in that tab you'll see restart click that.the restart could take a few mins,as it completes some updates.
I hope I've helped..Don't for get to rate this answer.
2answers
Printing problem
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
2helpful
I have a kenwood Excelon XXV-01D that came in the car and now its asking a code ..any help..thanks
you will have to call kenwood tech 1800 kenwood and have them fax you the kcar code you will have to have a remote control to do it
I keep getting the following: Windows must now
in run windows type services.msc and click ok it will open services window in services there are many windows services are there choose dcom server process launcher just double click on it will open dcom server process launcher properties in that go to recovery tab and in recovery choose the option first failure set to restart the service instead of restarting the computer set to all three option second and subsequent failure. And apply it.
Have a nice day and do not forget to rate please...!
1helpful
Need to reattach the W key on my Fujitsu Lifebook P7230
You may have broken a plastic "hinge", more like a tab or clip. Try taking it off again and examine the underside of the key. If it looks ok, try putting it back on. If a plastic tab/clip is broken on the left side, you should be able to go to a small computer repair shop and get a replacement key for it. That way you don't have to replace the keyboard.
2helpful
I have a fujitsu amilo Li 1718 and i cant turn on the wireless conections.
"Fn" + "F2". to switch on wireless
Other solutions are:
The way i get around it is to Hibernate my laptop instead of shutting it down. This makes for a faster startup, saves all your open apps, and ,of course, keeps the wifi enabled.
or
Here is the solution for starting wireless on startup :
go START > run > notepad ENTER
write this in the notepad
Set WshShell = WScript.CreateObject("WScript.Shell")
Set oExec = WshShell.Exec("C:\Program Files\Launch Manager\WisWBSet.exe")
do while WshShell.AppActivate("Wireless Status Option")=False
WScript.Sleep 100
loop
WScript.Sleep 100
WshShell.sendkeys("{TAB}{TAB}{LEFT}~")
and save it as wifi.vbs
put the file wifi.vbs in the startup folder and this will do the job
Hope this helps, good luck
Power jack removal and installation
most laptops use a combination of screws and tab/slots clamping to keep the clam shell halves together. The tabs fit carefully into the mating slots, so it is up to you to find them. Carefully press in on the sides where the clam shell halves mate and find locations where it is more difficult to press inward. This area will be a place where to find a tab/slot mate.
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
