Question about Zebra P330i Thermal Card Printer
How do i calibrate my zebra p33oi printer - Zebra P330i Thermal Card Printer
5 Suggested Answers
  • 3 Answers
SOURCE: My Zebra z4m plus
in the setup menu there is an option to choose what the machine does on powerup and head close. Yours is probably set to calibrate. Just change that setting to "none". Same thing with the pausing. there is a setting to pause after printing each label. Just change that option.
Posted on Jan 27, 2009
Sakeninja1
  • 5 Answers
SOURCE: Zebra 105Se power on calibration
If this unit has the LCD screen you need to Press Setup. Then Press Next till you get to Media Power Up and set it to FEED. Next go to Head Close and set it to FEED also and then save settings. It will only shoot one label out instead of Calibrate. Which is needed when they install new lables if its the same type of label all the time really don't need to Calibrate every time you stick new labels in it.
Posted on Mar 25, 2009
  • 53 Answers
SOURCE: dont want calibrate
turn your printer off then hold down pause and feed while turning it back on and count to 6 and let go of pause/feed
Posted on May 19, 2010
ozztech
  • 285 Answers
SOURCE: ZEBRA TLP28844 PRINTER WILL NOT CALIBRATE PROPERLY
press the butten untill flash 7 times, and relese the button
Posted on Nov 13, 2010
My zebra tlp 2824 won't line up to the labels
Either your printer needs calibrated: Calibrate Zebra Desktop Printer
Or your label template size( in the software) does not match the label size. I recommend the calibration then looking at the software label templates.
Jan 20, 2014 | Zebra Eltron LP 2824 Thermal Printer
Green light red
I would re-calibrate the printer and see if that helps, usually the quickest and correct means to fix ya !
Oct 05, 2013 | Zebra Eltron LP 2824 Thermal Printer
Prints label then prints a blank
This is always a calibration or label template size issue.
Feb 04, 2013 | Zebra Eltron LP 2824 Thermal Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
Dont want calibrate
Check to make sure that the media sensors are properly aligned. Being out of alignment is most common cause of non-calibration on Zebra's. See here for my tip: http://www.fixya.com/support/r4500516-locate_align_media_sensors_zebra_xi
Mar 27, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra S4M label printer
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
Aug 13, 2009 | Zebra S4M Thermal Label Printer
Zebra 170 xi labela are printing on top of each other
Don't forget to rate this.
You can download Zebra manulas from here. https://www.zebra.com/id/zebra/na/en/index/service_support.html here is a section of the calibration you require. Sorry it will not allow me to attach. i think issue with site usage.
Anyway press PAUSE to pause printer. Then find & press CALIBRATION, it will ask when you want to calibrate either at power up or after the print head is open & closed. I would select Power up since when you change lables out you should do so with printer off.
Good luck, post any questions to this & also rate it.
Feb 04, 2009 | Zebra 170Xi II Thermal Printer
ZEBRA P33Oi "WAIT TEMPERATURE"
Have you cleaned the printhead yet? If it is easy to get to. Use some alcohol and cotton cloth.
Aug 09, 2007 | Zebra Eltron P330i Card Printer
Zebra P330i Thermal Card Printer Logo
37 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
