My Crosley Washing Machine is leaking water from the bottom left hand corner downward across the floor...don't know why
  • 15,935 Answers
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My Bosch 300 series clothes washing machine is leaking alot. It leaks during the initial wash cycle from the lower left side. I have cleaned the detergent tray and it appears fine. I have also opened up...
Bosch 300 series This video will show you the 5 main areas to look, the washing machine door seal, the pump, check the drum bearings; look for a split hose, water coming out of the soap draw. This video tutorial will help you find the leaking parts and will also show you what needs to be done to repair it
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 26, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Washing machine leaks at bottom left corner. Water still machine after drain/spin cycyle
My GE washing machine leaks while filling up in the first cycle in the left back corner. Need help!
Jun 16, 2010 | GE Profile WPRE6100G Top Load Washer
Water leaking onto the floor
hat leak may not be in the machine. It may be one of the hoses going into it. Look to find out where the water is actually coming from. If it is a hose from the faucet behind the machine, the hose can easily be replaced at a low cost. If it is only leaking with hot water, check the water inlet valve at the rear of machine where the hoses connect, top left rear facing it. If it is leaking and running down the left side, it is the wrong side for the pump unless it running across the floor and out the left side. If it were the hose, it would leak all the time. It sounds like the hot side has gone bad on the inlet valve. You can save several dollars by fixing this yourself.
Tilt it back and look for two screws, near each corner on the bottom front. Remove these screws and pull the bottom toward you. It should lift off the clips on top. Run the machine carefully, moving parts and see if the leak is actually coming from the left rear and from somewhere up high. First try cold water, then hot. If it leaks on one and not the other, then it is the valve. Be sure to unplug the machine if you decide to change this part. Also you might want to mark where the wires go back to be sure you do not reverse the hot and cold water, as well as fittings and connections. The water leakage evidence should be visible. If not, wash a load and watch for where water leakage occurs. Just look. Do not touch since there will be electrical current supplied.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Drain hose to crosley washing machine, where?
looking at the rear of the washer, my Crosley drain is on the left, about 4" from the floor and about 6" from the side. You might need to remove the back panel. Probably should anyway, so you can blow the dust/lint out of it
May 26, 2009 | Crosley Washing Machines
Crosley Washing Machine leaking
cHECK PUMP AND ENSURE THE PROP CAN SPIN AND THERE IS NO **** IN THERE IF THERE IS CLEAR IT
Jan 24, 2009 | Washing Machines
GE Profile Washing Machine gurshing out water
Open the door and stretch the rubber seal to see if it is split.
It is possible that one of the two hoses feeding the pump have splits in them, only way is to turn power off at wall and with a couple of pints of water in lift machine at an angle prop it with solid objects i.e. wood and squash hoses with your hands MAKE SURE POWER IS OFF AT WALL Tim
Jan 13, 2009 | Washing Machines
Bosch WFCM 3200 Front load washer leaking from bottom of machine
I would try pulling the machine away from the wall and taking the back panel off. Get yourself a torch and then settle down on the floor while the machine runs a short cycle and wait to find out for certain where the water is coming from and at what stage of the cycle the leak happens.
Safety notes: Turn the power off while removing or refitting the back panel. Keep your hands away from wires and terminals when the power is on, and keep your hands and hair well away from the drive belt while the machine is on!
Once you know where the water is coming from and when, it'll be a lot easier to know what to do about it.
A.
May 27, 2008 | Bosch WFMC 3200 Front Load Washer
Neptune washer walking across the floor
Need to know how old your machine is and if it is on a pedestal. What type of floor is the machine sitting on ?
Jan 25, 2008 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
330 people viewed this question
Top Washing Machines Experts
