Question about Hoisting
How often should i clean and lubricate my chains?
  • 75 Answers
Once a year should be plenty, unless you are using it alot, then maybe once every 6 months
Posted on Jan 16, 2013
How often do I clean and lubricate the chain on a Suzuki 650 v strom xt.
Hi
I used to clean and lubricate my motorcross bike chain on every outing but obviously it was seeing a lot of dirt. On a road bike I would suggest just keeping an eye on it and do it when it looks dry ,you cant hurt it by over lubricating it but depending on where you park it it could drip off the chain although I used Putoline foam lubricant as its quite thick and easier to manage
Hope this helps Nick
Aug 20, 2017 | Suzuki Motorcycles
Lubricate has stopped flowing to lubricate the chain when in use. What should I do?
didnt specify make model ---generic answer--check level in tank ---if good remove cover, chain,and chain bar and look for a small foam sponge type material on inside frame along where chail and bar are thats what allows the oil to lube chain if covered in debris or clogged clean and or replace the following link showes the ioler on different models
Chainsaw Oiler Not Working Yahoo Video Search Results
Jul 12, 2016 | Garden
Where does the chain oil exit the tank and drop on the chain?
take off the side cover over the chain clutch/drive, don't forget to loosen the chain tension before removing, clean thoroughly, clean oil ports on saw and on the chain bar (little holes)clean the chain bar. Start the saw with the chain and bar removed and you should see oil coming from the port on the engine. Reassemble
Feb 25, 2015 | Garden
Garage door openers
Clean the chain rail with a solvent that can remove old lubricant. Re lube with Lithium based lubricant that does not "harden" when the temperature drops - other types of lubricant tend to "harden" with lower temperature that strains the movement of the door. Clean excessive lubricant from the rail as it can drip onto your vehicle.
Jan 19, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Lost operating and maintenance instructions. Need to know how much oil to put into the self lubricating chain reservoir and where it feeds the chain to make sure there isn't a blockage anywhere.
You are free to charge to the top if you think right to use a chainsaw. It is essential that the oil is clean. If you accidentally charge too much (full hopper) it is good the rest of oil put back in the oil bottle or to extend on the chain. It is important that it is not oil-free and should be cleaned around the chain for good lubrication.
Sep 05, 2011 | Garden
How often should i oil the drive chain and clean it ? When must it be replaced?
Use commercially available chain lubricant to keep the drive chain from ever running dry. Usually it will be necessary to lube the chain every 200 to 500 miles, depending on how hard your bike is ridden and the conditions it is operated under. Chain lubes available at your local motorcycle shop are far superior to using any other type of lubricant. They are formulated to not fly off and make a mess of your rear wheel, clothing, etc.
If given decent care, you can expect your drive chain to last 10,000 to 20,000 miles. Lubrication and proper adjustment are the keys to success. Ordinary cleaning is not necessary - except for off road bikes.
It is time to replace the chain when you can lift the chain from the sprocket and expose anything more than about 1/2 the length of any tooth on the sprocket.
Jun 08, 2010 | 2001 Triumph Triumph Bonneville
Chain maintenance
Whether or not your chain needs adjusting, you'll want to keep it clean and well-lubricated. Most modern chains are o-ring types which use rubber components, and are sensitive to certain solvents. Make sure you use an o-ring approved cleaning agent when you spray the chain and sprockets or use a soft brush to apply the cleaner. Next, you'll want to wipe off the excess grime using a rag or towel, which will create a clean surface that's friendlier to lubricants. Be sure to thoroughly reach all the sprocket teeth and chain links by rolling the rear wheel (or the entire bike, if it's not on a stand.)
Nov 20, 2008 | 2006 Harley Davidson FXDI Dyna Super Glide
Chain maintenance
Nov 20, 2008 | 2004 Harley Davidson FLHRS - FLHRSI Road...
Chain maintenance
Nov 20, 2008 | 2005 Harley Davidson FLHR - FLHRI Road...
Chain
The answer depends on whether external chain lubrication is beneficial for a chain with internal grease sealed with o-rings and perhaps how often you clean your chain. One school-of-thought believes that no additional lubrication is needed. The other believes that the sprocket and chain surfaces that do not have permanent grease also need to be lubricated. The chain manufacturers tell us that also lubricating the chain and sprocket surfaces will extend the life of these components. But a chain lube will sling-off unless designed to stick to the chain so it needs to stay tacky. Consequently it will also attract grit and road debris that, in turn, will accelerate wear faster than if you just have a clean unlubricated chain. Chain lube will also reduce power losses due to friction and shed water that leads to rust (and wear). If you live in a wet climate, you should probably use chain lube to prevent rust. A chain newly-cleaned with WD-40 will have a coat of light oil that will effectively displace water and reduce surface corrosion of the links. It's a low viscosity oil so any excess will sling off easily, but will attract very little grit - much less that any chain lube - and it will have the same rolling friction as a number of chain lubes on the market. WD-40, used as a one-step cleaner and lubricant is sufficient. Because it is a light oil, some fling-off will occur, so any excess should be wiped-off. USED REGULARLY, it provides good corrosion protection, low (but not the lowest) rolling resistance, and attracts less road grit than waxy chain lubes. So your chain stays very clean. If you aren't inclined to clean and lube your chain regularly, or often ride in wet conditions that promote corrosion, there are chain lubes on the market that are designed to stick to your chain to resist fling-off and provide longer-lasting corrosion protection. Some remain tacky and attract grit, some stay slippery to the touch. All of them need to cleaned off and renewed at some point. If you’ve decided to use chain lube after cleaning your chain, then it’s best to use straight kerosene as your cleaner because the light oil that WD-40 contains will make it difficult for the chain lube to stay attached without flinging-off.,,,
Nov 10, 2008 | 1977 Ducati 860 GTS
Hoisting Logo
779 people viewed this question
Top Hoisting Experts
Andrew Taylor
Andrew Taylor
Eric
Level 1 Expert
Are you a Hoisting Expert? Answer questions, earn points and help others
