Question about Dell 2300MP Multimedia Projector
The dell 2300mp projector makes a loud buzzing sound when turned on and does not subside
Removed fan and tested okay
  • 3940 Answers
SOURCE: dell 2300mp
http://support.dell.com/support/edocs/acc/2300MP/en/index.htm
Posted on May 10, 2008
  • 1257 Answers
SOURCE: dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Posted on Jun 18, 2008
SOURCE: dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Posted on Jun 27, 2008
SOURCE: Dell 2300MP Projector Lamp - "Orange Light"
Have you put the lamp cover back on? as I did the same and it would not power the lamp.
Posted on Nov 19, 2008
  • 22 Answers
SOURCE: projector heating up and bulb shuts down
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Posted on Jul 21, 2010
I have a DELL 2300mp i heard a loud sound and it sound like the fan was making a sound i took the bulb out it looked good ,when i took the bulb out i was get small pieces of color thin glass like a le
as your description, the color wheel should be shattered now. so you have to bur a new color wheel and replace it.
if you need any further help, you can freely contact me,
Mar 11, 2012 | Dell 2300MP Multimedia Projector
Dell 2300mp
Jun 18, 2008 | Dell 2300MP Multimedia Projector
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Mar 26, 2011 | Dell 3300MP Multimedia Projector
Projector heating up and bulb shuts down
Jul 08, 2010 | Dell 2300MP Multimedia Projector
I have 2300mp i had a loud sound and it sound like the fan was making a sound i took the buld out it look good but i bought one ant way,when i took the bulb out i was get small pieces of color thin glass...
This is undoubtedly a broke color wheel. The wheel is made up of four small slices of colored glass, Cyan, Magenta, Yellow and Clear. Each slice is fixed into a groove on a brass hub. The high-pitched "whirring" noise that you hear on start up is the wheel spooling up at high speed. If one of the "slices" comes loose from the hub it can break, bind or start scraping. Regardless, there is a sensor that reads the speed of the wheel and won't allow the unit to come fully on if the wheel doesn't come up to speed (which it no longer can). Bottom line...Game Over. It's simply too expensive to fix. I personally am hoping for a class action suit on this obvious piece of junk retailed by Dell. But think of all the extra money they are making from people rushing out and spending up to $300 for a bulb that won't solve the problem. Ahhh...gotta love free enterprise!
Dec 31, 2009 | Dell 2300MP Multimedia Projector
Dell 2300mp projector
check this out...
Jun 20, 2008 | Dell 2300MP Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
Dell 2300mp
May 09, 2008 | Dell 2300MP Multimedia Projector
Dell 2300mp projector color wheel
no there is a little difference in it. u can fix it if knows the proper settings....
there is always a setting in every thing....
Feb 07, 2008 | Dell 2300MP Multimedia Projector
how do you know the lamp is OK if no image appears? If it is in fact okay, be sure that the cables are properly attached (s-video in s-video, composite video in composite video) Lastly be sure the focus ring has not come loose and is distorting an image to nothingness.
Jun 15, 2007 | Dell 2300MP Multimedia Projector
Dell 2300MP Multimedia Projector Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
