Monitor colors too brite
Samsung monitor
  • 2,072 Answers
Locate the menu button on the monitor. Press it and look for the brightness setting. Look also for the + and - symbols on some of the buttons, use the - button to lower the brightness to desired setting. Remember though that having it too low will have negative effects on your eyes.
Posted on Mar 02, 2013
Over briteness and top botam both side cuting
open the monitor check eht rotate the preset on eht named screen brightness will be controlled
there is a three lead diode attached to heatsink near eht replace it even found ok problem of oversized display will be solved
Feb 07, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Hcl crt color 15" digital monitor.red color is
Unfortunately, this is not a fixable problem. Samsung CRT monitors are well known for losing color; they have defective cathode ray tubes. I recommend that you buy an lcd screen. sorry if that wasn't what you wanted to hear! don't forget to rate
Jan 13, 2011 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Dec 24, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
No green color
Dears,
It happens due to either the PC settings or the monitor (hardware) settings. Would advise you to select menu from the monitor and do a factory setting do a quick check by using paint. The other option here is to access the color management in the control panel, there select the RGB values appropriately Hope this solution helps !!
Nov 09, 2009 | Samsung SyncMaster 700 (White) 17 in.CRT...
Tv, has yellow hue,lacks brite day and night
Replaced light engine. Be sure to note if model has an A at the end of it when ordering. They use different parts.
Aug 11, 2009 | Hitachi 51F59 51" HDTV Projection...
Added as 2nd monitor, color PINK
Check the cable...are any of the pins damaged, bent or missing? Can you access the Monitors control panel and reset its settings to factory default?
May 17, 2009 | Samsung SyncMaster 920NW Monitor
Samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Dec 30, 2008 | SAMTRON 55V 15" CRT Monitor
Color of the monitor is in problem
I don't know why samsung company didn't do anything about this problem. It will cost their business to downgrade. Most of my monitors have the same problem like this. Even the service center can't do anything about this problem. So I recomend to those who is planning to buy a good monitor not to buy samsung monitor or else, you will experience the same problem as mine. Well if samsung personnel can read this, pls. give us advise how to solve this problem or else you will lose most of your customes.
Nov 28, 2008 | Samsung 793DF 17" CRT Monitor
Viewsonic VG919S 19" LCD
Hi
You must focus to mainboard of LCD monitor find the voltage regulator IC. Voltage test the regulator IC use digital or analog multimeter range 10v dc connect the negative to cold ground, these regulator providing a constant supply of 2.5 - 5v to all IC in the mainboard. check the scalar IC. Because scalar IC will convert analog input signal of Red, Green & Blue. Lastly check the controller board, check the ribbon cable connector from mainboard to
controller board for lose, check the fuse inside controller. I think the exact problem of your monitor could be either the (mainboard) or (LCD panel where the controller board is located).
Oct 06, 2007 | ViewSonic VG910S (Black, Silver) 19" LCD...
Computers & Internet Logo
David Payne
David Payne
