I got this from Haynes Diesel Engine Repair Manual. I bought it for my 6.2.
1. Remove the fuel filler cap and air cleaner assembly.
2. On filters without an air bleed screw, place a rag under the filter to soak up fuel and detach the lower clip FIRST to release pressure and then the top clip. They pop off with a screwdriver.
3. On filters with an air bleed screw (top passenger side) drain fuel from the filter by opening the screw first and the engine water drain valve (engine front near thermostat) if it has one. Detach the clips and remove filter.
4.Make sure the seating surface is clean and place new filter in position. On non-air bleed filters put the upper clip on FIRST. On air bleed filters secure both clips, then close the valve and attach a piece of hose to the bleed port into a pail.
5. Air must be purged BEFORE start up, so disconnect the pink wire from the top of the injector pump and crank the engine in 10 second cycles with a 30 second wait time until clear bubble-free fuel comes out the lower fitting or air bleed. Connect the lower clip on the non-air bleed , close the bleed hose and reconnect the pink wire.
6. Start the engine and let it idle for several minutes to purge any remaining air and check for leaks.
Hope this helps.
Depends what type of person she is. Tomboy, girly, etc.. See girly girls like big bug sunglasses. Aviator ones are cool though. And get them her favorite color (or black) if possible.
hi, you need to check if the processor fun is actually working. if its working then you need to replace the processor but if its not working then you need to order for the fun to reduce heart on the processor.
