Question about Cuisinart DGB-600 Coffee Maker
Coffee leaks while brewing.
While brewing, the brewed coffee leaks to the outside of the carafe, and all over the counter-top. This used to have occassionally, but occurs more often now, and seems to happen about midway through the brewing cycle.
5 Suggested Answers
SOURCE: DGB-600 leak from carafe during brewing
My new Burr Grind & Brew grinds away but all I get is hot water?
Posted on Feb 07, 2008
SOURCE: My DGB-500 Cuisinart Grind & Brew coffee maker leaks coffee
I found out that internally the water line that comes off of the heating element is made of a rubber/silicon material. The heating element is so hot that it scorches or dryrots the tube and it cracks causeing leaking. Sometimes it comes pouring out and other times it just is enough to make it a pain. I have taken the time to get my specialized screwdriver set and take off the bottom of the pot, but have not been able to find a replacement tube for it. (They also made the tube so that you dont have enough to cut the broken end off and put it back on and if you COULD do it, they also put an "X" in the original tube so if you cut it and try to put it on you cannot push it on far enough. Other than this, it was a great coffee brewer for me for the past four years. (Put baking soda and water paste on the coffee stain if you have formica counters. A few times of doing that and the stain will come clean)
Posted on Apr 13, 2009
NewsView
  • 40 Answers
SOURCE: my grind and brew turns itself off in the middle of brew cycle
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir as a guide rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. As such, a 12-cup machine actually produces closer to 9 standard 8 oz cups. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. It is extremely important to clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
Posted on Jan 04, 2010
NewsView
  • 40 Answers
SOURCE: cusinart 12 cup grind and brew overflows with grinds and water
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
Why does the coffee brew all over the counter, on cuisinart doc-1150?
Dear Friend,
Make sure that there is nothing interfering with the brewing process such as small particle of coffee been stuck between the jar and the brewing funnel on top that can cause any clog. Used coffee paper filter if you are not using.
Good Luck
Sep 20, 2014 | Cuisinart DCC-1150BK 10-Cup Programmable...
DCC-1200 leaks coffee onto carafe and warmer plate
My coffee pot was leaking over the carafe and onto the warmer. I found that this issue was caused by the carafe lid. The lid was not allowing coffee to flow into the pot fast enough. I removed the inner mechanism from the carafe lid (it pops off really easily) and just sit the lid on top of the pot while brewing, and no more leaks! After brewing, I put the mechanism back onto the lid and twist lid onto the pot.
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
DCC 2400 COFFEMAKER LEAKS CONSTANTLY. ALL OVER THE COUNTER. HAVE CLEANED IT. IS IT FIXABLE SHOULD I TRASH IT?
I had this problem.
The Fix:
There is a valve in the centre of the carafe lid (If you shake the lid you can hear the valve rattle). This valve becomes gummed up with heavy coffee oils over time and sticks causing part of your brew to pour onto your counter. The fix is to simply clean the oil out of this valve. I cleaned mine by soaking it overnight in a water/bleach solution then blasting hot water into it. You can clean it more thoroughly if you pop off the bottom lid part that extends into the pot. It is a snap fit. Before you take it off note the orientation.
On my lid this valve was coated in heavy, greasy coffee oils. After this cleaning your pot should not leak when brewing.
Another problem is the stiffness of the lid making it sometimes very difficult to open and close and if not fully closed coffee will leak while pouring. This o-ring binds against the carafe. To fix this, locate the 'O' ring in that same part the extends into the carafe on the bottom of the lid. put a drop or two of vegetable oil on your finger and apply a thin film around this ring once every three weeks or so. Your lid will open and close smoothly and beautifully.
Happy brewing!
Feb 22, 2011 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee spilling out the sides of the carafe
I had a Mr Coffee that did that. It was running across the brew pause arm and making a mess. I discovered that the position of the carafe had a lot to do with it. If I brewed with the handle pointing out towards me, very little leaked out. I finally tore the brew pause arm off of the bottom of the brew basket. I works great and hey, I can wait ten minutes for a cup of coffee! However, if yours is new and doing this, I would contact the company and see if they'll make it good.
Jan 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
When brewing the coffee at times the water stays and almost overflows where the filter and coffee is rather than brewing properly- what could this be and how to fix it?
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
8. Clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
Aug 13, 2009 | Cuisinart DCC-1200 Coffee Maker
My cuisinart brew and grind overflows onto to the counter also
8. Clean your carafe and machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water spots). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
Jun 27, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My grind and brew turns itself off in the middle of brew cycle
May 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cusinart 12 cup grind and brew overflows with grinds and water
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
Mar 29, 2009 | Coffee Makers & Espresso Machines
Apr 14, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
66 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
