Question about Korg PS60 61 Portable Performance Synthesizer KEY ESSENTIALS BUNDLE
Korg ps60 not working - Korg PS60 61 Portable Performance Synthesizer KEY ESSENTIALS BUNDLE
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
When i did the INTIALIZATION in korg x5, the PROG,COMBI,GLOBAL & MULTI is not stopping in blinking. How will i proceed to PRELOAD??? Pls help me. Thank you. Add a Comment:
If the answers I have provided you with already don 't work for you, or don't apply to your specific problem, you need to contact Korg customer service for an answer. Here is their link-
Mar 15, 2016 | Korg Music
My korg ps60 shuts off after using it for a while . The led screen goes white with no response
Open it up feel the transistors and chips one is getting hot make a cool element for it from aluminium or use ney arctic silver padte between the transistors and the cooling plates
Nov 08, 2014 | Music
What screws need to be removed to get inside the keyboard to replace power supply input jack
Flip the keyboard on its back and remove all screws with an arrow.
If no arrow, remove all on outside edge.
The jack should be easy to replace but you may need a soldering gun.
May 07, 2014 | Korg PS60 61-Key Performance Synthesizer
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
My Korg PS60 sounds veey low with Headphones . i didnt plug it to an Amp yet ( Id just receve it yesterday ). Headphones Sounded also just in one side. I had to buy a Plug Stereo converter . Is this...
It is NOT normal... Apparently one side of the audio drive is bad, Take it in for WARRANTY repair immediately. Also read your manual in regards to "Panning" and any settings for it.
Nov 08, 2012 | Korg PS60 61 Portable Performance...
My ps60 has a high freq noise with a regular pulse pattern it does this thru mymixer and also when i plug it direct into amp cheers Brian Garbutt
Hello Brian, It could be a ground loop problem, I usually get something similar when connecting a laptop to an amplifier. You can purchase ground loop isolators from car hifi places which are used to take ground loop problems out of car audio systems. They are very cheap so maybe worth trying this first. I got one for £12. They have stereo RCA input/outputs and require no power.
Hopefully this is of help to you.
Aug 08, 2011 | Korg PS60 61 Portable Performance...
How to perform a factory reset?
1. Power-off the PS60.
2. While holding down the four PERFORMANCE buttons and the OCTAVE DOWN button, power- on the PS60. The PS60 will be initialized, and the factory-set data will be written into internal memory. The display will indicate "Initializing..." while data is being written. Never turn off the power while this indication is shown.
Manual available here:
http://www.korg.co.uk/downloads/ps60/docs/PS60_OM_E1.pdf
Jun 24, 2011 | Korg PS60 61 Portable Performance...
Korg PS60 61 Portable Performance Synthesizer KEY ESSENTIALS BUNDLE Logo
35 people viewed this question
Top Korg Music Experts
Vito Vacirca Jr.
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Korg Music Expert? Answer questions, earn points and help others
