Question about Toshiba Satellite A135-S2276 Notebook
I re-started my toshiba A135 laptop, and the screen went black
The laptop never shut down and the screen went black, So I held the power button until it shut down, but when i turn it back on, nothing on the screen and it do not power up. and no cd drive or hard drive don't get power. only the green start button lights.
  • Julian Ruiz Jan 25, 2009
    I am currently working on a toshiba satellite that had the same problem. However I don't know how it work but I just turned it on and left it on and for some reason it kicked on. Right then I did a restart and started doing some simple diagnostics tests. Later to find the hard drive had several corrupted sectors. After I let the utility fix the little sectors, the laptop worked. However now it is messing up again. So it maybe possibly the Hard drive or the Motherboard in general. If it is the motherboard might as well let it out in the wild and shoot it. Unless under warranty.
  • djlarryb Jan 25, 2009
    I tried it all, but it's still not working
  • 51 Answers
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Posted on Jan 24, 2009
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Black screen of death
Try to Run in Safe Mode....
to run in safe mode.......switch on and press F8 cont. until You received the option menu. select the safe mode there.
if not try to start with last known good conf. with same proc.
if it is not work then u have to install ur OS
Jun 28, 2010 | Toshiba Satellite Pro L300 Notebook
I was shutting down my toshiba laptop, its now frozen.
If nothing else works remove the battery, leave it for 5 mins then replace it and it will start as normal. Yyou will get an error message usually saying it was not shut down correctly and it may do a system scan but unless there is a real problem with it that will restart it. Ive had to do that twice with mine in the last year.
Jun 15, 2009 | Toshiba Satellite A135-S4427 Notebook
Toshiba A135-S4527 will not automatically shut down
If you truly believe the problem happened right after installing the new mouse, then you should start by uninstalling the software for it. Go to Control Panel -> Software -> Uninstall. If this fails, you can use the System Restore utility to rollback the Windows registry to a time before you first installed the new mouse software. Have you tried to unplug the mouse and not use it, atleast on the attempted shutdown process?
Mar 22, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S2376, black screen problem
have u tried to power up with external monitor? reply back.
Oct 26, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshibba laptop a135-s2276 ,my mother bords smd chip does not work so display of screen does not appear
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
Oct 15, 2008 | Intel Motherboard
Toshiba Satellite A135 laptop
Try disconnecting power adapter and removing battery for two minutes. If the laptop still does not boot then there is an hardware problem. You can try taking out and putting back ram modules, but my suggestion is to take the laptop at a repair shop, if you cannot fix it by removing battery.
Jul 29, 2008 | Toshiba Satellite A135 Notebook
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
Apr 05, 2008 | Acer Aspire 5100 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
193 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
