Question about Texas Instruments TI-Nspire Graphic Calculator
I can not turn on my Ti-nspire Cx
When I plug in to charge the battery there is this orange light on but never turns to green. The screen when I plug in lights on but nothing shows in the screen.
  • Joaquim Santo Jan 18, 2013
    Ok here is more details as you requested. My Ti-nspire Cx seams like lost all memory. I tried to turn on but is a complete black screen. Nothing. I tried to charge for almost 24 h but still there is no power in it. It does not turns on.
texinst82
  • 12 Answers
SOURCE: ti 83 plus small black screen?
try pressing 2nd then hold in down arrow to change the contrast
Posted on Feb 16, 2009
  • 7993 Answers
SOURCE: My TI-nspire CAS doesn't want to go on! I changed
Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Posted on Oct 18, 2009
fathitkf
  • 1871 Answers
SOURCE: water damage on TI 84
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 27, 2010
SOURCE: My Ti-nspire won't turn on. Replaced batteries
Same thing happened to me. I replaced the batteries, and now it won't progress past the start-up loading screen. It just loads and freezes. I had to remove the batteries just to turn it off.
Posted on Oct 24, 2010
  • 12 Answers
SOURCE: I downgraded my TI-Nspire's OS
I had this same problem myself and I had to look everywhere to find a solution. You will have to remove the current OS from your device. Heres how.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=101985&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGC81E19298A9321E38D51491551F331C8CCDA6801E50CC672F84B3EFDF0F6ACEF9DD42026E6C2FF1F9579670CF87CEAF79D
I couldnt use option 2 for some reason and had to use option 4 (complete format, luckily I had backed the files up earlier) but once it was reformatted the device showed up in the software and told me to update the OS. From here you just install the latest OS as you would normally.
The problem with what you and I did is that previous OS versions (1.7 in my case) dont support the keypad, you may be able to use the older version with a different keypad but I'm not sure.
Anyway, I hope you can fix it, good luck.
Posted on Jan 08, 2011
My TI-nspire CX CAS just got a white screen with a black stripe.
Unplug the battery? I thought that the battery was built in.
Nov 13, 2014 | Texas Instruments TI-Nspire CX CAS...
What if my calculator is not working?
Use the original charger. The charge process may seem rather long.
Apr 27, 2014 | Texas Instruments TI-Nspire CX Graphing...
Ti nspire cx screen is really dim.
Recharge the battery and see what happens.. Could also be that the autodim feature is fixed to the lowest value (30 s).
Apr 01, 2014 | Texas Instruments TI-Nspire CX Graphing...
The calculator writes 8 all over
During operation of the TI-Nspire handheld it may be necessary to reset the device. Circumstances which may require a reset include; keys not responding, device will not turn on or a garbled display. To reset the device:
• Remove the keypad (for TI-Nspire with ClickPad, TI-Nspire with TouchPad, and TI-Nspire CAS with Touchpad) or the battery door (for TI-Nspire CAS with ClickPad) and remove at least one battery from each column of batteries. After 2-5 seconds, reinsert the batteries but do not turn the handheld on.
For the TI-Nspire and TI-Nspire CAS handheld units with ClickPad:
• Hold down [home] [enter] [P].
• While holding these keys press [on].
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
Please Note: For TI-Nspire Family handheld units that contain rechargeable batteries you can alternatively hold the above keys while pressing the [reset] button on the back of the handheld rather than removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
• 2: Delete Operating System - The operating system will be deleted without deleting any documents on the system.
• 3: Delete Document Folder Contents - This will delete the user's documents, but will not delete the OS. Selecting this option is the same as using the RESET hole on the back of the unit.
• 4: Complete Format - This will delete the OS and all documents for a total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled
Mar 12, 2014 | Texas Instruments TI-Nspire Graphic...
My TI NSPIRE CX CAS is stuck at the loading screen - it keeps loading and then going back and repeating (only when plugged in). I have tried resetting it whilst holding down EE, doc and enter. When I do...
restarts.
unit.
Please note that the second and fourth option will require that the OS will need to be reinstalled.
Oct 09, 2013 | Texas Instruments TI-Nspire CX CAS...
How to get the ti nspire cx to give square root answers
You can not achieve this with the Ti-nspire cx. Only the CAS version will give the square root form. On the CAS there is an option in the settings called "EXACT" under calculation mode. The cx does not have this mode.
Jan 09, 2013 | Texas Instruments TI-Nspire Graphic...
My ti nspire cx cas is totally stuck at the loading screen , it keeps reloading and reloading with a sign at the left corner at the bottom that say's that my battery is empty ? what should i do ?
I have a doubt, when I choose to completely format the calculator it will clear your operating system, files saved on it, but the product key (ID protuto) will be deleted too?32d3cd84-9b87-4f5d-abfe-aa04ca86df4c.jpg
Dec 18, 2012 | Texas Instruments TI-Nspire CX CAS...
Hi, I have a problem with ti-nspire cx cas.
The Ti Nspire CX CAS has a built in battery. It must be recharged. If you plug it in a wall socket or in a USB charger you should be able to use while it is being recharged.
Nov 22, 2012 | Texas Instruments TI-Nspire Graphic...
Hi, I have a problem with ti-nspire cx cas, it doesn't charge via a usb cable.
Are you really talking about a TINspire CX or a TI NSpire. The TINspire CX (CAS or Not) comes with a rechargeable battery and an adapter/Charger. You plug the charger in an electric outlet and let it party charge. If the calculator battery fails to recharge then it must be defective. Any third party mini USB charger will recharge the battery.
The TINspire with touchpad (CAS or not) can use regular batteries or the optional rechargeable battery.
It is not necessary to connect the calculator to a computer to have it recharged.
As far as the calculator being recognized by the computer, you must install the communication software (TI computer Link Software for the older TINspire) or the TI Nspire teacher or student software for the CX. When you run the TINspire teacher or student software and then connect the calculator, you will have the opportunity to select it.
Aug 16, 2012 | Texas Instruments TI-Nspire Graphic...
Havent used my ti-inspire since last school year.wont turn on
Here is what the TI knowledge base says about a calculator failing to turn on
Aug 30, 2009 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-Nspire Graphic Calculator Logo
1,239 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
