Question about RC Toys
Linear servo retainer replacement for e-flite mcx
How the heck do you get those little buggers on?
It isn't a great solution, but i was able to get one of these retainers back on. Using only the screwdriver in the kit, and my thumbnail. Try to work in a well-lit, clean area, so if the retainer gets loose, you can find it. Should be obvious, but Make sure the power is disconnected to the heli
--Heli Dis-assembly--
First, disconnect the two servo pushrods from the swashplate. Unless you want to replace the swashplate, be careful not to break the connecting ball off.
Second, disconnect the two motors from the control unit. Be mindful of the direction they need to be reconnected (white/black on outside, blue/orange on inside--in that order)
Third, using the provided screwdriver, remove the two screws holding the control unit on the heli. pull it off the chassis, but be mindful of the Antenna wire. I would try not to bend this more than you have to.
-Retainer installation-
Fourth, lay the control unit on the clean flat surface, pull the servo gear shaft slightly out of the unit until it is flush with the plastic.
Fifth, Carefully drop the retainer next to the servo. Using the tip of the screwdriver, apply enough pressure to the retainer to guide it up the plastic to match the hole with the shaft.
Sixth, Apply gentle but firm pressure upwards on the gear shaft. this should push the retainer onto the shaft just enough for it to hold on.
Seventh, using your thumbnail on one hand, and the tip of the screwdriver with the other, apply pressure to both sides of the retainer to slide it down the shaft. *NOTE* This is where i had the retainer flip off the gear shaft multiple times, only to have to repeat steps 4-7.
Eighth, Begin re-assembly in reverse order from steps 1-5. Reattach the canopy, and power, and attempt flight. If it spins uncontrollably, make sure that you have the motors hooked back up in the correct polarity (otherwise it spins in the opposite direction)
NOTES--
-Tiny tweezers don't seem to allow for enough force to push the retainer onto the shaft
-A standard screwdriver of comparable size to the provided phillips head screwdriver may allow for more pressure to be applied
-The retainers like to spring off of the shaft when pressure is applied in the wrong place-- hence the clean surface to find them when they do.
-I can't seem to find anywhere that sells only the servo retainers, so if you lose them, you may need to purchase the entire servo assembly. :(
-I know check these retainers as both pre and post flight checks to ensure that they are securely into place. They seem to like to pop off during very hard collisions (which is how mine came off)
Posted on Feb 18, 2009
MTD Snow Flite model 316230500. Where can I get belts?
I have already answered you twice with this information!
They have there own forum.
http://www.snowblowerforum.com/forum/mtd-snowblowers/1397-mtd-snow-flite-snow-blower.html
You don't need the part number, you just need to measure the length, or you can phone and say;
I have a snow flite brand snow blower model.316230500. Serial no.811262, send me a belt for it.
All the belts are here
http://www.jackssmallengines.com/equipment/mtd/snow-blower/belts
and here
http://www.mtdparts.com/equipment/mtdparts/parts/machine-types/snow-throwers
Dec 24, 2015 | Garden
Which is the Best financial solutions service provider in India?
Achiievers Equities ltd is the best financial solutions service provider in India.
Mar 14, 2014 | Cell Phones
2000 explorer automatic transmission shifting fine but noticed fluid on ground and checked.fluid leaking from servo cover and clip half off.loks like servo cover sucked in a little where clip is off.
You don't need us
You know that you need a new
retaining spring/ring on the servo cover
Do not use it, as the servo won't work correctly
& you could break the band or wear the bore in the case
Sep 07, 2013 | 2003 Ford Escape
I need a wiring diagram so i can figure out where the red wire goes. For some reason it's not connected to anything
That's the antenna and one end is soldered to the 5in1 board. The other end isn't attached to anything. It simply is wrapped around the frame to stay out of the way of the servos. That's how it comes from the factory.
Jul 15, 2011 | E-Flite Eflite Eflh2401 5in1 Control Unit...
The red light is always on, and it doesn't seem to be charging. Its almost brand new.
Same thing started happening to me. The red charging light was initially going out but then after a few days use started staying on. I assumed that the battery was damaged and bought 3 new batteries but the red light is still staying on when I charge the new batteries.
I suspect that the mains charger I was using (same voltage but not the recommended charger) has perhaps damaged a component inside the EFLC1003 unit which is now not letting the power through to charge the battery.
Dec 30, 2010 | E-Flite 1s 3.7v Li-po Battery Charger Mcx...
Throttle Problem
Hi
Your ESC is sensing an error. The error is either blade speed or a peripheral device - possibly servo or gyro. Sub the servos one by one. Check the blade tracking. Have you had any crashes lately? You should double check all the head assembly components.
Jun 02, 2010 | E-Flite Blade 400 3D RTF Electric Mini...
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
Rudder control very slow on CX 2
sounds like your servos are weak or just slow you can get stronger and faster servos check with your local hobby store
Mar 27, 2009 | E-Flite Blade Cx/cx2 Scale Body Sh-60...
Woofer,s outer ring is ripped.
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
Jan 03, 2009 | Velodyne VRP-1200 Subwoofer
Powr-flite PD 2500
I need a control knob (on off and speed) for a powr-flite pd2500, any ideas when I can obtain one
Jul 28, 2007 | Powr Flite PD2500 Handheld Vacuum
Toys Logo
822 people viewed this question
Top RC Toys Experts
LP
Tom Chichester
Tumaini Kihampa
Are you a RC Toy Expert? Answer questions, earn points and help others
