Question about Emerson EWF2004 20" TV
Vision Quest Van Gogh 32 " plasma TV. What are remote codes?
    Top Expert:
  • Emerson Master
  • 38,061 Answers
Codes are stored in the remote. If you use a universal remote you can try its code search (or equivalent) feature to find something that will manage some or all functions of your TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Posted on Feb 11, 2016
2 Suggested Answers
  • 9 Answers
SOURCE: comcst remote control code not working
That Emerson TV is made by Funai. Best solution is to get a univeral remote with code search capability for 10 bucks or so. Follow the instruction manual, and It will search all codes until it finds a code that works. May take 5-10 minutes.
Posted on Sep 15, 2008
Vision quest renoir
First check the power supply of your TV,multimeter the export voltage of power supply.if it is defective you can replace it.
if not you need check main boards,and inverter boards
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Dec 09, 2013 | Televison & Video
I have a vision quest tv and lost the remote and the buttons on the side won't switch so I need a code for my universal remote
Check these codes. If you wish to get more codes, check this site.
0664 0691 1233 0529 0404 1939 0067 0586 0039 0246 248 0247 0481 1167 1938 0910 1248 0906 0895 0728 744 0736
Feb 10, 2013 | Televison & Video
Reset Password?
I had same problem, called visionquest tech support for how to reset the tv:
Using the remote, press source then 2580.
A menu should appear, go to other settings then choose restore default. Select yes.
It worked for me - hope it does for you too!
Jan 09, 2010 | Panasonic TH-50PX75U Plasma HDTV
How to reset the password panasonic plasma tv Th50px75u.Becouse i forgot the password please.thanks
I have a Van gogh 32" PVQ-32VGB Plasma Tv by Vision Quest. The password which was the manufacturer password was 0000 and i went to enter it and it was incorrect. Now i can get into anything!!! What can i do?
Dec 10, 2009 | Panasonic TH-50PX75U Plasma HDTV
Tv code
The Innovage Jumbo remote control manual does not list any TV's by the manufacturer Vision Quest, but that does not mean your TV is not compatible with another brand's control codes. I recommend using the auto-search function to see if any of the remote's TV codes work with your set.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 07, 2009 | Innovage Jumbo Remote Control
VisionQuest Van gogh Plasma 32''. The standby light shut down. No power on has possible. I check the 3 fuses inside the TV and all is good. Someone know what is the problem !!!! Tks
Good day sir, your tv or any new tv are now using SMPS or technically called switch mode power supply, a regulator mode that is more efficient than traditional power supply, the down side is that its prone to defects, there are three main parts the Switching element which is the transistor, the oscillator circuit which is usually an IC that controls the frequency of oscillation and the high freqency power transformer that works with the switching transistor. All of these parts are need to be checked to ensure proper operations. SMPS also detects overload, which is caused by faulty parts on your tv, unless that faulty part is not found, it will not start and go on standby mode, worst will always shuts down. Call your dealer on how to go about your tv problem or have it check by a qualified technician.
Nov 03, 2009 | Televison & Video
Need a universal remote control code Vision quest Van gogh 42
According to my information this TV does not have any published universal codes as of yet. A call to the manufacturer results in:
" Just use the remote that came with the TV...it's too new to have the codes yet"
Not very helpful are they? IT's a nice Tv for the $$..guess customer support is sacrificed when we try to save some $$.
May 23, 2009 | Emerson EWF2004 20" TV
Vision quest tv problems
my screen is upside down i dont know how to fix it help me!
Mar 27, 2009 | Televison & Video
Emerson EWF2004 20" TV Logo
1,561 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
