Question about Panasonic KX-T7730 Corded Phone
I need to divert incoming calls to my cell phone
doctox
  • 51 Answers
SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
Posted on Jan 17, 2008
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T633?
If it were my choice, I'd set up an ICD number and forward that to an outside number. Something like pick 400 or 600 plus your extension like 605 (they tend to be defined by default), and go into the group fwd command to dial your cell numbers.
Any call placed from anywhere, either VM, internal, or transfer will go out on another line and dial your cell...assuming you put the fwd number in both places.
Carl
Posted on Sep 01, 2008
Centernet
  • 38 Answers
SOURCE: Diverting incoming calls to another office
You have posted this question under the Panasonic system, but have mentioned the Avaya IP Office 5410. I can't help you with that.
However, for the "other user" that has the same problem, if you're trying to forward calls directed to your extension, you can forward them to any outside telephone number by using the Call Forward/Do Not Disturb (FWD/DND) button. The code numbers depend on your telephone system (the KX-T7633 can be used on multiple systems), and how your system was programmed by your installer, so I can't describe the exact procedure. Also, your extension may have been blocked from using this feature by your installer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
alex_salve
  • 78 Answers
SOURCE: Instruction on how to divert incoming calls to a mobile.
hey c'mon please let the receptionist go after you have finished , why you want her with you?
Posted on May 20, 2009
SOURCE: how to divert call to cell phone?
how will i know if the pone im trying to connect is already cut?
Posted on Sep 04, 2009
Nokia active incoming call diverts
Contact Service Provider
Dec 05, 2013 | Cell Phones
I can make calls, text, but all my incomming calls go straight to voicemail. What's the problem?
Denise,if the phone is a nokia, go to tools in main menu then"settings" and open. scroll to "call divert" and open. you will be in "call divert settings", open "voice calls" and "cancel All Diverts" . then reopen "voice calls" and scroll to "if out of reach" push "options" and "activate".. your diverts will then only come through when the phone is out of area or turned off . you will then get a message when your phone is on again or back in area. other phones are similar and you will need to find similar settings, regards Terry
Jan 13, 2012 | Motorola Mobility CLIQ Cell Phone
Stop all my incoming call while my phone is on on my nokia x3
sir select the menu> settings >call>call divert in this you enter any invalid cellphone number [or] the number which is switch off.when try to access the divert calls you can`t reserve any incoming calls when your phone is switch on...............
Nov 23, 2010 | Nokia X3 Cell Phone
Nokia active incoming call diverts problem:
I hope you have activated your call divert function so your are not able to get the incoming calls.
To deactivate the diverts,
Menu > Settings > Call > Call divert > No Call Divert.
Select No Call Divert it will deactivate all the call diverts and now you can get the incoming calls.
Thanx
Aug 04, 2010 | Nokia 6300 Cellular Phone
How do i use the call forward option?
Call forward or call divert, the same features just different names in some models of phones. Only the name of the service says that it is diverting calls. There is 4 situations for activation and can be activated via the mobile device or directly by entering codes on the display phone. The function codes and their ability to use depends on the network operator.
Codes:
** 21 * number that diverts calls with code of network operator # OK, yes or call it will divert all incoming calls unconditionally
##21# ok, yes or call it will deactivate this divert.
*#21# ok, yes or call it will check status.
** 61 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you do not want or can not answer the call
##61# ok, yes or call it will deactivate this divert.
*#61# ok, yes or call it will check status.
** 67 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when your line is busy ##67# ok, yes or call it will deactivate this divert.
*#67# ok, yes or call it will check status.
** 62 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you are unavailable ##62# ok, yes or call it will deactivate this divert.
*#62# ok, yes or call it will check status.
##002# ok, yes or call it will deactivate all divert.
If the codes not working you have that option in your phone, it is in call settings. You choose option and then insert a number for diverting calls.
This service is not free, and you must contact your network operator for prices.
By!!!
Nov 03, 2009 | LG VX5400 Cellular Phone
Sony Ericsson z750a incoming rings end too quickly.
cancell all call diverts. it may be happening due call diverting.
Jun 04, 2009 | Sony Ericsson K750i Cellular Phone
All incoming calls go straight to voice mail
Just go to call settings and then call divert. check settings. Maybe all calls are diverted to voice mails. Cancell all diverts. Then you are done.
Jan 21, 2009 | Motorola Mobility TracFone® V170 Cellular...
Incoming calls
What you need to do is go to settings then call then call divert, and then cancell all diverts. This should hopefully solve your problems once you have done this you can choose what call diverts you want to use. Such as when the phone is off (divert if not available)
If you don't have signal it is probably the arial and will most likely need replacing.
If you need further assistance let me know!!
May 03, 2008 | Nokia 5300 Grey Cellular Phone
Call managing
Try to see if your phone has a Call divert Feature. 1. You can Divert all voice calls 2. You can Divert if busy 3. Divert if not answered 4. Divert if out of reach 5. Divert if not available
Jul 20, 2007 | Nokia 1100
Panasonic KX-T7730 Corded Phone Logo
80 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
