Question about ViewSonic 17" CRT Monitor
Blinking main menu of the monitor!
My viewsonic monitor (E70fSB) having a problem, the main menu (the one with the option of adjusting the position, zooming, color, size, etc.) of the monitor always pop-up. i can't fix it. i hope you can help me asap.
    New Friend:
  • 3 Answers
My view sonic monitor E70jB Model. Without I Press the menu, it always appearing on the Screen. Some times Contrast up/down and osd lock and it suddenly scrollsfor other options.
If I press the exit button, it sometimes exits or agin it occurs.
So please kindly solve this problem
Posted on Sep 17, 2010
    New Friend:
I also have the same problem dude,these f...ing view sonic doesnt support customers,specially for asia..........please help me ,i am very poor and i cant buy another one........please help me brothers........mail me [email protected]
thank you and god blesses you all.........greets from sri lanka
Posted on Jul 21, 2010
Posted on Oct 04, 2008
No I too have the same problem........
I suggest not to buy viewsonic monitors.......
its all ******* game..........
Posted on Aug 04, 2008
Go to properties of desktop and change resolution - that will reset the monitor - you can click no to make the change permanent for the resolution.
Posted on Oct 06, 2008
  • 65 Answers
Have you tried to isolate the push buttons to see what's happen ??? maybe they are stuck .
Posted on Jul 13, 2007
SOURCE:
My Monitor ViewSonic E70fSB 17" Monitor is working
Causes of OSD LOCK
1. The monitor is incompartible with the system unit, especially for newer version units versus older monitors
2.Older monitors display attempting to much up to the improved definition functions of newer system units display an operating system malfunction, interpreted as monitor malfunction instead. OPERATING SYSTEM DISPLAY MALFUNCTION
hardware checks
1. consider changing the graphic card on the system unit after attempting to adjust the appearance settings on the desktop once the computer is powered on.
2.Once changing the graphics card on an old system unit, consider changing the processing chip for reasons of achieving peak performance of the new part installed.
3. Once the fxing of the parts are complete, the monitor would continue to display OSD requiring entire system restart or book. after which, adjusting the appearance setting that should by which time display new list capacities due to the new device changes
Dec 06, 2010 | ViewSonic E70f 17" CRT Monitor
Viewsonic model E70fB, all the solutions listed won't work, is there another way tosolve this problem?
1)osd lock to remove
2) Main menu blinking and apppearing for every 10 seconds
Jul 31, 2010 | ViewSonic 17" CRT Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
E70fSB main menu keeps on prompting
your monitor low voltage regulator LM7805 inside needs replacement..electrical noise is entering the microcontroller of your monitor..bring the unit to the nearest monitor repair center..
May 10, 2010 | ViewSonic 17" CRT Monitor
Main menu is going on blinking.
its a problem with the monitor and press and hold the menu button on the monitor and the problem will be resolved
Oct 01, 2009 | ViewSonic E70f 17" CRT Monitor
ViewSonic Main menu pop up all the time
Replace the button switch. That switch may worn out, Kindly give feedback after problem get solved
Aug 23, 2009 | ViewSonic VA1930WM LCD Monitor
Viewsonic VX2235wm Horizontal Image Problem
Tricky one. Have you tried using different dispay resolutions from your Windows Display Control Panel?
ie 1200x1014, 1600x1400, etc.
When you say you used the manual adjust, do you mean the horizontal sync option?
Did you perform a Settings Recall?
And most monitors have a way of entering into an engineering "Factory Service Menu". Usually by depressing specific buttons while the monitor is OFF, and then pressing the power button while still holding the others. Then let all button go at once. From there, hit the normal button that you use for getting into the OSD. In the OSD, there's usually a new field with all kinds of cool new settings to play with. One of them being a soft reset. You'll have to search the net for how to enter into your Factory service menu.
Oh wait! I know!
If your picture has moved to the right, move yourself accordingly.
So that now you and your picture will be aligned properly.
He he he...
Kidding!
That one was from ViewSonic customer support.
Apr 03, 2009 | ViewSonic VX2235wm LCD Monitor
Viewsonic g71f+
the feature will be called Auto Adjust on your osd menu, I'm not quite sure where exactly it will be but by clicking on this within the menu will fit it perfectly to your screen. It possibly will even be it's own button on the screen. Since I am not totally familiar with this exact model, I can't be more specific but if you are having trouble, please let me know the options and I can tell you where to look since all monitors are basically the same.
May 17, 2008 | ViewSonic G71F+B-2 17 in.CRT Conventional...
ViewSonic 17" CRT Monitor Logo
873 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
