Question about Panasonic TH Televison & Video
My power supply packed up,is it possible to have it repair and what will the cost be?
    Top Expert:
  • Panasonic Master
  • 74,459 Answers
It will be better to replace the power regulator board to LCD TVs rather than trying to repair it. The repair charge and components cost might sometimes exceed than the price of a new one.
Posted on Jan 16, 2013
It has been a couple years that the typewriter has been out of its case. When plugged in, NOTHING. Would you conclude that the power pack is gone? If so, any idea how much to repair/replace? The...
If there is no noise, movement or lights the power supply is most likely bad. If you pack it well and ship it to us we will give you a free estimate. It won't cost anything unless you choose to repair it.
DickyO
Cleveland Business Machines
2327 St. Clair Ave. NE
Cleveland, Ohio
216-241-0027
Jun 15, 2011 | Royal Satellite 40 Typewriter
Tv repair
It may be possible, but I would need the full model number. What is the problem with the power supply? Depending upon the problem, it may not be worth the cost.
Keep us posted.
Dan
May 15, 2008 | Protron PLTV-32 Television
Tip
Laptop is plugged in but says it is running on battery.
You have your laptop plugged in but when you check it says that you are running on battery. Or, you have your laptop plugged in and it will not work because the battery is dead.
Both scenarios depict a broken power port on the laptop or possibly a bad power supply. Checking the power supply is easy. Using a DMM on volts DC set to 20 place the red lead on the center pin and the black lead on the outside of the plug assembly. If you do not have the correct voltage as listed on the power supply then you need a new one. While holding the leads on the power plug wiggle the wiring to make sure there are no breaks. If the power drops to zero at any time you need a new power supply. A good site is http://www.impactcomputers.com .
Many times people do not realize that their power port is broken until it is too late. If you continue to use your laptop after the port is broken you will destroy the power supply portion of the mainboard and it will cost you half as much as the laptop cost to repair and may make it not worth fixing.
When you realize that your laptop is not running on AC power, and it could be intermittant, you need to immediately take it to a repair facility to get the jack replaced. The average cost should not exceed $150 US.
This is not a repair procedure that I can walk you through. You can only get your unit repaired at an experienced reapair facility.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
on Nov 13, 2010 | Computers & Internet
Power supply fault?
Check all electrolitic capacitors at power supply area : better replace them.
Apr 15, 2008 | Bush 2871NTX 28" TV
How do I recharge the battery? This is a portable DVD player with a battery pack and the instructions say recharge battery before useing, so I put the battery in place and plug in the power cord and left...
Hello, You are doing it right! the battery should be charged with in the 24 hour period. There are two things to consider : One, is the possibility that the rechargeable battery has dried(due to wear and tear)and is not accepting the charge or The second possibility is that the power supply isn't working properly, therefore, not charging the battery.
It is possible to know at least if one of the two is working just by operating the DVD player while connected with the AC adapter. Turn the DVD on and play a disc, if the unit operates, this eliminates a defective power supply and only leaves a defective battery pack, if it doesn't work than consider the power supply defective and repairs are due. As to where to buy a replacement part is for someone else to answer. Good luck!
Oct 13, 2010 | Lasonic Televison & Video
I plugged my reciever into a 220 outlet while it was set on 110, is it repairable?
If the power supply is external device (like power pack) change it from a store or get it to a technician (check the cost). If it's inside the receiver you have to go the receiver to a technician.
Feb 20, 2010 | Audio Players & Recorders
Picture and sound on my old zenith bigscreen flash on and off.
Sounds like a power problem to me. Possible shorting out inside the tv. If its old I would recommend discarding this tv. The price of repair costs are really high for TV's. You can probably upgrade to a flat panel for what the repair cost would cost you to repair this older tv.
Does it turn off and on as if you were pressing the power button? Or does it happen really fast? If its happening as if you were turning the tv off and then having to wait for it to come on again I would say its the power supply which is probably going to cost you hundreds in a repair shop. However you could possibly find a power supply for it on ebay buy searching for the model number and brand in the search area of ebay. Putting a power supply in a tv isn't really that hard, unless there is something in the way to get it in or out of tv. Usually it just involves unscrewing it from the chassis and unscrewing the hot wires and ground from the supply...then putting the new one in and screwing them back down.
Sep 03, 2009 | Zenith IQC60H94W 60" Rear Projection...
TV MAXIM 11-54
I can supply a repair kit for that for £40.00
Plus delivery
Or a new PSU for £98.00
Plus delivery
www.FixMyPlasma.co.uk
Nov 26, 2007 | Televison & Video
RCA F36650 power problem
Apparently, a power supply weakness re-occurring........
Possible incomplete or incorrect repair the first time.....
Have it diagnosed by a qualified RCA tech......
Always a possibility = IHVT = 257805 or asti 2078.......T.
Please rate this solution..........................
Nov 11, 2007 | RCA F36650 36" TV
Low 12v rail!
Sounds a sthough you have a regulator problkem or bad filter capcitors.. these supplys are so inexpensive , is it worth repairing??I have never ever repaired a puter supply/.
Sep 10, 2006 | RaidMax Aurora RX580 (RX580F) 580-Watt...
Televison & Video Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
