Question about Maxxsonics Package: Autotek M4000.1d 4000 Watt Mean Machine Series
Autotek 4000d blown - Maxxsonics Package: Autotek M4000.1d 4000 Watt Mean Machine Series
Repair manual for Autotek MM4000.1d?
For a repair manual, contact Autotek directly.
Jul 19, 2017 | Autotek Car Audio & Video
The words "autotek" and "STREET MACHINE" don't
IF the amp is working properly and just not lighting up...then it's just a matter of replacing the blown L.E.D.s that are needed to light the logo on the amp. You will need to remove the top cover to take out and replace the blown L.E.D.s
Please rate if this helped :)
Mar 17, 2011 | Autotek Machine SM1-1000 Car Amp
I need akai part number ms244708 for a 4000d
If you look around you will likely find many many Akai 4000 series reel decks for sale..some for parts.. Akai 4000 series decks used basically the same mechanism and same parts... 4000d, DS, DS II, DB, Incidentally, the Akai 1700, 1710, 1722, 1731 used the same basic mechanisms as the 4000. .
Oct 24, 2009 | Audio Players & Recorders
Blown subs
check all the connections are good even hook a sub up to and cd player to see if it works if it does it will be the amp
Aug 28, 2008 | Autotek SX280 Car Audio Amplifier
Blown subs
HOW do you have it wired and what is the ohms rated on the subs
and is this amp bridgeable and at what ohms is it stable at
Do you have it Bridge to the subs to lower the ohms( Series or in Parallel)
Is the amp running hotter the normal and do you have it in a well ventilated are of your car/truck
Most car audio or at 4ohms and also is the subs dual
Autotek 7100 BTS series
99% of pots are off the shelf items.
See a tech with a parts catalog and a soldering iron.
Labor will far out price, the part.
Experience ain't cheap.
Regards, Sumthin
Jun 10, 2008 | Autotek MX3000.1 Car Audio Amplifier
Two channels (3 n' 4) with almost no sound and very 'statiky'
JFYI.
This is solved. Changed them 4 caps on the amp plus a blown diode. It's working like a charm now.
Feb 18, 2008 | Autotek Super Sport SS-600.4 Car Audio...
Autotek mean machine 200xi
fuse blown maybe? check the fuse(s) on the amp, and also on your car's dash for audio or acc maybe. And check the bubble on your battery.
Jan 30, 2007 | Autotek MX1500.1 Car Audio Amplifier
Autotek mx1500.1
i am a master audio amp repairman i am working on an mean machine mx 1500.1 the RCA inputs wer just worn out on mine,
but your problem is much worse your power supply is gone, all mean machine`s are CLASS X mind you NOT CLASS D basicly all that means is that the audio feads directly into one big power supply unit instead of having both an input and output stage.I recomend you find a web site or audio shop with a phone number
for the autotek corp. and have it sent in..DO NOT WORK YOURSELF
Maxxsonics Package: Autotek M4000.1d 4000 Watt Mean Machine Series Logo
Top Maxxsonics Car Audio & Video Experts
xxxxxx xxx
Are you a Maxxsonics Car Audio and Video Expert? Answer questions, earn points and help others
