Question about Garden
I just got a Amazon Sword Plant. How much lighting does it need to flourish in my aquarium?
    New Friend:
    Problem Solver:
  • 17 Answers
It needs minumum 2 watts per gallon of lighting (full spectrum), between 5000 and 7000K.
Posted on Jan 16, 2013
  • Justice Thounaojam
    Justice Thounaojam May 17, 2014
    And the duration should be between 5-6 hours per day(24 hours)
How can I remove my plastic aquarium plants without emptying the entire tank?
This can be a difficult process. Most often, the base of the plants are buried underneath the gravel/substrate. If you have an aquarium vacuum you can use it to help you pull out the plant from its base. If you do not have any tools to help you, your hand will have to do. Make sure to grab the plant from its base and pull gently.
Aug 29, 2012 | Alpine Fish
What should I consider when choosing a substrate for my live plant aquarium?
Substrate choice is a very crucial part of keeping living plants in an aquarium. Many species of plant life draw their nutrients from the substrate in the tank. The following are the most important factors you will need to consider:
Particle size - if too small the roots will not grow properly and if too large debris will get trapped inside.
Water reactivity - look for something inert
Price - most of the good products can become quite costly, but are well worth the expense
Aesthetics
Depth
Aug 28, 2012 | Aquaculture Fish
Do I need a heater for my substrate?
Absolutely not, it is a complete waste of money. Plant roots can get tangled in them and when you pull up the plant it will pull up the heater together with it and can destroy your plant.
Aug 26, 2012 | Aquaculture Fish
Why is lighting my aquarium is so important?
Proper aquarium lighting allow hobbyist to observe the fish in your aquarium. More importantly, proper aquarium lighting provides vital energy to photosynthetic plants and animals. Aquarium lighting is essential any system that contains photosynthetic organisms such as plant, corals and anemones.
Aug 21, 2012 | Fish
How much money should I spend on a Phillips Agro-Light tube?
The Agro-light is a new technology aquarium light which encourages plant growth by 10 percent at least, the average prices of agro-light tube by Phillips is starting at 60 dollars and can get up to 300 dollars.
Aug 21, 2012 | Fish
In which case it is recommended to use Plant Growth fluorescent Lights?
Plant growth lights are meant solely for promoting plant growth. Since these light are quite commonly used for houseplant you can find it in every hardware store. The price is a bit high ranges from 15-35 dollars.
Aug 21, 2012 | Fish
There are dozens of different fluorescent lights to choose from, how could I pick the right one?
A small percentage of the dozens fluorescent lights available are appropriate for aquarium use. You should look for industrial, daylight, plant growth, actinic or tri-phosphor fluorescent light.
Aug 21, 2012 | Fish
How can I properly determine the amount of watts per gallon of lighting I need for my aquarium?
How many watts you need depends on the type of plants and the volume of the tank. Here is an excerpt from an article that will help you determine proper wattage.
Instructions
Identify the species of plants you have in your tank or that you plan to put in your tank and how much light that species needs. Each species of plant will have an optimal lighting requirements, from low light to bright light. To determine the plant species, compare photos on the Aquarium Plants Photos and Profiles page of the Aqua Hobby website, or take samples of the aquatic plants to your local aquarium store for identification.
Write down how much lighting each of the plant species in your tank needs. Give each plant a rating of low, medium or bright. The books "The Complete Fishkeeper" and "Freshwater Aquariums for Dummies," as well as your local fish store, are good sources of information for this.
Review your list and determine what type of plant dominates your tank. For example, if you have mostly plants that need bright light, then use a bright-light formula. If you have an equal mix of plant lighting needs, then use a medium-light formula.
Calculate a range of watts of lighting you need for your tank with one of the following formulas, depending on the amount of light you determined you needed for your plants. For low light, multiply one and two by the number of gallons. For medium light, multiply two and three by the number of gallons. For bright light, calculate three and five by the number of gallons. For example, for a 20-gallon tank with plants that need medium light, you would get a range of 40 to 60 watts (2 x 20 = 40 and 3 x 20 = 60).
Read more: How to Determine Watts Per Gallon for Aquarium Lighting ' eHow.com http://www.ehow.com/how_8014286_determine-per-gallon-aquarium-lighting.html#ixzz23KB8HErA
Aug 14, 2012 | Fish
Should I turn the light off in the aquarium?
If you won a plant aquarium you should keep the lights on for 9-10 hours a day, try avoiding a direct sunlight on the aquarium which leads to a rapid growth of algae. Don't ever leave the light on for 24 hours because just like you the fish their sleep and it is very necessary in order to keep them alive.
Aug 02, 2012 | Fish
How long should I leave the lights on in my aquarium?
Theamount of time you should leave your aquarium light on depends on a number of factors. If you don't have plant life, I would saythat about ten hours a day is a safe average. However, not all fish take to light well so it depends on the type offish you have.
May 13, 2012 | Fish
Garden Logo
821 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
