Question about Shimano Cycling
Need bottom bracket for FCM570 crankset - Shimano Cycling
    Problem Solver:
  • 18 Answers
What kind of bike is that. you will need to look up brand on line and order it threw danscomp, a online bike shop or go in store buy new one you cant work on a cassette bottom bracket.
Posted on Jan 25, 2013
A squeak in my bike
Tyler lubricate bicycles chain, pedal bearings and pedal crank.
Check the attached links to see how some cranks come apart to lube,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bottom Bracket Inspect clean and lube
How To Overhaul Bike Bottom Bracket With One Piece Crank
How to Take Apart and Service the Bottom Bracket on Bicycle
Sealed cartridge Bottom Bracket crankset and pedal removal installation...
May 02, 2016 | Norco Cycling
How do I convert my Gary fisher Tassajara from triple crankset to single . do I need to change the bottom bracket and what crankset would best suit ?
You can get a bottom bracket with a shorter spindle in order to move the single chainring closer to the center of the bicycle. This will allow the chain enough leeway to move from high to low without affecting the chain line.
Any single speed crankset will suffice. It's a matter of budget.
Jan 05, 2015 | Gary Fisher Cycling
Bike serial number lookup
You can locate the serial number for your bicycle on the underside of your bike, near the crankset and bottom bracket area.
Aug 19, 2014 | Bianchi Cycling
Crank set replacement. Trying to replace the crankset due to a stripped crank arm. What crank is compadible to replace it with?
The only guarantee for an exact match width-wise is to use the same make and model of the crank you're replacing. A change in the given bottom bracket and crankset pairing will almost always yield some difference. Bike shops seem to have a way of determining a starting point for it but my own experience with them is that trial and error plays into it. If you change crank brands you may have to also change the length of the BB to get the same effective pedal dimensions.
http://www.parktool.com/blog/repair-help/categories/bottom-brackets
http://www.parktool.com/blog/repair-help/categories/crank-service
Sep 15, 2011 | Gary Fisher PreCaliber 24
Can you switch the crankset of a 2011 nevada to a 53 tooth crankset?
You can put just about any crank/chainring on any bike if the front derailleur will allow it. And that can be swapped, too. But not all cranks and bottom bracket combinations will give you the same chainline you have now. You should ask a Bike Shop for advice on that.
May 17, 2011 | Fuji Cycling
Right side pedal is "wallered
That would depend on the brand and design. A sprocket is literally a gear. A crankset is the combination of the crankarms and mounted gears. Bottom brackets join them within the frame.
http://en.wikipedia.org/wiki/Crankset
http://www.sheldonbrown.com/brandt/stuck-pedals.html
Pedals are replaceable.
A Bicycle Shop could help you decide what you need and select the proper size(s).
Mar 30, 2011 | Cycling
I have a Shimano SIS chainset on which has now done 3000 miles hence the teeth are wearng and requires replacement. I've tried using a chainset extractor tool but it will not budge. Is this the correct...
Let's see, chain, teeth and bottom brackets. Three different
I think you mean chain rings with worn teeth and you're trying to remove the crankset to get at the chainrings. Crank removal may not be necessary to change the outer rings. In my experience the most-used chainring is the only one that wears out fast. You may be able to just buy one or two rings, or a whole crankset may end up to be more economical, depending on where you shop.
Special tools are necessary for non-destructive removal of the cranks.
Find your style of crank and bottom bracket in here.
If your chain is that old that it's wearing the teeth your whole drive train will need replacement - chain, cassette and chainrings. If you keep your chain clean and lubed and replace it before it 'stretches' too much, your expensive drive train parts will last longer.
http://www.sheldonbrown.com/chains.html
Mar 25, 2011 | Cycling
The plate on my e-type is bending when pulling the line, making shifts unprecise. What do I do wrong ?
I am not quite sure what you mean by plate, but if you mean that the whole derailleur assembly is moving under tension, you have to make sure that the bottom bracket cups are tight.
To do this will require removing the crankset and following the installation instructions listed here. follow the directions for your brand of crankset (if Shimano, then Hollowtech II) under the bearing installation heading.
Mar 16, 2011 | Shimano Xtr Fd 970 E Type
I need the righthand crank and pedal
No one sells one side. Get the whole crankset. Match the original crankset exactly or you may have to get a whole new bottom bracket to macth the chainline because of different horizontal spacing. Special tools are required, too. A bike shop would be glad to choose the replacement and swap it out.
Ask them about the pedals.
Mar 06, 2011 | Mongoose MGX Maxim Dual Suspension...
Cycling Logo
51 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
