Question about Hotpoint Washing Machines
Hotpoint wml540 will not finish cycle after last spin and pumping water out all the lights start flashing and the door is locked and will not unlock until I switch the main power supply off . Can someone advise me what could be the problem . thanking everyone in advance for the help
Yozzer6821
  • 116 Answers
SOURCE: Door lock light flashing
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
Posted on Nov 09, 2008
SOURCE: Hotpoint WMA33 washer - door won't open
Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
Posted on Oct 08, 2009
  • 56 Answers
SOURCE: wml540
brushes on motor ? replace cost around £50.00 in total
Posted on Feb 11, 2010
  • 353 Answers
SOURCE: my hotpoint wml540 is not finishing cycle,the
check your motor carbons
Posted on Jun 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Hotpoint Aquarius WML540 washing machine
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
My Hotpoint BWM129 drains at end of a cycle but doesn't proceed to spin, fault lights flashing are rapid Door locked and intermittent Delay Start. Does this fault code indicate a faulty drain pump or
Engine fault or main board fault. Most likely main board.
Check cable harness from main board to engine. Check the carbon brushes on the engine. If its all okay, replace main board
May 21, 2014 | Hotpoint Washing Machines
Hotpoint WML540 gets to spin then stops wont empty and all lights start flashing
hi sharon, i had simular problem, if your waste outlet from your machine to kitchen sink is pushed on to sink waste sometimes held with jubilee clip, disconnect it and check weather its clear cos it can get build up of ****** and stop water from draining, hope this helps.
Jul 08, 2012 | Hotpoint Washing Machines
Hotpoint WML540 stops mid cycle, end of rinse going onto spin. Key lock light flashes, it also makes a banging sound as though washing trainers and then there are some clicking sounds before it stops. If...
maybe the concrete balancing weight has come loose and the fact that most of the water has been drained off when you turn it off for 10 seconds it does not have the one-sided affect anymore also check the damping springs as one may have come off in the violent spin eric
Dec 19, 2017 | Hotpoint Aquarius WMA42 Front Load Washer
My Hotpoint WML540 wont start wash cycle. The door lock clicks 4 or 5 times then the red door lock light flashes.
This sound like the main control board has blown and this is due to the motor shorting out, if you isolate the power supply and remove the control panel you will be able to remove the pcb/module and inspect it for signs of burning or split tracks if you find this is the case usually it is cheaper to replace the machine than purchase a pcb and motor.
Regards
Ian
Apr 20, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
I have a hotpoint aquarius extra washing machine. The door will not unlock, I have turned it of over night and it still doesn't unlock. I have checked that the water has drained and unblocked a sock from...
This would suggest that the lock is getting a signal from the control board telling it to stay locked, which would explain why the "spin light" is on as the control board does believes the cycle has not finished its in your signal board sorry
Dec 05, 2010 | Washing Machines
Hotpoint aquarius WML540, HAS JUST STOPED WORKING ITS ONLY OVER 1 YEAR OLD,WILL START ANY WASH BUT JUST STOPS WHEN IT REACHES THE SPIN AND DRAIN AND ALL LIGHTS START TO FLASH VERY FAST CAN YOU HELP.
Could be the pump blocked or not working, check the pump for blockages or wiring faults. For Hotpoint, Creda and Indesit error codes that include flashing lights visit selfix-uk
Mar 20, 2010 | Washing Machines
The final spin light is flashing and its not spinning the clothes
is the door locked light lit did all the water drain out(plugged pump) will it turn in the wash cycle (no, belt broke or came off)
Dec 08, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
I have the hotpoint BWM129 super silent 1200 spin, recently the machine has stopped draining water even after spin cycle has finished , I also have constantly flashing lights which are super wash and delay...
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Feb 18, 2009 | Hotpoint BWM12 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
