Question about Philips 42FD9954 42 in. Plasma HDTV
47 Ufd, rated @ 450 volts - Philips 42FD9954 42 in. Plasma HDTV
    Top Expert:
  • Philips Master
  • 74,136 Answers
It can be bought from most of the electronic spare part selling shops at your town.
Posted on Jan 16, 2013
Mitsubishi DLP WD62725 TV after powering down the timer light say blinking till unplug it then reset it to turn back on can any one help me
Good Day,
More than likey you have bad caps on DM Board.
It willcost about $450 to repair or you can do it yourself,.
On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V,
The DM PCB is on the left hand side of the TV when you take off the back cover.
Good Luck, BIG IRISH,.
Dec 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Start up problem
Bill;
Cause 1
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB.
2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Replace all these if they look bad or not. If you can't do it yourself call a service Company and get an estimate, it should cost about $450 if they know what they are doing.
Thanks using FixYa, Big Irish.
Nov 21, 2009 | Mitsubishi VS-50705 50" Rear Projection...
42FD9954 philips plasma TV flashing LED it wont come on
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Nov 08, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Pioneer pl 50 turntable it is turning too fast ,there is no adjustment.Is there a solution
I brought my turntable in a repair shop. Don`t know if it will be fixed. If not ,I will use your technical support. thank you Alain
Oct 14, 2008 | Pioneer Audio Players & Recorders
Good Day, skieebumm;
There no adjustment. Try this: (MENU DOES NOT ROLL) CHECK C2A04, 10 UFD 50V OFF PIN 5 OF IC2A01 ON THE VIDEO PCB. 2. CHECK C2046, 47 UFD @ 50V OFF OF DL2001 ON THE VIDEO PCB. 3. (MENU DOES ROLL) CHECK C2B14 10 UFD @ 50 V NP OFF THE BASE OF Q2B02 ON THE VIDEO PCB. Good Luck, big IRISH.
Sep 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi CK-3526R (PIP model)
GOOD DAY; 1. CHECK C218 4.7 UFD 50 V, AND C220 47 UFD 35V ON THE SIGNAL PCB. 2. CAN BE OBSERVED AS DISTORTION ON DC PEDESTAL PORTION OF STAIR STEP PATTERN. SUSPECT C222 OPEN. LOCATED ON PCB-SIGNAL AT IC200 PIN 35. (10UF 35V) 3. SHOWS UP ON COLOR SIGNALS ONLY. OK ON B/W PICTURES. CHECK X600 AT IC200 PIN 13. SHOULD BE 3.58MHZ. LOCATED ON PCB-SIGNAL. PT# 285P02905 4. (COLOR LINES) CHECK C601 47 UFD @ 35V ON THE COLOR CONTROL OFF PIN 36 OF IC200 ON THE SIGNAL PCB. 5. SUSPECT C222 OPEN. LOCATED ON PCB-SIGNAL AT IC200 PIN 35. (10UF 35V) . REMOVING CRT SOCKET, YOU MAY HAVE CORROSION ON THE PINS OR POOR CONNECTION ON CRT BOARD, AND BY REMOVING IT COULD HAVE CLEANED THE PINS A LITTLE. TRY CLEANING PINS ON CRT AND SOCKET. GOOD LUCK, big IRISH.
Aug 16, 2008 | Mitsubishi WS-55807 TV
Split screen and dark colors
Good Day, scharania;
Try all of these: 1).HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB. 2). CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. 3).
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. Good Luck, big IRISH.
Jul 30, 2008 | Mitsubishi VS-50605 50" Rear Projection...
VERTCAL HOLD
Good Day, marvy21; try theses ideas, they will fix the TV # 3 is most common, you might start there. 1). VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.2). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. 3). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. Good Luck, big IRISH.
Jun 10, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Check C2p05 100 Ufd 16 V Off Pin 3 Of Ic2p01 (9-Volt Regulator) On The Signal Pcb. Check C2p08 100 Ufd 16 V Off Pin 3 Of Ic2p03 (3.2 Volt Regulator) On The Signal Pcb.
Bill
Dec 16, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubshi 32 inch cs-31303
on the A/V PCB . Check C206 33 UFD 16 V off pin 17 of IC201 on the A/V PCB. Check C207 47 UFD 16 V on the A/V PCB. Check C211 47 UFD 16 V on the A/V PCB.
Sep 21, 2007 | Televison & Video
Philips 42FD9954 42 in. Plasma HDTV Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
