Question about Sunbeam Heritage 2346 Stand Mixer
Taking Sunbeam Mixmaster Apart
I have the Sunbeam Heritage Series Mixmaster and almost as soon as I bought it, the bowl turning mechanism quit working. I took the turn table off and used the mixer without. It is no longer on warranty and the gears are stripped. I tried to take the unit apart so that I could replace the stripped gears, but I can not get it apart. Does anyone have any tips?
SOURCE: Sunbeam Mixmaster Heritage series
I hope this helps. I found on mine that the rear screw on the "neck" had become slighty loosecousing the release to not fully disingage. I had to remove the dome shaped cap in the middle of the speed control knob, pops off fairly easy, to gain access to the nut to tighten it. Hard part was trying to hold the screw head still while I used a small screw driver and small hammer to tap the nut tight, very limited space between the "neck" and motor body.
btsctn
Posted on Oct 22, 2008
  • 4 Answers
SOURCE: Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Posted on Dec 16, 2008
SOURCE: bowl revolving turntable of sunbeam
http://www.householdappliance.com/turntable_chart.html
Posted on Dec 11, 2008
SOURCE: Sunbeam Mixmaster Heritage series mixer
Ok um.... did you read your warranty? If you had you would see that this model has a two year warranty.
If you simply called 1 800 458 8407 and told them the problem, they would file your claim and then tell you to cut the plug end off of the cord and send it (Not the unit) along with a copy of the receipt for replacement. They will then send you a brand new unit in the mail to your home. You get to keep everything, including the original unit!!. Now you have double everything (Bowls, Beaters....Mixer) That is a awesome warranty.
Posted on Dec 22, 2008
rylee_smith
  • 8619 Answers
SOURCE: Sunbeam Heritage Mixmaster Won't Tilt
Hi
Most of them have a button to push that releases the mixer head to tip back. Sometimes the buttons stick and will not release. That picture looks like you are using the Heritage model.
You have to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; tighten it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer you may also notice that the tilt release had become easier to use -- previously you may have found that you have to press the tilt release button very hard to get the tilt to unlock.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 12, 2009
Beaters will not turn
This will definitely be a problem with the actual beater gearbox unit inside the front and under the top handle of the machine.
I've had my wifes one apart and it was difficult at best to even do that, so my recommendation is to take it back to the shop if it is still in the warranty period.
If not, take it to a small machine mechanic and get a Quote for repair before anything is done as it's quite likely that the repair will cost as much as a new mixer.
Mar 20, 2014 | Sunbeam 2346 Heritage MixMaster Series...
Bowl does not rotate anymore
This is typical of Sunbeam mixers. The solution is to throw that piece of junk out and never buy anything from Sunbeam again. They can't stand behind their products because they know they are junk. They would go out of business if they tried to repair/replace all of the useless appliances they sell.
Oct 24, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Bowl wont rotate
My Sunbeam mixmaster bowl won't turn, how can I fix this?
I believe that this particular model is supposed to have the bowl mix separately. I have removed the black piece from the bottom of the larger bowl in order to allow manual spinning. If I am able to figure out how to fix the bowl spinner I will make another post.
Mar 06, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Beaters won't turn bowl still does turn
I just took mine apart for this same issue. What i found was the plastic beater drive gears have been stripped by the motor worm gear. I am currently looking for these parts to replace them.
Dec 28, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Why does my sunbean mixmaster bowl don't spin?
the spinning plate under the bowl does not have any power to spin the bowl; it only aks as a "lazy susan" carousel that allows the bowl to turn from the movement of the material being wipped in the bowl.
the beaters are purposely off-center of the bowl in ordwer to create a dragging motion of the material in the bowl, thus pulling (that is, spinning) the bowl slowly. If the beaters are not off to the side of the bowl, you will not get the pulling/spinning motion. Also, if the plate under the bowl does not move very easily, then the bowl will not spin. You may have to remove the spin plate and clean the center pivot for the plate to move freely. Good Luck, Macgivor.
Nov 27, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Motor head will not tilt back
Push down slightly on the head and then the button will go in further and the top will release. ((this answer after I just bought it home and was about to take it back to the store!!))
Oct 11, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam Heritage 2346 Stand Mixer Logo
985 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
