Question about Cutter Tools
What are the advantages of using a pipecutter over a hacksaw?
  • 75 Answers
Pipecutters are faster, cleaner, more convenient, easier, and provide a cleaner cut. the only advantage of using a hacksaw is if the pipe is too big for the pipecutter to get around it
Posted on Jan 16, 2013
What does a spark plug gap at
hi, your spark plug gap should be the thickness of a hacksaw blade. use a hacksaw blade. sheers
Mar 14, 2014 | Craftsman sears 18" Chain Saw Chain (...
Tip
Choosing the right hacksaw for your job
For every project that you want to work on, there will be a different set of tools that you will need to use. The hacksaw has different types of blades and frames that can be switched out for the different projects that you are working on.
There are three main kinds of blades that the hacksaw can use and each one has different benefits. The teeth on the hacksaw blade will range between 14 and 32 teeth per inch. The thicker the blade the fewer teeth there will be per inch on the blade. The types are regular, raker and wavy. Regular blades are good for soft metals that don't have a lot of metal and the teeth will be closed together touching and alternating left and right. The raker blade has teeth placed in sets of threes and are best used fro cutting through thick metals. The last kind of blade is called a wavy blade, on these ones the teeth are in a wave pattern that are great for making smooth cuts in hard thin metals.
When it comes to hacksaw frame types there are two types to look at the fixed frame and the adjustable frame. Fixed frames are only able to hold a blade of a single sized length of blade. The adjustable frame can hold different length blades typically between 10 and 12 inches. The blades that you will buy for a hacksaw will have holes on either end of the blade. These holes are used to attach and dettach the blades from the frame.
Whatever the blade that you are using make sure that when you are sawing through metal make sure that you go slow because rubbing metal on metal will generate a lot of heat and can spark. You can also ruin the blade on your if you are sawing too quickly.
on Feb 02, 2014 | Saws
Can I use a hacksaw for cutting metal?
Of course you can! That is one of the most common uses for a them!
Jan 02, 2014 | Saws
Are there different types of hacksaws?
They aren't really different types of hacksaws, they're more like variations of the traditional hacksaw. There is the panel hacksaw, junior hacksaw and the power hacksaw.
Jan 02, 2014 | Saws
What are the holes on the ends of the blade of my hacksaw?
These holes are used for mounting the blade in to the frame.
Jan 02, 2014 | Saws
Am i better off using a hacksaw or a pipe cutter to cut the metal pipe that runs through my garden?
Although pipecutters are generally seen as giving a much cleaner and better cut than hacksaws, they are a bit limited in what they are able to cut through. Hacksaws however can cut through all sizes of plastic and metal.
Dec 26, 2013 | Cutter Tools
Whats the difference between a hacksaw and a panel hacksaw?
a panel hacksaw has no frame, so it is better for use in cutting sheet metal
Jan 28, 2013 | Saws
Should i use my pipe cutters on very thin or small metal piping?
no, it will probably be easier and better overall to use a sharp pair of pruning shears. if you dont have any good shears, you can use pipecutters
Jan 16, 2013 | Cutter Tools
Remove broken key from egnition
Hi
Use needle-nose pliers to pull the broken key out, if there is enough of it sticking out of the ignition to grab. Put a little melted wax, Museum Putty or Super Glue on the pliers before you grab the key.
Make sure that the ignition is in the "neutral" position so that the tumblers are not gripping the key. If it is in the locked position, insert a thin hacksaw blade--with the teeth facing up--next to the broken key, and turn the ignition to the "neutral" position.
Pull gently up on the hacksaw blade. If you are lucky, the teeth will grab the key and slide it out. Try this with the hacksaw blade behind the key, and again on top of the key. Most keys have a groove on them that the hacksaw blade can grab, so wiggle and twist the hacksaw blade around and see if you can feel it catch the key.
Try using the hacksaw blade and the pliers together--pushing with the blade and pulling with the pliers.
Cut or break a six- to eight-inch piece off of a wire coat hanger and use your pliers to fashion a small hook at the end. Slide this into the ignition behind the key and try to grab it. If that doesn't work, insert the wire in front of the key and try again.
Spray a little cooking spray or WD-40 into the ignition and try again with the hacksaw blade. Remember to try both in front of and behind the key, and to wiggle the blade. Do not spray the lubricant before trying the pliers or wire, because now your key is not only stuck, it is slippery.
Call a locksmith if the above steps do not work. Do it before you get too frustrated, because it is much cheaper to replace a key than it is to replace a key and a shattered ignition.
Also check this useful link:-
http://www.diylife.com/2010/06/24/the-daily-fix-remove-a-broken-key-from-a-lock/
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 23, 2012 | 2002 Kia Spectra
Cutter Tools Logo
858 people viewed this question
Top Cutter Tools Experts
Joe Garcia
Joe Garcia
Are you a Cutter Tool Expert? Answer questions, earn points and help others
