Question about Lenovo 3000 C200 8922 - Celeron M 420 1.6 GHz - 15in. TFT (S6420812) PC Desktop
When laptop charging in off position and if i connect usb pen drive, ext. HDD, etc. these are on and flashing
  • Lenovo Master
  • 7,627 Answers
Your computer is Sleeping or Hibernating. Shut down the computer by pushing and holding the on off button.
Posted on Jan 16, 2013
I cannot get my cruzer glide flash drive to open up and let me access it on my Windows 7 which is an emachines
As the pen drive works fine on your laptop there is no problem with you pen drive the problem is with PC, Formating the PC might solve the problem
Jul 01, 2013 | SanDisk SDCZ60-008G-A11 8gb Cruzer Glide...
Tip
Windows 7,Linux and other OS install from USB Pen drive, Flash Drive
To Install Windows 7 via USB Flash Drive (Pen Drive)
You need:
USB Flash Drive (Pen Drive) minimum 4 gb for windows 7
Windows 7 ISO image file.
UNetbootin software download from here UNetbootin
Download the Unetbootin software, and open the file and click "RUN".
below window will pop
You can aslo install other OS's like linux etc etc. for Windows 7, click "Diskimage" radio button, locate or browse the ISO file of your OS by clicking "..." button.
select Drive: (in my PC usb drive is "I:" and press OK.
Next window looks like below picture
Wait till Installation Compleate.
after compleation. Click "reboot" to install to the same PC, or remove the Flash drive(Pen drive) and plug it to another PC or Laptop USB
and boot that System by USB Flash drive.
To do this Select the USB boot option from the BIOS. Or to boot from USB go through your Motherboard User Manual.
This method works on most of Machines with USB booting option.
I personally installed 100's of PC's via this method
thank you. Keep smiling. aaarwind
for other OS setup's via USB drive refer to below Website:
UNetbootin - Homepage
on Jan 20, 2011 | Computers & Internet
Is the laptop off or Hibernating? Sleeping? Open the Control Panel, Power Options, Set to High Performance, open Advanced Power settings, set Hibernate and Sleep to Never. Shut down the laptop at the Start Menu. If the AC cord is plugged in the battery will charge. Nothing else should work.
Jan 16, 2013 | Lenovo 3000 C200 CM 520 1.6G 512MB...
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I cant format my C400 with a pen drive
If you're tryng to format the HDD on a Dell latitude C400 (or install an OS), this thing will not boot to any USB devices (flash drives, pen drives, external USB cd-rom drives, etc.) - just ain't gonna happen since the BIOS doesn't support such boot devices. The only thing it'll boot to is (1) docking station, and (2) a Media Bay optical drive.
Sep 01, 2011 | Dell Latitude C400 Notebook
My computer don't see mt toshiba 500 GB external disk. I had Win XP with SP3 and my external disk is connected to a USB hub with 8 ports. I had a pen connected to that hub and the computer see it. But...
Your USB hub cannot provide enough power for your external hdd, you can try to plug it in directly to any free USB port for the mean time to check if its detected or not, if it has a power button ( which is not normal for regular USB powered EXT HDD) make sure that it is on, if its still not working try to use a different cable, a known good cable or plug it in to a different computer to check if its your USB port, or the usb cable or the ext hdd that is causing the issue
Hope this help.
Jul 10, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
How to repair my pen drive????? when i connect my pen drive with my laptop a message is shown ''not recognized USB Port'' . so, how to start my pen drive? plz rply your answer......
if its in warranty replace it give me ur pen drive details like s/no , etc.... ill help u to get new 1 dont worry now in this state of drive u cannot do any thing its a hardware error the memory ic has been damaged so only option left is company mail me prince2parag@gmail.com for more support visit my site neotechcomputers.co.in
Jul 05, 2010 | Kingston 4GB Secure Digital High Capacity...
No manual for 320 GB desk top hard drive
its a plug and play just connect to the sys and start working on it
but be careful that u connect the power to the Ext.HDD first and then after that connect it to the USB port
similarly safe remove from the Sys and remove it only after u see the msg It is safe to remove the USB drive disconnect the USB cable from the Sys wait for 20-30 secs ten power off the HDD for better performence of the Ext HDD
Jul 27, 2009 | Electronics - Others
Lenovo 3000 C200 8922 - Celeron M 420 1.6 GHz - 15in. TFT (S6420812) PC Desktop Logo
22 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
