Question about Janome Sewing Machines
Janome 9000 carriage not moving when starting embroidery
Stitching in one place only as carriage not moving
bargainbox
  • 1388 Answers
SOURCE: janome 9000
Remove the needleplate and clean out the lint from between the teeth of the feeddogs........it is the most likely reason, the lint holds the feeddogs below where they need to engage fabric.
Check your Presser foot tension is at 3 then do a test.
If this is not sufficient the method of adjusting feeddogs is possible at home, tho perhaps not for those lacking some confidence in mechanical adjustment.......so post back for detail if needed.
Posted on Jul 31, 2008
  • 1170 Answers
SOURCE: instruction manuals/user guides
Manual for Janome 9000 is available from the Janome site.
http://www.janome.com/documents/File/Man...
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Posted on Apr 02, 2009
SOURCE: The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Warning - undertake this fix at your own risk as it will probably invalidate the warranty.
The problem is a bad connection inside the embroidery unit - there is a small plug that joins four sets of wires that comes loose.
1) disconnect the embroidery unit
2) Turn the unit over and remove the posidrive (crosshead) recessed screws on the bottom. ONLY remove the recessed screws NOT the ones holding the catch to hold embroidery unit to machine. ALSO DO NOT remove the one screw that is different (it has different head that allows a flat screwdriver as well as a posidrive)
3) Carefull turn unit back over
4) With the enbroidery unit facing you there is a screw facing you in the white cover of the hoop holder. Remove this screw and carefully remove the plastic cover.
5) On the underside of the hoop holder nearest you there are two black screws that are undone with an allen key. Remove these (they allow the main cover to come off
6) Pop out the long plastc cover under the hoop holder (where the ting moves back and forward)
7) Pop out the section of cover behind this that is now loose.
8) Carefully tease off the main cover. IT will come with patience and by moving the embroidery arm back and fortht to give space. DONT FORCE IT.
9) You will see the rails running left to right that the hoop holder moves on. Under these you should see four wires, that are joined to four other wires by a connector.
10) Wobble the connector to get them to connect again
11) Connect the embroidery unit to the machine and switch on.
12) If the carriage goes to the start position you have restored the connection. Secure with insulation tape
13) If not switch off, wobble, switch on unitl it works
14) Disconnect and replace covers.
Good luck. This sorted out our machine that just moved the carriage the wrong way and flashed red 88
Posted on Aug 27, 2009
bargainbox
  • 1388 Answers
SOURCE: Can the main touch screen be replaced for the
Yes, the touchscreen can be replaced, but is unlikely to be a problem, will be replaced FOC if within 5 years of purchase. A dimming screen is the LCD Backlight not the screen itself. Depending on your location, your country's supply of parts should last for many years, subject to demand, as with anything. .....but eventually they will become depleted Try eBay as a shopper to see the current value of your machine in the market.
If you would like me to send you the Diagnosis Chart for testing operation, please contact me HERE, just make sure you specify the nature of request and the model you refer to, as many requests arrive daily.
Posted on Sep 10, 2009
Testimonial: "Thank-you very much, I appreciate this information."
SOURCE: the carriage on my Janome 350E will only move left
When my janome 350e did this I had to take it in to be calibrated and one month later it did it again and I had to take it back it has not given me any problems since but it would be nice to know how to do this myself it only took 5 minutes for this and takes me 3 hours there and 3 hours back. Hope this helps.
brenbb@skywayusa.net
Posted on Jan 12, 2010
Will the premier embroidery System work on my janome 9900?
Hello Maria
The Premier Embroidery System software is compatible with all sewing machine brands.
Once an embroidery design whether created or downloaded can be saved in various embroidery formats. You can save the design as .jef and use it in your Janome embroidery sewing machine. If the same design is saved in other formats, it can be used in other sewing machine brands.
The Premier Embroidery Software is amazing.
Please let me know if this is helpful.
Happy stitching
Mar 03, 2017 | Janome Sewing Machines
Janome 9700 embroidery machine carriage
sadly that looks normal to me . it is the frame holder for the embroidery machine
Aug 03, 2015 | Janome Sewing Machines
Free hand stitching
Drop your feed dogs, remove your normal foot... replace with embroidery or darning foot... or leave without a foot. stretch fabric in a hoop..... set your stitch.. and sew as you move the hoop.
Jul 25, 2012 | Janome Memorycraft 6500P Computerized...
Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
Mar 29, 2012 | Janome Memory Craft 9000 Computerized...
How do I attach my embroidery foot to my Janome 8080?
if its like the 8000 and 9000, you unscrew the metal part that clips onto the foot, and attach the plastic embroidery foot ( P?) instead. It does not just clip on like other feet. the screw holds the embridery foot in place
Sep 17, 2010 | Janome 8080 Computerized Sewing Machine
Does this machine have a low shank --- or high shank?
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop
Bargain Box
Apr 19, 2010 | Janome Memory Craft 9000 Computerized...
I want to sell my 1991 New Home memory Craft 8000 sewing machine
A good place to see what machines are selling for is Ebay. That's where I sold a sewing machine and an embroidery machine.
It helps to know your product and machine embroidery lingo.
What are cassettes? Floppy disks? These make the machine borderline obsolete.
Memory cards are still around, but most EM now have USB connectivity or USB flash drives.
Satin thread? Embroidery machines use Rayon or Polyester embroidery thread.
Having had the machine recently serviced is also a plus.
Mar 19, 2010 | Janome Memory Craft 9000 Computerized...
My Janome 10000 stopped in middle of embroidering a design and the machine rebooted. it was making a bit of a whining sound as it was stitching just at the last..but now the hand wheel seems harder to...
Janmore10000 Stopped Embroidering thenstopped everything just shutting off.
If it is getting no power at all, it is probably a fuse. Thefuse is located in a little black box underneath the base of the machine, butit is NOT an easy job to take the box out, disassemble it, replace the fuse,and then reassemble the whole machine. But in your comment you mentioned that there is power tothe machine that means its not fuse problem.
It stopped embroidering in the middle of a project. the handwheel would notmove at all this means that it wasthread jam. Also check the carriage carriage if it does not move to the rightor left and gor stuck in one position or hardly moving a bit then it is out of calibration.
if your machine is outof calibration it will need to recaliberate . Something is like forcing theneedle through a thread jam would cause this. This is not an expensive repair.But a time consuming repair. Its advisable to get it done by service center,
click this linkdirectly to get the support center help
http://janome.com/index.cfm/ContactUs
This will help. Thanks please keep updated. please dorate the solution positively .thank you for using fixya.
Nov 29, 2009 | Janome Memory Craft 10000
WHERE IS THE FUSE FOR THE JANOME MEMORY CRAFT 9000? THANK YOU
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the bottom to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
Jul 11, 2009 | Janome Memory Craft 9000 Computerized...
JANOME MEMORYCRAFT 8000 STEPPING MOTOR ERROR
if you ever have this problem, it is because you have had something in the way of the embroidery arm at the back of the machine, so it has not been able to move freely; you'll get a terrible noise as the machine is unable to do what it wants, slips gears or something and then can't bring the arm to its home position. But fear not, i have found if you turn the machine off and gently push the arm back home to touch the machine as it is the start position, when you turn it on, it will work fine and no harm done. just make sure the arm can move freely before you start embroidery!
Jul 11, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
