Dell inspiron n5010 sound problem
I have dell inspiron n5010.this lptop's intrenal left speaker has no sound while internal right speaker has sound.when i connect hadphone.headphone's both speaker have sound.i disassembeled laptop and checked internal left speaker.it is in working condition.plz tell me its solution
  • 7,627 Answers
Maybe A loose connection?
Posted on Jan 16, 2013
  • 3940 Answers
SOURCE: Internal speakers do not emit sound but I can hear w/ headphones
I have a 700m, so I'm real familiar with the system. I see one of 2 possibilities. The headphone jack has a switch that disables the on-board speakers, if that is stuck or broken, then the jack/switch must be replaced. (Big hassle)
The other is easier to troubleshoot, then connection from the speakers to the MB goes through the Right hinge cover. Take the hinge cover off, check for broken wires (I has one, ***** to splice too)
Posted on Jun 05, 2009
Pyrhyc
  • 2028 Answers
SOURCE: Dell 610 lptop - haedphone not working,
First try uninstalling the sound drivers from the device manager, then reboot. It will find and reinstall them, then check Dell's support site for updated sound drivers. If you find updated drivers you will need to use the update button for the device in the device manager. If this doesn't work, then it may be a faulty headphone jack. The jack should override the speakers when the headphones are plugged into it. If you can still hear the speakers with the headphones plugged in then the jack is faulty and needs replaced. If the jack does override the speakers or if you get some static then it could be that the jack has come loose or has a loose or broken wire. The only other thing is try a different set of headphones, sometimes laptops get picky and one set will work and yet another set may not.
Posted on Jul 02, 2008
  • 3940 Answers
SOURCE: sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Posted on Mar 02, 2009
  • 50 Answers
SOURCE: Turn on my laptop A dell Inspiron B130. Found to
click on the "mixer" on the bottom right next to speaker, click device, and change the check to "speakers" (if vista).
Posted on Jun 16, 2009
  • 6771 Answers
SOURCE: my dell inspiron N5010 's
The problem is in the earphone jack, when you plug headphones into the jack it dis-connects the internal speaker. Since you can hear the sound through the head gear, it indicates the jack is defective and needs to be replaced, or it needs a good flushing of electronic contact cleaner, attach the supplied straw and aim it in the jack and spray, next take the headphone jack and push it in and out quickly, repeat the process three or four times, If this fails the laptop will need to be dis-assembled for continued repair.
Posted on Jan 21, 2011
Internal Speaker not working properly suddenly. Hearing Ruptures along the voice.
If you have been using your computer with the audio on full you will probably have blown the speaker cones. An easy fix. Add some external speakers.
May 21, 2013 | Dell Inspiron N5010 Black
My N5010 dell laptop battery won't charge anymore. Could I just need a new battery, or charger, or could there be something else going on internally that I need to know about? For the most part, I
If your laptop is still under warranty, contact dell and they should be able to fix it free of charge, The same thing happened to my laptop a few years ago and fortunately, it is still under warranty, The fault is the charger itself which dell replaced free of charge.
Jun 26, 2012 | Dell Inspiron N5010 Laptop Core I5...
There is nos sounds in headphones and the laptop internal speakers in dell inspiration n5010 laptop
Hi sabdulla1974...
Try this solution to your problem.
Look for the speaker icon on your desktop in the right bottom portion of the sceen.
Also when you find it, RIGHT click on it, you will have two choices to make, choose and check each one of the choices to make sure that NONE of the boxes on each
choice has a checkmark in Mute,if there is a check mark then uncheck it.
NOTE:In "Open Volume control: you will find slider to adjust for volume,Wave,CD Player,etc.
After that is down, then LEFT click on the speaker icon and make sure that the slider is all the way to the top and that the Mute does not have a check mark,if it does remove the check.
If that does not work then re-install the audio driver for your computer.
Please take time to rate me thumbs up
Dell Inspiron 1525 drivers:
http://dell.driversdown.com/dell-drivers-list/s_482_1.shtml
Sep 23, 2011 | Dell Inspiron 1525 Laptop
MY SPEAKERS ISN'T WORKING DELL INSPIRON N5010
hi, check yr sound driver in system properties, look at your sound driver, if have yellow exclamation mark that mean your need to reinstall yr sound driver,
if not try use external speakers and see what result
TQ
Aug 05, 2011 | Dell Audio Players & Recorders
Drivers for dell inspiron n5010 for xp
To get the correct drivers for your Dell Inspiron n5010 I suggest you go to the link below. This is the Dell Driver download page. You'll notice that you have 3 options for getting the correct drivers for your computer. The best option is to enter your "Service Tag" number. Usually this is located on the bottom of your computer.
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
Mar 03, 2011 | Home
Can anyone suggest a wifi driver for dell inspiron n5010 lap?
Hi Dear here is the collection of N5010 XP Drivers you can havit here. If it works fine say thanks for us.
Link:
http://www.a2zdrivers.co.cc/2011/04/dell-inspiron-n5010-xp-drivers.html
Feb 28, 2011 | Dell Computers & Internet
My dell inspiron N5010 's internal speaker is not functioning..but i can hear through my head phones
Jan 21, 2011 | Dell Inspiron 1525 Laptop
Muted sound from left speaker, no sound from right speaker
try uninstall/reinstalling audio driver. if it fails contact Dell tech support possibility that the internal speaker is already loose/broken.
May 25, 2009 | Dell Inspiron E1505 Notebook
Computers & Internet Logo
214 people viewed this question
David Payne
David Payne
