Question about Garden
Hitachi digger wont stop running
Key turned off, engine still running, can't find a kill switch
    Top Expert:
  • Garden Master
  • 45,551 Answers
Check for a continuous power supply to the solenoid in the fuel pump that shuts off the fuel. It is usually spring loaded and shuts of a hole when the solenoid power is turned off.. Check solenoid is working properly
Posted on Oct 07, 2013
Why doesyamaha dt200r start but not stop 1993 model dt200r
sounds like slide in carb is stuck open could possibly be in backwards if ignition switch is wired correct it should kill engine
May 15, 2014 | 2000 Yamaha DT 125 R
A safety feature appears to be stopping my mower from turning over
You will have at least 2 safety switches. One is the clutch/brake pedal activitated and the other is the seat switch. It sounds like the clutch/brake pedal switch is not allowing the starter to engage the flywheel and start the mower. Check for the switch under the footrest or near the back of the mower. Should be easy to find. Check it with an ohm meter and verify it is working. you could use a wire with 2 aligator clips to jump the switch but dont make this a permanent solution. Replace the switch if it is bad. One thing to consider is the ignition switch. Since you can jump the solenoid and the engine turns but wont run, you may have no power to the ignition/coil to fire a spark to the sparkplug. You need to turn the key to RUN and then jump the solenoid to confirm this. I think it will be one of those as the seat switch only kills the motor if the deck is engaged and the seat raises up. Let us know.
Apr 07, 2012 | Husqvarna Garden
When i try to start me 2008 sonata the alarm goes off and the engine will not turn over. what can i do?
Your Sonata is equipped with a "Keyless Entry & Burglar Alarm" system. When the Burglar Alarm is activated, it KILLS the starting system through the used of a relay called the "Burglar Alarm Relay". This mode prevents engine starting with the key.
Solution #1
Disarm the system with the Keyless Remote (key fob) If you don't have this remote (or its battery is dead) replace the battery & try disarming again.
Solution #2
Enter the vehicle & insert the key in the ignition and turn the ignition switch to 'RUN'. Wait 3 to 5 minutes until the alarm stops. You should then be able to start the engine.
Have a qualified/certified Hyundai Service Technician properly diagnose this issue.
Sep 07, 2011 | Hyundai Motor 2004 Sonata
The engine is a 12ht turbo diesel 85 modle hj61 land cruiser. engine will start, the base idle is low and runs rough RPM aprox 600. wind up base idle with idle screw to 1000 runs good but u can take turn...
Check to see stop solenoid is working, you may be able to do this by getting someone to turn the key on and off slowly while you are hold your fingers against the side of it.
It is the small metal (Nut) with a wire going into it for an easy description.
The reason you have to choke the engine to stop it is you have either no power going to the switch or the switch is not working properly. i would think more that the switch may not be working properly as it is meant to close fully when power is turned off, if this was working it doesn't matter how much the motor is reving it will still shut of the fuel to the pump.
Sometime these solenoids get a bit of dirt etc stuck in them s well, this is usually just a easy fix,clamp the rubber fuel line before the pump, undo the switch, clean it and refit it, then undo the clamp and prime the pump using the hand primer.
Then start the vehicle, don't try to start the vehicle before you have reprimed the pump as you can damage the engine if you don't have fuel going into it.
Hope this helps, and good luck with it.
Dont rush working on a diesel, just take your time mate.
Jul 23, 2011 | 1989 Toyota Land Cruiser
2000 hyundai elantra alarm goes off where is the
There is NO kill switch on the 2000 Elantra... HOWEVER, there is a thing called the Key Fob (keyless remote entry system). There is, however, a system in place called the 'starter kill' circuit and it is activated when the burglar alarm goes off.... it's called the burglar alarm relay and it is activated to prevent the engine starter system from being used. There are three ways to get the engine started in such a circumstance... 1. use the key fob to 'disarm' the system... 2. put the key in the ignition and turn it to the 'RUN" position and wait until the alarm stops (horn stops beeping and the parking lights stop flashing), then the engine will start.... 3. pull the starter relay from the UnderHood junction box and bypass the starter circuit (key in ignition and in the 'RUN' position), jumper the starter solenoid circuit to energize the solenoid to start cranking the engine -- it should start then.
Oct 03, 2009 | 2000 Hyundai Elantra
Turn ignition key to lights and kills motor
faulty ignition switch...remove and test
Oct 01, 2009 | 1977 Yamaha XS 500
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
