The times bridge program will not install on vista bought as a present
Prog not suitable for vista bought as a present. not told on purchase
  • 2,878 Answers
Installing the programs made for another version of Windows may cause problems. Vista may have a right click option to install as XP.
Posted on Jan 17, 2013
How can I install with out errror's
Little info? Is the Roxio version compatible with your present windows prog? Try to download an update. but first try following
Think I know what you are saying!
Restart puta, leave Broadband switched off!. any auto programs that startup, turn off, so little is working or waiting instruction.
Re-install prog you wish to load!
May 26, 2011 | Roxio Easy VHS to DVD for PC
I bought a utilitech three outlet outdoor timer and cannot get it to set. Now I cannot seem to find the instructions that came with it. Where can I download the instructions?
I bought one also but am taking it back today as I am not satisfied with the performance and the internal battery dies losing all programming. The instructions below are word for word from the manual but not all that clear. Since I can't post the diagram from http://www.thencc.com/westinghouse/LS/Instruction/T28499_TimerManual.pdf (if I can post links here), I substituted words in the "Set Mode" section instead. This is for the Utilitech 0149289 model and also applies to the Westinghouse and Stanley equals. Good luck.
3-Outlet Photocell
HEAVY DUTY OUTDOOR TIMER
Tri-Mode Digital Timer
3-Wire Grounded Outlet and Plug
6 in (15cm) AWG 14/3 SJT vinyl cord
Rated: 125V/15A/1875W Tungsten
60Hz
INITIAL USE:
Before initial use, please plug in your timer for at least 1 hour to charge the internal battery. After the LCD display appears, your unit will be ready for programming.
RESET:
Press the "+" and "-" buttons at the same time to reset your timer. This will clear all programmed settings.
SET CURRENT TIME:
Press and hold the "TIME" button to enter the current time. First, set the day of the week: press "+" or "-" button to set today's day.
Press the "TIME" button to enter the hour setting. Press the "+" or "-" buttons to set the current hour. Be sure that AM or PM appears correctly.
Press the "TIME" button to enter the minute setting, Press the "+" or "-" buttons to set the current minute.
Press the "TIME" button to finish setting the current time and return to normal display.
SET MODE:
Press & hold the "MODE" button to scroll between the different Mode settings:
Display Mode Explanation
Digital Timer On/Off at your exact
programmed times (Picture of clock inserted here)
Photocell Countdown Timer On at Dusk or On immediately,
Off after 1-12 hours (Picture of what looks like half sun on horizon)
Digital Timer + Photocell On at Dusk, Off at your exact
programmed times (Combined picture of clock and half sun on horizon)
SET PROGRAM:
After choosing your mode, set the timer program by holding the "PROG" button for 3 seconds, and then follow the appropriate section below.
SET PROGRAM: DIGITAL TIMER
The first setting is "PROG 1 ON" which should appear on the screen. Set the desired day of the week setting for your timer using the "+" or "-" button to scroll between choices. You can select each day individually, Monday to Friday, Saturday/Sunday, or the entire week. To have your timer turn On/Off at the same times every day of the week, be sure to push "+" until all 7 days of the week are lit up for both PROG 1 ON and PROG 1 OFF.
Press "MANU" to enter the "PROG 1 ON" hour setting. Press the "+" or "-" to choose the desired hour for your timer to turn ON. Be sure to cycle through until AM or PM appears correctly.
Press "MANU" to enter the "PROG 1 ON" minute setting. Press the "+" or "-" to choose the desired minute for your timer to go on.
Press the "PROG" button to enter the "PROG 1 OFF" setting. Repeat steps 2 & 3 to set your desired Off time.
You may now either press the "PROG" button to enter additional programs (up to 8), or press the "TIME" button (or wait 15 seconds) to store your program. Your timer will now show the current set time and is ready for use.
SET PROGRAM: PHOTOCELL COUNTDOWN TIMER
The first setting is "PROG 1 ON". Set the desired day of the week program by pressing the "+" or "-" buttons. You can select each day individually, Monday to Friday, Saturday/Sunday, or an entire week. To have your timer turn On and Dusk and Off at the same time every day of the week, be sure to push "+" until
Press "MANU" to enter the hour setting. Press the "+" or "-" to set:
Display Explanation
d Dusk to Dawn - On at sundown, Off at sunrise
d:01 to d:12 On at Dusk, Off 1 to 12 hours later
S:01 to S:12 On immediately, Off 1 to 12 hours later
SET PROGRAM: DIGITAL TIMER + PHOTOCELL
The first setting is "PROG 1 OFF". Set the desired day of the week program by pressing the "+" or "-" buttons. You can select each day individually, Monday to Friday, Saturday/Sunday, or an entire week. To have your timer turn On and Dusk and Off at the same time every day of the week, be sure to push "+" until all 7 days of the week are lit up for both PROG 1 ON and PROG 1 OFF.
Press the "MANU" button to enter the "OFF" time hour setting. Press the "+" or "-" to set. Be sure to cycle through until AM or PM appears correctly.
Press the "MANU" button to enter the "OFF" time minute setting. Press the "+" or "-" to set.
You may now either press the "PROG" button to enter additional programs (up to 8), or press the "TIME" button (or wait 15 seconds) to store your program. Your timer will now show the current set time and be ready for use.
MANUAL OVERRIDE:
Press the "MANU" button to choose the timer status:
Display Explanation
ON Continuously ON
OFF Continuously OFF
AUTO Timer will turn On/Off according to program settings
Dec 01, 2010 | Hardware & Accessories
I bought a house with a Hunter # 44100A programmable thermostat but have no manual to program it from. How can I program it?
To change the time, press Hour once. Then press and hold Hour to until it reaches the correct one (pay attention to the AM/PM notation). Do the same with the Min and Day buttons. Press Return when done. (The thermostat will leave return to the normal mode after 10 seconds without a button press.)
Now to set the program, set the switch to heat or cool depending on which you want to program first. Press Prog (this will program M-F settings) then press and hold Hour until the time you want Prog 1 to start. Press the Up or Down arrows to get to the temperature you want to reach and stay for this period. Press Prog again and use the Hour/Min/Up/Down keys to set the time and temperature for next period. Repeat for program 3 and 4 for weekdays. Press Prog again to do the same thing for the 4 possible weekend program segments. Any time left at 0:00 results in a program being skipped.
Press Prog to set the Program. These settings will not take effect until the next time change in the program. You can review the settings by pressing Prog and scrolling through the settings.
Change the switch to the other setting and repeat the programming if your system has both AC and heat.
If you want to press the AutoProg button the thermostat will use preset times and temperatures. For Heating that is 5 am 68, 7 am 60, 3 pm 68, 10 pm 62. For cooling it is 5 am 78, 7 am 85, 3 pm 78, 10 pm 82.
For more information, you can get the manual from Hunter: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ , just enter the model number in the Search line.
I hope this helps.
Aug 17, 2010 | Hunter Heating & Cooling
Can't get out of control room views
I finally determined that the video card installed in the computer at the time of purchase will not support the game.
Jan 17, 2010 | Video Game Consoles & Games
I recently installed Bridge Baron 15 on a new laptop with Windows Vista and get the following upon startup 'Error reading Std Am with Strong Two Bids profile!' Any suggestions? I can't get beyond this to...
If You run this program using another account than that, which was used to install it on 64bit windows, your account registry is missing "Program Directory" setting:
[HKEY_CURRENT_USER\Software\Great Game Products\Bridge Baron 15\Settings] "Program Directory"="C:\\Program Files (x86)\\Great Game Products\\Bridge Baron 15\\"
In that case program defaults to search hard coded c:\Program Files\ (instead of c:\Program Files (x86)\ directory)
Dec 19, 2009 | Victory Technology Bridge Baron 15 for...
Removed epsom rx600 printer installed lexmark f480 get ocr prob
If you are using MS Vista Operating System then your scanner feature will not work as there is no provision for it in Vista. If you are using MS XP or older, unistall the software from your pc. Detach the device and restart the pc. Re-install the drivers from the cd. DO NOT CONNECT the printer at this stage. Connect it ONLY when prompted or at the completion of installation. Good luck
May 04, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
TextBridge PRO 9.0 to work on Vista Microsoft agent incompatible
You mean you want to download text bridge? For upgrading to pro you need to purchase the software. You can obtain the free version here.
http://www.brothersoft.com/downloads/textbridge-download.html
Jul 06, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
