My webcam iball c8.0 is showing blurr images and is fully blurrr
My webcame is starting and also working but it has become very blurry
  • Computers & ... Master
  • 27,725 Answers
Webcams are useful in both personal and business functions, from video chatting to video conference calls. When your webcam displays strange colors, it is usually due to a problem that is easily fixed even without advanced technical abilities. By trying at-home solutions before sending the computer or camera in for service, you can save time and money.
Lighting
Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu. On a Mac, effects for the built-in iSight webcam can be changed in the Effects 1 and 2 menus in the Photo Booth application. Hope this helps.
Posted on Jan 16, 2013
SUPERMAN_B_1
  • 294 Answers
SOURCE: Blurry image
there should be a ring around the web cam lens that you can turn to fine tune your image just keep playing with it till desired image
Posted on Mar 21, 2009
Mortaza
  • 30 Answers
SOURCE: blurry image
You should turn the blue tab, right in front of the eye. Turn it until the picture is clear again. If you do not understand what I mean, tell me, then I can upload a picture.
Posted on Apr 06, 2007
SOURCE: Drivers for IBALL Face 2 face 1.3 MP / Megapixel /Night Vision
i want driver software for iball c1.3
Posted on Apr 22, 2009
SOURCE: I want a driver for I ball C2.0 face to face webcam
http://www.multiupload.com/VYSSJVCPLD
Posted on Mar 06, 2010
SOURCE: iBall Face2Face Webcam C12.0 not capturing image
I have installed new iBall Face2Face Webcam C12.0 and loaded the software given in the CD. But when i try to view the camera image it gives '' This graph cannot be previed'' error. i have windows xp os
Posted on Apr 10, 2011
Can youi show me how to fix my webcam so i can get clear view , because i do not know how?
Step 1:
A webcam is first and foremost a camera that uses a lens to gather light reflected by an object. There are a number of reasons why the image captured by the webcam can be blurry, all of which can be remedied. Supplies from a photography store or hobby shop, along with items that most people already have in their homes, are needed. The webcam does not need to be disassembled in any way in order to obtain a sharp and clear image.
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu. Aim the webcam towards you so that you can see the blurry image presented in the program's video window. Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp. Blow off the lens at the front of the webcam with compressed air. Moisten the end of a cotton swab in photo lens cleaning solution. Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge. Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image. Launch the webcam video program that is on the hard drive. Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window. Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field. Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam.
Feb 12, 2013 | Logitech Webcam
I instald Iball c8.0 webcam with driver sucessfully but image quality is very poor, i tried every settings till 8mp,is my product defective or some settings re?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Aug 12, 2010 | Mri WebCam
It is giving blurr view? What should be done to improve the picture quality?
Your webcam is one of the less expensive ones, and the best image resolution you can achieve is 0.3Mp, or 640x480. Better webcams can provide images at 1.3Mp or 2Mp. To get the best image possible from the webcam you have try the tips in this article How To Improve Your Webcam Image Quality. Beyond that you'd have to just buy a better webcam. Sorry.
Aug 12, 2010 | Microsoft LifeCam VX-1000 Webcam
I have installed the iball face2face camera C12.0 but no image
Check to see if its a hardware or software problem.
Plug your camera in
Go to this site and see if your webcam works using 3rd party software.
Hit "Allow" in top window and the cam should fire up in the left hand panel.
If it works there you know you still have a software problem
http://www.testmycam.com/
If you have Vista, you can uninstall the software, plug the cam in and the software will be installed on boot-up.
If not, I would recommend you uninstall the software - run the CD again and then go into Device Manager, expand the Imaging file, right click on your webcam and select the update drivers option - from the internet.Delete any redundant webcam software if found.
Aug 16, 2009 | Computers & Internet
IBall Face2Face Webcam C12.0 not capturing image
Jul 05, 2009 | Computers & Internet
The webcam image is not clear when it is in full screen mode
its a low resolution image, the larger the image is made, the larger the pixels become and this makes the image blurry. unfortunately nothing can be done about this besides buying a higher resolution camera.
Jun 18, 2009 | Computers & Internet
I need a driver for Iball Robo 468 Webcam
i have iball robo468 webcam i have lost driver of it can anyone send me a driver for this thank you
my id ameenbird@gmail.com
Jun 03, 2009 | Computers & Internet
Hooked up my web cam and picture is blurr
if the webcam is a budget webcam and the picture looks ok when staying still but is blurry when moving, then there is nothing you can do, that is how the webcam is for the fact it is a budge, low price webcam
if the picture is blurry all the time, usually, around the lens, you can turn something to sharpen the picture up, eg, some cameras you turn the lens's basal itself and it move the lens back and forth changing the focus
Dec 27, 2008 | Logitech Webcam
Blurry Webcam
okay this is what u all do XD
u kno the white part around the camera, like by the lens...
turn that counterclockwise, at first it wont move.. but eventually it will u just gotta try
well anyways hope that helps u guys out :]
Jan 22, 2008 | Logitech Webcam
Computers & Internet Logo
288 people viewed this question
David Payne
David Payne
