Question about Panasonic VIERA Televison & Video
Panasonic tv Th5opz81b flashes red twice will not turn on
    Top Expert:
  • Panasonic Master
  • 75,599 Answers
Two times blinks to Panasonic Plasma indicates 2 blinks 15v SOS D Board. Check this site for more details about blinking codes to Panasonic Plasma displays.
Posted on Jan 16, 2013
zjut
  • 106 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Posted on Jan 01, 2008
  • 18 Answers
SOURCE: Power light flashing...TV won't turn on
Two flashes sugests that the power supply is faulty.It will have to be taken in to a service centre for repairs.
Posted on May 31, 2008
  • 814 Answers
SOURCE: tv stand by red light flashes twice continuosly
This unit is having a problem with component failure and is going into the protection mode. This protects the unit from further damage. You will have to take or send your television in for testing and service.The service center will have all the service information to analyze the problem and do the repairs. If you had given the brand name and model number of the television, i could have directed you to a customer support website or telephone number. This information can be found in your owners manual. I hope this information helps you with your problem.
Posted on May 29, 2009
welcomejee
  • 10594 Answers
SOURCE: I have a Panasonic LCD
2 times red light flashing indicates problem of defective back light inverter board that is either not working or not getting 24V supply.
Check 24V supply at power supply board, if volts appear then replace back light inverter boards and if 24V supply is missing, check/ replace power supply boards.
Required boards are available at ShopJimmy.com
Click above link to view boards images and price info.
Hope this will help you.
Let me know if you have additional question.
Thanks.
Posted on Nov 16, 2010
jdvillanueva
  • 2098 Answers
SOURCE: TV power shut down, began
Hi garnie868,
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the dried-up/leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit and blinking error appear. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Also, bad solder joints can produce the same symptom, it is hard to spot, you should use table lamp/portable lamp for finding the cold solder. Secondary reason of fault is the open fuse/fusible resistor in series with the output of regulator IC/transistor, shorted/openRegulator IC/transistor, shorted zener diode(all are in the power supply section) and the microcontroller. Best that you check the output voltage of each regulator to determine where the fault came from and narrow the job.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 16, 2011
Panasonic TX-L42S10B has power but won't turn on
ok, this may be a silly question but when you turn it on and it starts flashing red, have you tried pressing the stand-by button on the remote. if a tv has been put on stand-by by the remote, and is then switched off by the set, when the set is turned back on it is still in stand-by mode and you need to press the stand-by button on the remote.
other than that I don't know.
Nov 08, 2013 | Panasonic TXL42S10B 42 in HDTVReady TV
1080p PT56LCZ70, won't turn on, green light flashes for a while and then the red light flashes twice, pauses for a second or two and then flashes twice again, continues to repeat this over and over. What...
I have the same problem with my Panasonic PT56LCZ70, after check the test points, I'm sure its the "LIFI 4000" Lamp, and I think its a faulty part in all kind of those Tv's
Jan 15, 2011 | Panasonic PT-56LCZ70 56" HDTV
PT61LCZ70K panasonic tv won't turn on, flashes green light for a couple of minutes then flashes red twice then stops and flashes red twice again. TV Made in Feb 08 lamp shouldn't be gone yet. Manual says...
have a tech clean inside cabinet and replace bulb , should be under warrantee if under 5 years old just had mine done free of charge from panasonic call 1 888 843 9788 they will direct you to a dealer. hope this helps
Oct 01, 2010 | Panasonic PT-61LCZ70 Television
PT-56LC27 52
If the light flashes red 2x's its a problem with the lamp. That's all I know. It's happened twice to me.
Dec 18, 2009 | Panasonic Televison & Video
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Pairing Sky+ Remote with Panasonic Viera remote
3. Press tv again
Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
May 30, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
358 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
