Question about Acer Aspire 3610 Notebook
Will the Lcd Lid Top Cover AP008002400 fit the acer aspire 3610 laptop
Will the Lcd Lid Top plastic Cover reference no AP008002400 fit the acer aspire 3610 laptop as my cover is broken. this part is from an Acer Aspire 3960 laptop
  • 4 Answers
Posted on Nov 08, 2013
kbdesign
  • 370 Answers
SOURCE: were can i get a new lcd rear cover for my acer
You will probably have to get one from a bone yard. Have you tried EBay?
Posted on Mar 17, 2009
jose_v17
  • 227 Answers
SOURCE: Broken screen on Acer aspire 3610
I don't see a problem with the screens it seems that they both have the same specs. The casing is where you might have an issue just check to see if all the clips and screws are in the same positions. you never know till you try
Posted on Mar 25, 2009
joecoolvette
  • 5660 Answers
SOURCE: how do I remove the back lcd cover on my acer
Come in from the front.
The Top Cover has the LCD screen attached to it, and the hinges are attached to it. When you have the laptop closed, you are viewing the Top Cover.
AC adapter unplugged (Charger), battery removed.
Around the LCD screen is a Screen Bezel. This bezel is removed first. Look carefully around the bezel. Upon close inspection you'll see a series of rubber rounded tiny pads. These are Screw Covers. Take a small flat tip Jewelers screwdriver, and remove them, or pry them up to one side, so that you can get to the screw head.
The statement -> Pry, sounds bad. In essence these screw covers, are a half moon shape (Almost) of some rubbery material, and have a glue that holds them on. This glue 'resembles' a type of rubber cement. If you carefully ease the flat tip towards the edge of the half moon shape, where it contacts the flat bezel, push in, and pry up, you'll see they come off relatively easy.
Most of the time if you store the screw covers upside down, glue surface up, you can reuse them with no additional glue needed.
The only problem you'll have with them, is they stick to the screwdriver tip, and your fingertips! Hard to put them somewhere!
Be sure to remove all of them. Generally there are 6. Two per side.
(Top, Bottom, Left Side, Right Side)
Now remove the Philips head screws underneath them. (Have this shape +) (No.1 Philips screwdriver)
Now you have to pop the bezel up, and off. I would use two Jewelers screwdrivers for this. A small kit of Jewelers screwdrivers, can be purchased from a number of places, if you don't have any. An inexpensive set should do just fine, ($5?)
The bezel has a parting line, (Crevice/Gap), where it meets the Top Cover. Sometimes it's a little tough to see. Start with a small flat tip Jewelers screwdriver, and see if you can ease it partially in this parting line. It's a little tough to get the first one started. If it seems as though it won't slide in a little, (Depth of 1/8th inch, or half the width of a No.2 pencil), then move over, try again.
DON'T come in from the LCD screen side. You'll damage the LCD screen, AND the bezel. (Even if you're replacing the LCD screen, you'll break the bezel. Has to be taken off from the outside edge)
Part way in, on the outside edge of the bezel, are locking tabs. These are made of plastic, and formed when the bezel was made. They are part of the bezel. They are spaced around the inside edge of the bezel. They are spaced, Locking tab, space. Locking tab, space. Locking tab, space.
This is why I suggested to move over with the screwdriver. You may be trying to put the screwdriver in, where a locking tab is.
Once you get a start, and have the flat tip Jewelers screwdriver in the parting line, take a second flat tip Jewelers screwdriver, and try to ease it in the gap you've made. Put it towards the end of the gap, where it narrows down. If you cannot, ease the end of the screwdriver you have in now, down. This will pry up on the bezel.
You will see the bezel bend. It fairly thin plastic at this edge, but this is TOUGH plastic. Don't go crazy, but it will bend pretty far, before it would break. Use a fair amount of pressure, but use finesse.
See if the bezel will pop up a bit. You can also move down a bit with the other flat tip Jewelers screwdriver, and try to make another pry point. Working two screwdrivers in this fashion, puts less strain on that plastic bezel.
When you get the bezel up far enough, you'll hear a loud pop, or snap sound. You'll think you broke the plastic bezel. Nope! Just one of those lock tabs letting go of the Top Cover. Keep working around the edge. Watch the top edge. If you have a built in webcam there are small wires close to the webcam. Look in while you're popping the bezel cover up. Use a flashlight if necessary.
Once you have the bezel off, you're home free!
You can now see the screws that hold the LCD screen to the Top Cover. You can see how the hinges are attached. After you're done, the bezel just snaps back into place, then the screws are put in, and the screw covers.
Posted on Apr 24, 2009
copper7op
  • 30 Answers
SOURCE: My top cover of the Acer aspire 9300(9302 AWSMi) has broken...
The best bet is eBay for these things: 79.99
http://cgi.ebay.com/Acer-Aspire-9300-9400-9410-LCD-Back-Cover-Hinges_W0QQitemZ110383131585QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item110383131585&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
this one has free shipping and all that fun stuff. 80 USD is better than 100 quid. You can do it yourself with a screwdriver, it takes about 20 minutes
Posted on May 01, 2009
leecom72
  • 4806 Answers
SOURCE: where can i get a replacement back cover 15.4
Take a look here at eBay for spare plastics for the Aspire 3610>>>>>>>
http://shop.ebay.co.uk/i.html?_nkw=acer+aspire+3610+plastics&_sacat=0&_trksid=p3286.m270.l1313&_odkw=acer+aspire+3610&_osacat=0
Regards.
Posted on Nov 12, 2009
My lid on the acer aspire 3610 has cracked. i
check ebay or google for the part number
Mar 16, 2010 | Acer Aspire 3610 Notebook
Where can i get a replacement back cover 15.4" for my acer aspire 3610
Regards.
Nov 12, 2009 | Acer Aspire 3610 Notebook
How can i find out part numbers for acer aspire 3000/3610. I have a 3000 (broken screen) and a 3610 (dead) , can i swop the screen from my 3610 into my 3000?
The Acer 3000 series and 3610 series has different set of Parts, Hence Swapping the LCD screen may damage your other 3610 LCD also. Please try to get a replacement for Aspire 3000 LCD.
Thank you for using Fixya.
Oct 08, 2009 | Acer Aspire 3000 Notebook
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
Were can i get a new lcd rear cover for my acer aspire 3610 as mine is broken at the left hinge
Mar 17, 2009 | Acer Aspire 3610 Notebook
Cracked laptop screen casing
I didn't find any clear information on other model covers and if they fit, but I did find a cover listed at a decent price.
http://cgi.ebay.com/New-Acer-Aspire-3610-15-LCD-Back-Cover-Hinges_W0QQitemZ200302544446QQcmdZViewItemQQptZLH_DefaultDomain_0
If found a link indicating the 3000, 3690 nd 3610 use the same LCD but that doesn't assure the cover is the same.
Feb 11, 2009 | Acer Aspire 3610 Notebook
Acer 3610 crack by hinges on monitor
Unfortunately the LCD back cover is not readily available but you can find it here http://www.computercare.ca/product.php?productid=18048&cat=1648&page=
I bought this part and replaced my back cover for LCD. be careful while replacing LCD inverter you might be needing a new one.
Aug 19, 2008 | Acer Aspire 3610 Notebook
Cracked front cover at hinges
What does work is this-
Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly.
Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
Feb 18, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
256 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
