I am taking apart my Kenmoore 80 Series washer due to the coupler needing to be replaced. Is there a quick tutorial on taking the motor off to get to the coupler?
  • 130 Answers
Its easy
1-remove the washer cabinet -- usually take screws off controll panel the flip it back, remover the 2 metal clips and un plug wire harness
2-take clips off pump - flip it to the side
3-take clips off motor - usually 2 screws there too. un hook wire harness and pull motor off
there is the coupling
Posted on Jan 26, 2009
The belt came off of the washing machine so it will not spin. We have a kenmore 80 series the model # 110.29852991. I just need to know where it goes back on please. A diagram if possible. Thanks
this unit does not have a belt,,this model number is for a direct drive washer,,,you have a coupling thats in between motor and looks like the picture enclosed..if we are talking about some other part ,,repost...onthejob5130_5.jpg
Sep 11, 2011 | Kenmore Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
I have a Kenmore Series 80 washer and the tub
i would check the motor coupler
it sits behind the motor before the transmission
this model
thre piece part that drives the transmission
Oct 15, 2009 | Washing Machines
I need instructions on replaceing the motor coupler on kenmore washer series 80 mod 110-24822200 typ 111
Check the video at the following link and see if it is of assitance to you in changing the coupler. Sure hope so and best wishes.
Oct 04, 2009 | Washing Machines
The 80 series washer wont agitate or spin. all i
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Jul 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
Kenmore 70 series washer, clothes are soaking wet after spinning
If it fill and motor runs but will not agitate it likely is the coupler. If you have the cabinet off and see the motor here is what you do.
there are 2 metal straps that attach the motor to the transmission. take the screws out that hold the straps on and pop the straps out of their slots. the motor will then come off and the coupler is between the motor and transmission. One section goes on motor shaft and one on the transmission shaft with rubber bushing in between.
Coupler part number is 285753A
May 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore series 80 washer that is making a loud clunking
check the motor coupler between the gearcase and motor for wear. If it is cracked or broken it will need to be replaced
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
80 Series Kenmoore will not spin or timer move
the timmer were the knob is attached to has gon bad it very easy to replace 8 screws and one plug part can cost from 40-80 dolllars
Dec 19, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
