Question about Cutter Tools
What is the common width of the steel cutting wheel on generic glass cutters?
  • 75 Answers
I think you meant diameter of the wheel, since the width is basically that of a razors edge. the most common diameter of the cutting wheel is 7/32", unless your tool is made for cutting patterns or circles, in which case the wheel diameter should be 1/8"
Posted on Jan 16, 2013
How to cut glass and metal tiles?
You will have better luck with a hand glass scorer, looks like a pen with a score wheel at the bottom and the tube is filled with oil (like a sewing machine oil). If you want to cut each tile individually, then snap the tile by holding each side with a pair of snubby pliers wrapped in tape (slippery otherwise) You can get a glas scoring pen at craft stores with stained glass supplies or a stained glass supply shop or online. The wet saw is used to cut a row of the tiles at once, which is most efficient. The sliding tile scorer would be too cumbersom to hold the small tile in place and try to cut.
Perbaiki lantai teraso Teraso cor di tempat Terazo and mosaic tile
May 01, 2015 | Saws
How to cut glass in a oval
I used a Dremel with a diamond cutting wheel. First draw the oval shape you want in a window marking pen available from newsagents or post office, so you can rub it off easily. Then slowly cut around the edges, you will end up having to do small straight cuts keeping as close to the line as possible and then just file or sand the small edges that are left. Make sure you wear protective eye goggles and i would recommend a mask of some sort so as not to breath in the glass dust. Good luck.
Sep 04, 2014 | Cutter Tools
How do I cut up a large mirror?
Essentially the same as cutting glass. Get a glass cutter with a new sharp wheel. Practice on a piece of scrap glass the touch. Firm but not too heavy then make a smooth stroke along a straight edge to guide your cut.
Put a t' thick board under the line to be broken with the board to the left of your intended cut then make a push down on the glass to the right of the break line. If you have made a good continuous scribe line in the glass completely along your cut line it will snap cleanly into your desired two pieces. Repeat until you have the sizes you want. It will only break in straight lines in this method.
Us a torch to burn the edge corners to keep them from cutting you. Just heat it long enough to round the sharp edge.
Jul 02, 2014 | Home
What is a glass cutter?
"A glass cutter is a tool used to make a shallow score in one surface of a piece of glass that is to be broken in two pieces. The scoring makes a split in the surface of the glass which encourages the glass to break along the score." (Wikipedia)
Oct 07, 2013 | Cutter Tools
How do you use a glass cutter?
Here is a video showing the basics of how to cut a piece of glass, in this case a mirror, with a small glass cutter.
http://www.youtube.com/watch?v=rQaLV35HQEU
When was the steel wheel cutter invented?
this now common addition to the glass cutter tool was invented by Samuel Monce in Bristol, CT in 1869
Jan 16, 2013 | Cutter Tools
All the chains i cut cut to the right not straight through the log. The bar is new.
Pay a professional to sharpen one chain. If that cuts straight examine your sharpening procedure or the individual that does the sharpening.
Lou
If not please post back below.
Jan 26, 2010 | Oregon Scientific Oregon Bench-Mount...
My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Aug 22, 2009 | Garden
Glass shelve on bottom over grisper is broken Sanyo SR-9510W
You didn't say what size or model Sanyo you have, but the solution is easy. I have a Sanyo under the counter refrigerator in which the glass over the crisper is 1/8" thick frosted glass, 16" by 6 3/4" with the two back corners cut off diagonally. The frosting is simply to prevent you seeing through into the crisper below. It is maybe fifteen minutes work with a piece of window glass and a glass cutter to make a replacement. My full size refrigerator uses 1/4" glass since it is much larger and I have replaced it myself this way. If you don't have a glass cutter -- they are cheap and available in all harware stores -- you should be able to get any hardware store to make the cuts for you. They are accustomed to making custom cuts for people replacing their own windows. The have, and I use, what is known as an oil cutter which is a lot easier to use than the little hardened steel wheel cutters you will get if you buy a cheap one. Those work fine for straight cuts. Oil cutters make curver cuts equally easy to do.
Dec 07, 2008 | Sanyo SR-9510W Refrigerator
Plasma cutter
in order to cut the thicker steel just boost the air pressure this will allow you to thourghly blow through the steel. just remember not to turn it up too much. this should do the trick. please rate
Sep 15, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Cutter Tools Logo
909 people viewed this question
Top Cutter Tools Experts
JOHN LAPIER
Are you a Cutter Tool Expert? Answer questions, earn points and help others
