Question about Cutter Tools
When was the steel wheel cutter invented? - Cutter Tools
  • 75 Answers
This now common addition to the glass cutter tool was invented by Samuel Monce in Bristol, CT in 1869
Posted on Jan 16, 2013
What am I able to drill through with a milling machine?
Milling machines are very versatil, they are able to cut through almost all solid materials.
Jan 23, 2014 | Tools & Hardware - Others
What is a double wheeled pizza cutter?
a double wheel pizza cutter is a pizza cutter that has 2 wheels - one behind the other. The advantage of the two wheels is that they go through the pizza in one motion and you don't have to go back and forth to get a clean cut through the pizza.
Feb 28, 2013 | Home
What is the common width of the steel cutting wheel on generic glass cutters?
I think you meant diameter of the wheel, since the width is basically that of a razors edge. the most common diameter of the cutting wheel is 7/32", unless your tool is made for cutting patterns or circles, in which case the wheel diameter should be 1/8"
Jan 16, 2013 | Cutter Tools
My mother-in-law's insinkerator shakes violently when turned on. She believes I broke it when I put some small watermelon rinds down it recently. Any advice?
You cant break stainless steel cutter blade, welded parts and steel ball bearings with water mellon rinds.
Even a metal fork should not break a garbage disposal ... the fork will wedge against the side wall and cause cutter blade to get stuck. Once the fork is removed, no damage is done.
If insinkerator is shaking, then either a bearing has rusted out, or the shaft has finally worn out.
The stainless cutter blade is permanently attached to a steel shaft that goes into the sealed bearing. If the cutter weld is broken, then the disposal will wobble. If the bearing wears out, then the steel shaft will wobble. If the steel shaft is worn down at the bearing, then the cutter plate will wobble. A tiny bit of wobble will cause the disposal to shake. A brand new disposal will vibrate.
Check date of purchase receipt.
Amazon shows warranty is 2 years:
http://www.amazon.com/InSinkErator-Badger-Food-Waste-Disposer/dp/B00004U9JO/ref=sr_1_3?ie=UTF8&qid=1303015273&sr=8-3
If disposal is 3-5 years old then that is a short lifetime for a solid product like the 1/2 HP.
If disposal is 5-8 years old, that's a good run. 8-12 years is very good.
I wrote tips for replacing disposal from days when I worked apartment maintenance:
We replaced disposals every 6-7 years. Some never wore out. Others went bad right away.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Apr 16, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a 1984 Chevy Silverado V6 2 wheel Drive. I replaced the fuel filter, since then it continues to leak gas at the fitting to the carb. Have bought 2 rebuilt carburaters and the same thing, it leaks.
The fuel line flare no longer can seal. You might be able to use a tubing cutter to remove 3in of steel fueline with the fitting at a wrecking yard. Use the tubing cutter to cut your old line and use a rubber fuel line hose with mini clamps to re-connect everything.
Mar 13, 2011 | Chevrolet Silverado Cars & Trucks
Why does my garbage disposal keeping locking up? I've checked inside to see if anything is lodging the blades but can't find anything.
Next time it sticks. Vacuum out everything.
See if the cutter wheel is still lodged.
Or if cutter wheel rolls free.
If cutter wheel rolls free after a simple vacuum, then I would suspect the motor is old and weak.
If cutter wheel is still lodged, then check around the edge and see what is stuck.
If there are pieces of metal, then the cutter wheel is probably falling apart bit by bit.
Oct 24, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Need to change timing chain. do i need to remove the head?
Check the vehicle manual for recommended mileage for replacing the timing chain.Locate the timing chain,you will need to replace it if the automatic chain adjuster "also known as the tensioner " is damage or worn.Drain the cooling system and disengage the negative battery cable.Undo the spark plug wires and set the No.1 piston at Top Dead Center ( TDC ) of the compression stroke. Disconnect the engine undercover,vacuum and fuel hoses,harness and connectors,drive belts, power steering reservoir,alternator and bracelet,upper radiator hose and,air doct,front exhaust tube,intake manifold collector supports,collector and exhaust manifold and distributor.Prop up the oil can and take out the front engine mounting,the valve cover and camshaft sprockets,cam bearing caps and camshafts,cylinder head bolts, cam sprocket cover,upper chain tensioner,chain guide and the chain,idler sprocket bolt,cylinder head,intake manifold and cylinder head gasket and the steel oil pan. Place a steel cutter between the steel and aluminum oil pans.Slip the cutter around the the edge of the oil pan and disengage the steel oil pan,baffle plate,oil strainer and front tube. Secure the vehicle on jack stands and place a seal cutter between the oil pan and the cylinder block,slip the cutter around the edge of the oil pan.
Aug 15, 2010 | 1997 Nissan Pickup
Glass shelve on bottom over grisper is broken Sanyo SR-9510W
You didn't say what size or model Sanyo you have, but the solution is easy. I have a Sanyo under the counter refrigerator in which the glass over the crisper is 1/8" thick frosted glass, 16" by 6 3/4" with the two back corners cut off diagonally. The frosting is simply to prevent you seeing through into the crisper below. It is maybe fifteen minutes work with a piece of window glass and a glass cutter to make a replacement. My full size refrigerator uses 1/4" glass since it is much larger and I have replaced it myself this way. If you don't have a glass cutter -- they are cheap and available in all harware stores -- you should be able to get any hardware store to make the cuts for you. They are accustomed to making custom cuts for people replacing their own windows. The have, and I use, what is known as an oil cutter which is a lot easier to use than the little hardened steel wheel cutters you will get if you buy a cheap one. Those work fine for straight cuts. Oil cutters make curver cuts equally easy to do.
Dec 07, 2008 | Sanyo SR-9510W Refrigerator
Plasma cutter
in order to cut the thicker steel just boost the air pressure this will allow you to thourghly blow through the steel. just remember not to turn it up too much. this should do the trick. please rate
Sep 15, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Cutter Tools Logo
900 people viewed this question
Top Cutter Tools Experts
JOHN LAPIER
Are you a Cutter Tool Expert? Answer questions, earn points and help others
