No wireless on my toughbook CF-31
I just bought a toughbook cf-31 that came without a wireless card. I had one lying around and put it in but it cant seem to see it in device manager. I looked it up and I should be able to see it in the bios but its simply not there. How can I get the computer wireless ready? Any help is greatly appreciated.
  • Steve B Jan 16, 2013
    I am running Windows 7 32bit and have the intel pro wireless driver and software loaded on the computer. It tells me it cannot find the hardware. I verified the hardware is installed and the connection looks clean.
  • 7,627 Answers
You install a wireless Adapter in a Laptop? Why not use a USB wireless adapter? Where did you get the driver software? If the driver didn't come from the exact model and Laptop Manufacturer's website, the hardware ID may be different, requiring you to open the driver software and modify the hardware ID of the driver. In effect writing a few lines of code in the driver itself. i have done this and it can be done, but requires a bit of research.
Posted on Jan 16, 2013
  • Steve B Jan 17, 2013
    Yes, I put in a similar model intel pro wireless card that would have come from the factory, and downloaded the correct driver and software. The problem i am finding is that the wireless settings in the bios are non existant. I looked at the Panasonic manual and thats where it said it would be to correct my problem. How can I unlock the bios in order to have the computer read that there is hardware in the wireless port?
  • max carson
    max carson Jan 17, 2013
    Is it listed it Device Manager? When you installed the Wireless card and rebooted did the laptop software ID it as unknown device? If the wireless driver you install has a different Hardware ID written in the code, the driver will fail to locate the hardware. What happened when you installed the driver? I have done similar procedures and had to write a new Hardware ID into the driver, and modify the compitibility.
SOURCE: Install XP on Panasonic Toughbook CF-27 ?
sxcss
Posted on Apr 30, 2008
1234s282
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Posted on Jan 04, 2009
  • 130 Answers
SOURCE: cf-27 wireless driver
www.panasonic.com/.../Toughbook/laptop-computers this link should fix ya and please rate my help, and thanks
Posted on Jun 21, 2009
MrObvious
  • 115 Answers
SOURCE: wireless connectivity
possible reasons that it is "off"
Physical switch on outside of case that has a turn on and turn off function. Make sure this is turned on.
Go to network places and find the connection that says wireless (or something similiar), it should say Enabled, if not then enable it.
Posted on Jun 22, 2009
1alexh
  • 484 Answers
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Where is the wireless swith on the cf-19
The wireless switch is behind the PC Card Door located on the left side of the Toughbook 19
Rugged Mobile Technology Panasonic Toughbook Toughpad Tablet Sales...
Jun 16, 2014 | Panasonic TOUGHBOOK CF-18 Tablet PC
How do you obtain the hard drive serial numbers for CF-30 and CF-31
Try this freeware program, SPECCY at: http://filehippo.com/search?q=speccy Install and start, look at the HARD DRIVE section. You will find useful info to ID your Laptop's hardware/software OS.
Aug 24, 2013 | Panasonic Toughbook CF-29 Notebook
How can I enable wireless for none wireless module of CF-R8?
I suggest staying away from BIOS flashing. Last thing you want is a brick.
In Win 7 - Go to Start > Control Panel > Network and Internet > Network and Sharing > Manage network connections. Enable the wireless card.
In XP - Go to Start > Control Panel > Network Connections. Enable the wireless card.
Oct 14, 2012 | Panasonic Toughbook CF-R8 Core 2 Duo...
Get wifi to work on Panasonic Toughbook CF-29 PC Notebook
if you don't have a card, you can always buy a pcmcia card if it has the appopriate slot. if not you can buy a usb adapter for it. make sure that you have the physical on/off switch set to on
May 05, 2012 | Panasonic Toughbook CF-29 Notebook
How to remove wireless card from panasonic cf-51?
The mini pci card or wireless is under the small access door on the bottom of the laptop. It is accessed with one screw holding the access door in place.
Jun 21, 2010 | Panasonic Toughbook CF-51 Notebook
I have a CF-73 toughbook that keeps dropping off network
What frequency is your wireless network? And do you have a cordless phone in the area where your router is? You may have to go into your router settings and select a different channel within its frequency range as some cordless phones will constantly scan the channel bandwidth and knock off your wireless connection.
Apr 19, 2009 | Panasonic Toughbook CF-73 Notebook
On boot up a safeboot apears and asks for password i bought this secondhand and its been trouble from day one anyone out there please help also bios has had a password done as well so cant get into that...
if you are able to open motherboard then simply remove CMOS bettry for 10 sec and put again then password will reset...if you dont open motherboard then ask me?????
Apr 03, 2009 | Panasonic Toughbook CF-51 Notebook
OS wont recognize wireless modem
This happen regularly on the older Toughbooks. Find an XP or Win2000 modem driver for the 27 or 72 at Panasonic's support site or driverguide.com and it should work just fine. It will allow the machine (XP) to recognize the modem and install the drivers.spellcheck.gif
Sep 02, 2008 | Panasonic Toughbook CF-27 Notebook
SD wifi
I would rather go for CF wifi card, because Panasonic doesn't states that this one has SDIO type slot. If you use CF slot you will have to find WIFI card cover - it's different one - it will allow to close top cover with the card inside.
There was also two models:
  • CF-P1P1CDZ6J - Bluetooth / wireless LAN built-in
  • CF-P1P1CZZ6J - Built-in wireless LAN-model
Apr 28, 2008 | Panasonic Toughbook CF-P1
Computers & Internet Logo
David Payne
David Payne
