Question about Cutter Tools
Are bolt cutters safe to use around live electricity?
  • 75 Answers
Only if they have fiberglass handles. these are the kinds that are used in emergency situations
Posted on Jan 16, 2013
How do i fix my bolt cutters
you can try tightening all the pivot bolts but generally when this happens there is not much that can be done but to junk them
the secret with bolt cutters is to get the size that is 3 times the size of any bolt you intend to cut as cutting a maximum size bolt on smaller cutters is what puts them out of line
Jun 15, 2016 | Air Tools & Compressors
How to remove the oil pan easy and safe from a 2005 crv honda
Hi Evelyn.here's a link on your oil pan removal,it says engine removal,will send a link on that too. SAVE 20 ON ONLINE SHIP TO HOME ORDERS OF 100 OR MORE Here's the engine removal guide. SAVE 20 ON ONLINE SHIP TO HOME ORDERS OF 100 OR MORE
May 17, 2015 | 2005 Honda CR-V
My blades are a little dull will the blades still cut through a bolt?
You shouldn't really be using dull bolt cutters because it requires more force to cut through the metal which increases the likelyhood that you will get an injury. Yes you can use dull bolt cutters but you should always make sure that your blades are sharp before you use them.
Nov 14, 2013 | Cutter Tools
Are bolt cutter blades really sharp?
A pair of new or freshly sharpened bolt cutters will be sharp enough to cut through skin if you run your finger along the blade. Never run your finger along the blade to check for sharpness.
Flymo electric power trim..dual auto feed line keeps getting wound around the drive shaft...bloody annoying any suggestions.. Ian (M)
Most trimmers have a cutter on the shield by the spool. This cuts excess line off to prevent it from wrapping around the shaft. If the shield has been removed or the cutter is dull it will allow extra line to wrap around the shaft.
Aug 03, 2011 | Garden
How do I assemble the bar and chain on my 1.5hp chain saw MS1415?
Start by removing the bar nut/nuts, and remove the side cover, if the chainbrake is in the cover make sure this is off by pulling the hand guard fully back to the top handle, before removing the side cover, wind the chain adjuster screw fulley in toward the rear of the saw ( it may be in the crankcse, or in the side cover ) now assemble the guide bar onto the bar bolt/bolts, loop the cutter chain over the sprocket,and into around the tip of the guide bar, and into the bar rails, make sure the sharp end of the cutters on the top of the guide bar are facing away from the saw ( the chain rotates clockwise as you look at it ) now align the adjuster hole in the bar with the adjuster pawl on the machine, now re fit the side cover, if the adjuster pawl is in the cover make sure this lines up with the adjuster hole in the bar, assemble the bar nut/nuts finger tight, adjust the chain so as it touches all the way around the guide bar ( not sagging on the bottom of the bar ) with a gloved hand pull the chain around the bar to make sure it is free and sitting in the sprocket correctly, re adjust the chain if required, now lift the nose of the bar and fully tighten the bar nut/nuts
Feb 10, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
Electric line trimmer: line simply cuts off and disappears after a few seconds; can this be that the line is too thin? It is a prewound purchased replacement, so must be wound the right way. Has a...
you can replace the head of the unit as it is bolted on left-handed threads, Lowes, HomeDepot, Wally world, Kmart, basically any discount store sells replacement heads for weed-eaters. hope this helped Tim
Nov 20, 2010 | Ryobi 15" Electric Factory Reconditioned...
Need to change timing chain. do i need to remove the head?
Check the vehicle manual for recommended mileage for replacing the timing chain.Locate the timing chain,you will need to replace it if the automatic chain adjuster "also known as the tensioner " is damage or worn.Drain the cooling system and disengage the negative battery cable.Undo the spark plug wires and set the No.1 piston at Top Dead Center ( TDC ) of the compression stroke. Disconnect the engine undercover,vacuum and fuel hoses,harness and connectors,drive belts, power steering reservoir,alternator and bracelet,upper radiator hose and,air doct,front exhaust tube,intake manifold collector supports,collector and exhaust manifold and distributor.Prop up the oil can and take out the front engine mounting,the valve cover and camshaft sprockets,cam bearing caps and camshafts,cylinder head bolts, cam sprocket cover,upper chain tensioner,chain guide and the chain,idler sprocket bolt,cylinder head,intake manifold and cylinder head gasket and the steel oil pan. Place a steel cutter between the steel and aluminum oil pans.Slip the cutter around the the edge of the oil pan and disengage the steel oil pan,baffle plate,oil strainer and front tube. Secure the vehicle on jack stands and place a seal cutter between the oil pan and the cylinder block,slip the cutter around the edge of the oil pan.
Aug 15, 2010 | 1997 Nissan Pickup
I forgot my combonation to my wordlock and now i cant unlock it what do i do
Get a pair of bolt cutters and cut it off. Next time, write your combination down and store it in a safe place that is easily remembered.
Jul 01, 2010 | Locks & Locksmithing
Remington M8221 Help
STEPS
• Thoroughly clean the razor cutter area
• Pull off (straight out) cutters and lay aside
• Release spring clips and remove
• Gently pry up and remove rubber boot
• Pry case open starting at cutter end and bending up toward connector end
• Thoroughly clean razor interior area (blow out)
• Pull up motor and remove black oscillator bars
• Pry up the circuit board by releasing the cutter-end catch using a small tool to push it in while prying gently up on the cutter-end of the board and bending up
• Clean the board and turn it over
• Note battery polarity and mark on board if not present already
• Unsolder the battery tabs using unsolder braid. Be careful not to short the electrical circuitry as the batteries are electrically LIVE at this point.
• Remove the old batteries and fully clean off the circuit board solder-pads using unsolder braid.
• Mark the installation date on the new batteries in a place where it will be visible
• Install new batteries, making sure the polarity is correct (cut the tabs to a correct length if they extend too far through the circuit board)
• Solder the battery tabs being careful not to short the electrical circuitry as the batteries are electrically LIVE at this point
• Re-install the circuit board and other parts following the procedure in the reverse order (be sure to put a soft rubber pad over the motor to hold it firmly in place when the upper case half is snapped in place)
• Before installing the metal retaining clips be sure that the rubber boot is fully free and not pinched between the case halves
• Finalize the assembly by reinstalling the cutters and screen
Feb 24, 2008 | Remington MicroScreen Intercept M-8221...
Cutter Tools Logo
690 people viewed this question
Top Cutter Tools Experts
JOHN LAPIER
Are you a Cutter Tool Expert? Answer questions, earn points and help others
